(2018-04-25, 20:06)architeuthis Wrote: [ -> ]Is there a way to watch recaps without spoilers, with Kodi or otherwise?
Yes! If this addon doesn't do it anymore, you can use the Baseball Theater web site or Android app, just toggle Hide Scores in the settings:
https://baseball.theater
(2018-04-26, 17:10)tonywagner Wrote: [ -> ] (2018-04-25, 20:06)architeuthis Wrote: [ -> ]Is there a way to watch recaps without spoilers, with Kodi or otherwise?
Thanks, this helps!
Is it just me or does the order of listing Home or Away in the menu for completed games depend on who won?
(2018-04-28, 18:36)Common Man Wrote: [ -> ]Is it just me or does the order of listing Home or Away in the menu for completed games depend on who won?
It is random as to which comes up first. I'm gonna try to put together a pull request to get it in the same order each time.
(2018-04-25, 02:05)lynx649 Wrote: [ -> ]Does anyone here have highlights working consistently and if so what are your settings ? I can sometimes get them to play if I use Level 3 and try a highlight a few times however it stops playing after a few seconds and I can see the buffer loading very very slowly but not enough to keep up with the video. I'm in Australia but have tried with my Canadian VPN, same symptoms as well on multiple devices.
Live streams have been working 100% for me using Akami.
I have kinda the same problem with condensed games... I haven't found a fix so far.
I'm on Raspberry pi 3 with Kodi 18 nightly.
Ugh, I'm really struggling to stream for some reason my add-on is updated the top one and yes I can guarantee my connection etc is fine. Should I be clearing cache / purging modules bless advise why my streams are stuttering.
Edit: I'm also getting a lot of "Playback failed" errors - One or more items failed to play. Check the log for more information about this message.
(2018-05-09, 21:31)sonicmouse Wrote: [ -> ]Ugh, I'm really struggling to stream for some reason my add-on is updated the top one and yes I can guarantee my connection etc is fine. Should I be clearing cache / purging modules bless advise why my streams are stuttering.
Ya, it's not working for me either past few days.
I'm genuinely sad, I'm in the UK and I pay for an MLB sub, this was my go to method of watching the games... and with these consistent issues. I'm not sure what an alternative method to stream to my big TV is.
(2018-05-12, 01:37)sonicmouse Wrote: [ -> ]I'm genuinely sad, I'm in the UK and I pay for an MLB sub, this was my go to method of watching the games... and with these consistent issues. I'm not sure what an alternative method to stream to my big TV is.
What do you have hooked up to your big TV?
What issues are you having? I live in Thailand and there I'm using a generic Android box and have fibre internet. There I sometimes am able to get through a game at the highest resolution settings (720p@60fps) but often I need to use a lower resolution in order to avoid buffering. For the past couple of weeks I've been in Atlanta and using the addon on a NVIDIA Shield and Comcast as an ISP and I've yet to get any buffering even at the highest resolution setting even when using a VPN. So basically I'm happy with MLBTV this year - as long as I select "Akamai" as the CDN the streaming seems to be as good as on any other streaming service.
I have mlb.tv account but no streams with this mlb.tv kodi addon using on kodi windows and android box....any update from author?
More detail on what you mean by "no streams". If you are getting errors post a log file. when in doubt read the first post.
(2018-04-28, 19:12)matty8199 Wrote: [ -> ] (2018-04-28, 18:36)Common Man Wrote: [ -> ]Is it just me or does the order of listing Home or Away in the menu for completed games depend on who won?
This will be fixed in the next release.
Any luck with bring back audio overlay, OP?
