(2018-04-04, 17:59)matty8199 Wrote: [ -> ] (2018-04-04, 17:57)Dixon Butz Wrote: [ -> ] (2018-04-04, 17:54)matty8199 Wrote: [ -> ]Download the newest version, it takes out the commercial loop.
I have 2018.3.27
Isnt that the latest?
Nope, 4.2 is out.
Is that in the repo?
I have to go. BBL
The beta you d/l is still 3.27, you need to update it to 4.2 in Kodi.
Update 2018.4.4 Released
- Re-Enabled stream quality setting (Best Available or Always Ask)
- Minor bug fix
(2018-04-04, 20:14)eracknaphobia Wrote: [ -> ]Update 2018.4.4 Released
- Minor bug fix
Working nicely on Yankee game and no ads!
Just tried and I'm getting tons of freezing on certain feeds. The Hou vs Bal feed for instance works fine on Bal feed but the Hou feed is unwatchable.
Just tried on spmc with 4.2 and 2.1.0 python and the Hou feed is fine.
This on a Shield.
(2018-04-04, 21:05)sask3m Wrote: [ -> ]Just tried and I'm getting tons of freezing on certain feeds. The Hou vs Bal feed for instance works fine on Bal feed but the Hou feed is unwatchable.
This on a Shield.
Tried the Bal feed but I am blacked out. Guess Addfreetime doesn't get around the blackouts anymore.
Had one instance of freezing on Yankee game.
The Bal feed was good but for some reason Hou feed was terrible.
- Minor bug fix
Tested great on Debian9 && rpi LibreElec 8.2.4! I like the streamlined new 'dynamic' selection ability.
Streams fail in Krypton 17.6 using MLB 2018.4.4.
Mac OS X 10.10.5 Yosemite
log file at
http://ix.io/16E4
I see the unsupported dependencies error in my side-by-side install of Jarvis, which I prefer over Krypton. I am looking forward to your plugin being supported on both sides.
Previous installs this year had successfully connected but with a great deal of buffering slowdown. Thanks for your hard work!
UPDATE EDIT: appears to be the popular demuxer error
"14:01:18.656 T:4520574976 ERROR: OpenDemuxStream - Error creating demuxer"
Has anyone been able to get the radio audio to work for live games?
When you try to switch audio streams in Kodi it just exits back to the menu or crashes.
4.4 working w/ the ability to choose bandwidth on spmc (via @
sask3m and his glorious hack) and also seems to be working (at least initially) on kodi 17.6 on android. i'll keep an eye on it and try it on the fire stick too...will report back.
edit: as has been said though, 4.2 and 4.4 don't seem to support audio overlay unfortunately. not sure if that's a limitation of switching to browser streams. @
eracknaphobia any word on that?
For those who don’t know. There’s a krypton alpha version of SPMC out there. 17.6. And this add on is working gloriously on it.
can confirm that 4.4 fixes the demuxer error on fire stick, at least when using "always ask." i'll probably stick with spmc though since it does seem to be a bit faster.
eracknaphobia one thing i noticed that is different from last year is that the only two options are best available or always ask...any plans to allow setting one of the available resolutions ahead of time, or is that not possible with the api changes? also, is there any chance of bringing back audio overlay with the new browser streams?
datapoint, following matty8199's observation regarding 'always ask,' and reconfiguring the plug in to follow his lead, I was able to successfully begin streaming the MIN game. I did not try leaving it up or messing with various bitrates.
