2016-11-02, 20:01
New movies does only show recently added movies. Not sure why there are no available on your db. Does this also happens if you select random movies for that widgets?
(2016-10-18, 06:45)xhaggi Wrote: [ -> ]To get more tiles for movies (4 tiles) you could switch to classic home in skin settings > Home > Use classic homeThanks, I was aware of the classic home skin but to be honest don't like it's overall design. Since the "Applications" tab consists of tiles only which all can be customized, I was wondering if you can't just have an option in the settings to use the same for other tabs as well? Code/Logic must be there from the "Applications" tab, so I believe it could be reused.
(2016-11-02, 19:12)Dakkar Wrote: [ -> ]Like if the skin was not able to show any content even if the counter on the left shows that actually I have 1764 movies.
msgctxt "#31922"
msgid "Cancel"
msgstr "Cancel"
msgctxt "#31923"
msgid "Close"
msgstr "Close"
msgctxt "#31924"
msgid "View Options"
msgstr "View Options"
(2016-12-31, 12:48)3500 Wrote: [ -> ]Kodi 17 RC is released.
and i use the latest version of this skin, and when i open my Kodi and this is happen
(2016-12-31, 12:48)3500 Wrote: [ -> ]and why the Homescreen using Classic Style default?
(2016-12-09, 20:59)JoshDi Wrote: [ -> ]I noticed a bug in the Xperience1080 language file for Kodi 16 (Jarvis) and Kodi 17 (Krypton).
In the userdir file: \AppData\Roaming\kodi\addons\skin.xperience1080\language\English (US)\strings.po, the "Close" string should be listed as "Close" and not "Cerrar"
Line 845 of the file should be msgstr "Close", not "Cerrar"
Thank you!
(2016-12-31, 13:30)xhaggi Wrote: [ -> ](2016-12-31, 12:48)3500 Wrote: [ -> ]Kodi 17 RC is released.
It looks like your language file is broken. For me everything works like it does before.
I've dropped the classic home screen and merged some of the visuals and animations into the default. I've spend to much time to maintain both the default and classic home screen over the last year.
(2016-12-31, 19:23)3500 Wrote: [ -> ](2016-12-31, 13:30)xhaggi Wrote: [ -> ](2016-12-31, 12:48)3500 Wrote: [ -> ]Kodi 17 RC is released.
i've recently updated Kodi from RC1 to RC2 and updated the skin too in github Xperience1080 (master) and the problem still same
and how i can fix this problem, because before that i used Jarvis and never had a problem like this
& Happy NewYear
