Full Version: MLB.TV®
Update 2018.8.16 Released
- Add ability to toggle catch up mode
Addon settings > Visual > Catch Up (Default Enabled)
Thank You for the catchup opion!!! Your awesome!!!!!!!!!!!!
None of the alternate audio streams are working for me today. Has anyone else experienced this issue?
(2018-08-26, 22:09)markdstjohn Wrote: [ -> ]None of the alternate audio streams are working for me today. Has anyone else experienced this issue?
I didn't watch yesterday, but I just loaded up a live game now (Monday night) and all 4 audio tracks worked as expected.
What do you mean by "not working" -- did they not appear, or did they not have any audio? Did it affect live games, archived games, or both?
I am having an issue with the audio streams as well. I am able to select all 4 but only the TV broadcast audio has sound. The other 3 are silent.
(2018-08-30, 05:39)zalo Wrote: [ -> ]I am having an issue with the audio streams as well. I am able to select all 4 but only the TV broadcast audio has sound. The other 3 are silent.
Still working for me on live games today.
If you still have trouble, one idea is to make sure you have the Inputstream.Adaptive addon active, and it might not hurt to update it manually too (download the zip from Github, and install it in Kodi):
https://github.com/peak3d/inputstream.adaptive
Otherwise, you might need to share some debug logs.
I currently have Inputstream.Adaptive version 2.0.20. This is the most recent version compatible with Kodi 17.6.
Also it doesn't seem like you are able to install from zip.
How to install
inputstream.adaptive is an official kodi binary addon and therefore either already installed or available from kodi binary repo repository (linux). Pls. refer to kodi sources about how to install kodi binary addons if its not in your installation.
Here is my log.
http://paste.osmc.tv/eqoqoxosin
Edit:
Seems like it is a codec issue. Stream 1 is codec id 28 and the other three are 86018. Not sure where to go from there.
Just wanted to say thank you for this awesome add-on. Better quality streams and less delayed than anything on roku.
(2018-08-31, 03:59)zalo Wrote: [ -> ]Also it doesn't seem like you are able to install from zip..
You can install InputStream.Adaptive from zip, but you generally don't need to. I wouldn't worry about it here.
(2018-08-31, 03:59)zalo Wrote: [ -> ]Here is my log.
Edit:
Stream 1 is the video, so it should be a different codec! I see the same 86018 audio codec in my logs. I am running Kodi 18 though.
I notice in your logs it says ffmpeg 3.1. I know when I was using the Python script mlbstreamer earlier this year, it needed ffmpeg 4 to get the alternate audio tracks. And my Kodi 18 has ffmpeg 4 too.
Is there any way to disable Input Stream Adaptive just for MLB.tv? Looks like the Comet TV Live add-on from the Kodi repository installed it. It wouldn't let me disable the Input Stream Adaptive unless I disabled that add-on as well (which I did). With Input Stream Adaptive enabled I only get 960x544 29.97 fps. I tried the solution that was posted here for that but it didn't work.
(2018-09-15, 06:46)relayer35 Wrote: [ -> ]Is there any way to disable Input Stream Adaptive just for MLB.tv? Looks like the Comet TV Live add-on from the Kodi repository installed it. It wouldn't let me disable the Input Stream Adaptive unless I disabled that add-on as well (which I did). With Input Stream Adaptive enabled I only get 960x544 29.97 fps. I tried the solution that was posted here for that but it didn't work.
You mean, you tried setting Stream selection to manual in the InputStream Adaptive settings? That will just pass all the qualities/bitrates through, and you can switch between them as different video tracks by calling up the OSD during playback. (Unfortunately it defaults to the lowest one.)
Alternatively, you could keep it Auto, but set the Minimum bandwidth to something higher. 4200000 bps would get you the highest quality MLB stream, I think.
If you really want to selectively disable InputStream Adaptive, or toggle a setting in it, I did it by launching Kodi with a batch file. So when I clicked the MLB batch file, it first copied the InputStream Adaptive settings file into place, then launched Kodi, then copied back a default version of that settings file afterward.
It would be nice to see more customization options in InputStream Adaptive, now that it is so widely used. You could submit this feature request at its Github:
Audio streams working perfectly with OSMC nightlies and Kodi 18.
h
I guess nobody else is having buffering issues.. I don't get this damn thing. When I first installed Kodi v18 64-bit, it was so good for a month, better and faster than Kodi v17 32-bit.. Now it's complete shit.
Does anyone have a solution for blocking commercial while watching in browser?
