Eracknaphobia, thank you for continuing with this add-on! Are you planning on adding a 'play all recaps' option? They can't be watched now without spoilers.
The ability to select between the two different CDN's, appears to have been removed in 2018.4.4 . I was going to test if one network was better than the other in solving the freezing problems.
both feeds for mets/nats not working at the moment...anyone have it working?
edit: now they seem to be up. not a very promising start for mlb.tv this year...
Watching the Bos - TB game, and every time during the commercials I have to exit the stream and reload because it's unable to get back to the game play? Frustrating.
(2018-04-05, 23:17)sonicmouse Wrote: [ -> ]Watching the Bos - TB game, and every time during the commercials I have to exit the stream and reload because it's unable to get back to the game play? Frustrating.
The NESN feed of that game is playing well for me with bandwidth set to 1800 kbps. At higher resolutions I was getting a lot of buffering and freezing even though I have a 100 Mbps Internet connection.
(2018-04-05, 23:24)hhqjdaasc Wrote: [ -> ] (2018-04-05, 23:17)sonicmouse Wrote: [ -> ]Watching the Bos - TB game, and every time during the commercials I have to exit the stream and reload because it's unable to get back to the game play? Frustrating.
Thanks I'll try this yeah watching the NESN feed. I have a gbps - around 700Mbps a symmetrical using as WeTek Play 2 box, using the latest update.
you're stronger than me...i'd rather watch at a higher bitrate with some buffering (as long as it's not crazy) than at 1800kbps. if it's not at 60fps it drives me nuts...
(2018-04-06, 01:23)matty8199 Wrote: [ -> ] (2018-04-05, 23:24)hhqjdaasc Wrote: [ -> ] (2018-04-05, 23:17)sonicmouse Wrote: [ -> ]Watching the Bos - TB game, and every time during the commercials I have to exit the stream and reload because it's unable to get back to the game play? Frustrating.
I hear you, but when set to use 720p@60fps resolution it was impossible to watch; it would just freeze, freeze, and freeze again.
Here’s how I rationalize putting up with less than HD resolution. When I was growing up we lived about 90 minutes from Boston and we’d either listen to the BoSox games on the radio or watch them on a primitive TV with a rotor-driven antenna that was only barely able to pull in Boston channels. Now I live 13,000 kilometers away and the problem is that I sometimes have to settle for 504p@30fps. Actually that’s not a huge hardship - while I'd like to get the resolution that I'm paying for it still amazes me that I can watch any team's games any day from halfway around the world.
(2018-04-06, 03:22)hhqjdaasc Wrote: [ -> ] (2018-04-06, 01:23)matty8199 Wrote: [ -> ] (2018-04-05, 23:24)hhqjdaasc Wrote: [ -> ] The NESN feed of that game is playing well for me with bandwidth set to 1800 kbps. At higher resolutions I was getting a lot of buffering and freezing even though I have a 100 Mbps Internet connection.
fair enough!
(2018-04-04, 20:14)eracknaphobia Wrote: [ -> ]Update 2018.4.4 Released
- Re-Enabled stream quality setting (Best Available or Always Ask)
- Minor bug fix
Thanks for continuing to update!!
Using Kodi 17.6 on my Nvidia Shield it is working well with 1 exception - if I select "Always Ask" I then have no option to toggle the audio stream(s). I don't know if that is a bug or intended behavior.
Thanks again great work!
Would an Nvidia Shield be an improvement? I also would need to be able to use a VPN with it.
So from now on all versions in my repo will support jarvis 16, Nope still get error with Jarvis Hellllllllllllllllllllllllllllp....
(2018-04-07, 03:35)Kanipek Wrote: [ -> ] (2018-04-04, 20:14)eracknaphobia Wrote: [ -> ]Update 2018.4.4 Released
- Minor bug fix
Oh! Thanks for this post! I just assumed the new version left out the ability to toggle between the audio streams. I could live with not using "Always Ask".
Has any one successfully toggled the audio stream on a live broadcast?
Has anyone actually got the new update to work with Jarvis 16.1?? I get the same error on yesterdays and todays game very time...
