Full Version: MLB.TV®
Just installed the latest version and I can't get everything to work however no live games are streaming in HD. Sometimes I'll get a highlight in 720p but all the live games are streaming in 960x540. Tried on multiple PC's and its the same thing. Is this happening to anyone else? What do I need to do to get it in HD?
Just curious if it is working for anyone else. For me when I click on a game, then "catch up" or "live," nothing happens.
Archived games working. Just tried one. SD only. Catchup didn't work for me last year.
(2020-07-23, 17:06)Crap Yeah Wrote: [ -> ]Just curious if it is working for anyone else. For me when I click on a game, then "catch up" or "live," nothing happens.
Try a replay from yest game. If there are no live games there is nothing to catch up
(2020-07-23, 17:13)Dixon Butz Wrote: [ -> ]Archived games working. Just tried one. SD only. Catchup didn't work for me last year.
Have u gotten any games to stream in 720p HD? Best I get it 960x540.
This is most likely because inputstream adaptive is set to automatically detect screen size / network speeds. To override this you can go to: Addons > My Addons >VideoPlayer Inputstream > Inputstream Adaptive
Configure Min bandwidth to be (10,000,000)
- or -
Set stream selection to Manual Video and then you can change it while the video is playing through video settings
The first option is set once and you're done but gives you less flexibility when the network bandwidth dips.
Setting Min to 10,000,000 makes 720 work again
Not getting email replies. Going to change eamail to gmail.
(2020-07-23, 18:58)eracknaphobia Wrote: [ -> ]This is most likely because inputstream adaptive is set to automatically detect screen size / network speeds. To override this you can go to: Addons > My Addons >VideoPlayer Inputstream > Inputstream Adaptive
- or -
This worked! Thank you very much!
@Dixon Butz - the avatar you had is against our forum rules (wiki) and has been removed.
Please do not use such images again.
Here, it doesn't work. Version 2019.3.31
Quote:
File "/home/xbmc/.kodi/addons/script.module.requests/lib/requests/sessions.py", line 522, in request
                                                resp = self.send(prep, **send_kwargs)
                                              File "/home/xbmc/.kodi/addons/script.module.requests/lib/requests/sessions.py", line 642, in send
                                                r = adapter.send(request, **kwargs)
                                              File "/home/xbmc/.kodi/addons/script.module.requests/lib/requests/adapters.py", line 513, in send
                                                raise SSLError(e, request=request)
                                            SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661)
19:30:58 T:139966672959488   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.mlbtv/?mode=104&name=%5BCOLOR%3DFFF69E20%5DCompleted+Early%3A+Rain%5B%2FCOLOR%5D+Yankees+at+Nationals&game_pk=630851&stream_date=2020-07-23]
19:30:58 T:139965556467456   ERROR: EXCEPTION: XBMC is not playing any file
Neither archived games or current ones work for me. I click on the game, it very briefly shows a loading wheel and then nothing happens.
I'm curious whether a kodi skin could be messing with things, I'm currently using Arctic Zephyr 2.
(2020-07-25, 01:24)Crap Yeah Wrote: [ -> ]
Just switched back to original OSMC skin and same thing happened. Any ideas would be appreciated!
2020-07-24 18:39:40.607 T:2764468432   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.KeyError'>
                                            Error Contents: 'access_token'
                                              File "/home/pi/.kodi/addons/plugin.video.mlbtv/main.py", line 42, in <module>
                                                stream_select(game_pk)
                                              File "/home/pi/.kodi/addons/plugin.video.mlbtv/resources/lib/mlb.py", line 230, in stream_select
                                                stream_url, headers = account.get_stream(content_id[n-1])
                                              File "/home/pi/.kodi/addons/plugin.video.mlbtv/resources/lib/account.py", line 122, in get_stream
                                                auth, url = self.get_playback_url(content_id)
                                              File "/home/pi/.kodi/addons/plugin.video.mlbtv/resources/lib/account.py", line 97, in get_playback_url
                                                auth = self.access_token()
                                              File "/home/pi/.kodi/addons/plugin.video.mlbtv/resources/lib/account.py", line 88, in access_token
                                                % self.media_entitlement()
                                              File "/home/pi/.kodi/addons/plugin.video.mlbtv/resources/lib/account.py", line 69, in media_entitlement
                                                self.login()
                                              File "/home/pi/.kodi/addons/plugin.video.mlbtv/resources/lib/account.py", line 54, in login
                                                login_token = r.json()['access_token']
                                            KeyError: 'access_token'
possibly a login problem?
(2020-07-25, 03:43)chalbersma Wrote: [ -> ]2020-07-24 18:39:40.607 T:2764468432   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                self.login()
Found my issue : https://github.com/eracknaphobia/plugin....tv/pull/30
Workaround for others using email alias, replace the + with %2B.
I also have this behavior. Same as WHamilton, the log points to an SSH issue. Not sure how to fix this, any ideas?
2020-07-24 16:40:07.445 T:1547633520  NOTICE: Opening stream: 1 source: 256
2020-07-24 16:40:07.453 T:1606382448  NOTICE: Librespot: pactl 1
2020-07-24 16:40:07.865 T:1170789232   ERROR: CCurlFile::FillBuffer - Failed: SSL peer certificate or SSH remote key was not OK(60)
2020-07-24 16:40:07.865 T:1170789232   ERROR: CCurlFile::Open failed with code 0 for https://playback.svcs.mlb.com/silk/event...17505f9410:
2020-07-24 16:40:07.868 T:1170789232   ERROR: AddOnLog: InputStream Adaptive: Cannot download https://playback.svcs.mlb.com/silk/event...17505f9410
2020-07-24 16:40:07.875 T:1547633520 WARNING: OpenStream - Unsupported stream 1. Stream disabled.
