2016-03-18, 04:51
2016-03-18, 09:06
2016-03-18, 13:27
http://forum.kodi.tv/showthread.php?tid=...pid2271090
new dialog is created-merg from few dialog,need some time to create all this in to one dialog.
I'll start to change settings for 1080i skin AeonmQ6 (KRYPTON VERSION)
https://github.com/Angelinas1/skin.aeonmq6.1080
These dialogs have been merged into DialogSettings.xml
•DialogAudioDSPSettings.xml
•DialogContentSettings.xml
•DialogMediaFilter.xml
•DialogNetworkSetup.xml
•DialogPeripheralSettings.xml
•DialogPVRTimerSettings.xml
•LockSettings.xml
•ProfileSettings.xml
•VideoOSDSettings.xml
DialogMusicInfo.xml
•replaces DialogAlbumInfo.xml
•replaces DialogSongInfo.xml
DialogNotification.xml
•replaces DialogKaiToast.xml
DialogConfirm.xm
•replaces DialogOK.xml
•replaces DialogProgress.xml
•replaces DialogYesNo.xml
DialogVolumeBar.xml
•replaces DialogMuteBug.xml
•LockSettings.xml
DialogMusicInfo.xml
DialogConfirm.xm
DialogVolumeBar.xml
2016-03-18, 14:52
(2016-03-18, 13:27)Angelinas Wrote: [ -> ]http://forum.kodi.tv/showthread.php?tid=...pid2271090
•LockSettings.xml
DialogMusicInfo.xml
DialogConfirm.xm
DialogVolumeBar.xml
Will keep up with your progress, if you have any test material, i am will to test..
2016-03-21, 22:43
@Angelinas
Any progress on Kodi Krypton support, my current configuration is very buggy and slow.
2016-03-23, 14:27
(2016-03-21, 22:43)movie78 Wrote: [ -> ]@Angelinas
I tried removing the texture and rezipping, install from zip but get error. Any help would be greatly helpful.
2016-03-23, 14:47
(2016-03-23, 14:27)Repoman Wrote: [ -> ]I tried removing the texture and rezipping, install from zip but get error. Any help would be greatly helpful.
Download skin from zip(with changes)......My version from GitHub
unzip and do some changes...
-Media folder with all.png images.(not *.xbt) unpack texture.xbt file in media folder
-change addon.xml (like in my post)
<?xml version="1.0" encoding="UTF-8"?>
<addon id="skin.aeonmq6" version="3.3.0" name="Aeon MQ 6" provider-name="MarcosQui">
<requires>
<import addon="xbmc.gui" version="5.11.0"/>
</requires>
<extension point="xbmc.gui.skin" debugging="false">
<res width="1280" height="720" aspect="16:9" default="true" folder="720p"/>
</extension>
<extension point="xbmc.addon.metadata">
<summary lang="en_GB">AeonMQ6. (Kodi's skin)</summary>
</extension>
</addon>
-DialogAlbumInfo.xml in DialogMusicInfo.xml
-DialogYesNo.xml in DialogConfirm.xml
See how you create this new dialog (you can copy from default kodi skin)
•LockSettings.xml
DialogVolumeBar.xml
And finaly rezipping to new file....
2016-03-23, 14:54
(2016-03-23, 14:47)Angelinas Wrote: [ -> ](2016-03-23, 14:27)Repoman Wrote: [ -> ]I tried removing the texture and rezipping, install from zip but get error. Any help would be greatly helpful.
-rename two dialogsCode:<?xml version="1.0" encoding="UTF-8"?>
<requires>
</requires>
</extension>
</extension>
</addon>
•LockSettings.xml
DialogVolumeBar.xml
So we should add all these Dialog
Quote: •DialogAudioDSPSettings.xmlinto one XML = DialogSettings.xml ?
•LockSettings.xml
2016-03-27, 23:02
<requires>
</requires>
</extension>
</extension>
</addon>
•LockSettings.xml
DialogVolumeBar.xml
Angelinas, I tried time after time with no success to install from zip for Krypton. Could you please zip a working copy for download for Krypton?
2016-03-28, 15:57
2016-03-28, 16:39
2016-03-30, 12:20
Hi Angelinas,
It would be grat if you can provide these changes in a zip. It would be easier for us to install this instead of doing all changes on our own again.
2016-03-30, 12:35
I didnt start to change for Krypton, this thread isnt mine....Krypton version will be 1080i ...I dont want to change for krypton, lot of my changing code depend of script helper..
This script doesent work for Krypton version.
2016-04-02, 14:35
Hi at all
@Angelinas, Great work for this skin super customizable!
I encounter an important limitation with selection of fanart background for smart playlist of movies.
Why not exists the possibility to use fanart colecction in smart playlist of movies (with same filters for images,I mean) same that movies in general? Maybe isn't possible?
An option that I have used has been, to create a directory with the images of the films that are filtered in smart playlist.
The disadvantage is that it is an action manual and needs a maintenance
Greetings
PD:Sorry, The question is for version Jarvis, I copied the question in the version Jarvis too
Greetings
