(2023-03-30, 22:25)gnrtool82 Wrote: [ -> ]Everything seems to work great so far. Had some early user error seemingly resolved. Cheers
Is that with version 20 of Kodi, by any chance?
(2023-03-30, 20:16)DCosta27 Wrote: [ -> ]It does work great as always, but gamechanger seems to be needing an update to work.
Yes, if anyone else needs the Game Changer fix before it is updated in the official repo, you can download and install the addon ZIP file from here:
https://github.com/tonywagner/plugin.vid...v2023.3.28
(2023-03-31, 00:53)hhqjdaasc Wrote: [ -> ]Is that with version 20 of Kodi, by any chance?
I have been using it with Kodi 20. Any specific problems you are having?
A big supporter of the MLB-TV add-on! I recently installed it on my Fire Stick, but when I try to pick a stream I get an error. I included the log below. Is anyone able to take a look and let me know how to troubleshoot this one? Thanks for all the help in advance.
https://paste.kodi.tv/ivehenujax
(2023-04-05, 06:04)sanu_456 Wrote: [ -> ]A big supporter of the MLB-TV add-on! I recently installed it on my Fire Stick, but when I try to pick a stream I get an error. I included the log below. Is anyone able to take a look and let me know how to troubleshoot this one? Thanks for all the help in advance.
ivehenujax (paste)
Thanks for the log. I think you may need to enable the InputStream Adaptive addon. If it hasn't moved, it should be in the official Kodi Add-on repository, under "VideoPlayer InputStream."
I am having problems with the MLB.TV addon on my daughter's system. It is running LibreELEC and Kodi on a Raspberry Pi4 and it is VERY slow. When she tries to watch a game, it takes forever for each option to come up. Then when the game should play it sits for a long time and then she gets an error that the stream can't play. The other features of Kodi that she has tried work fine.
https://paste.kodi.tv/asimipinos.kodi
Never mind. I re-installed the addon and it is working now. Cheers.
Not every spring training game is showing up on Kodi 18. It cuts off after the 1 PM games.
Not getting live streams on Omega. Is it a known issue?
tpaniaki This should be fixed in version 2024.3.29
Not getting any 720P streams. Who is?
(2024-03-30, 14:07)eracknaphobia Wrote: [ -> ]@tpaniaki This should be fixed in version 2024.3.29
Stream now start but crash after a while. Posted a
ticket. Stand by, thanks.
How can we get 720 streams? Certain versions or something? Anyone?
These feeds are the best as they have no ads.
(2024-04-03, 01:36)Dixon Butz Wrote: [ -> ]How can we get 720 streams? Certain versions or something? Anyone?
I'm getting 720p60 streams with no special configuration. (Default "Best Available" Stream Quality in MLBTV add-on settings, and default InputStream Adaptive version 20.3.18 add-on settings too.)
You can set InputStream Adaptive "Stream selection type" to "Ask quality" and it will prompt you to choose. Or under "Adaptive (default)", you can set a high initial bandwidth and minimum bandwidth to "force" it to select the best stream automatically.
If you still have trouble, share those settings and a complete debug log.
