Maybe you could tease us with the date?
(2016-06-10, 16:44)Ned Scott Wrote: [ -> ]I can't update anyone yet, but I can tease you: The Play 2 is now even better than originally announced.
So are we looking at an extra €40 to €60 now for this newer than new version o_O
Too many teases and release date rumors. Think we need some solid info. from WeTek
Yes, that would be even better.
Hello guys, specially the DVB device is being really worked on, we are rewriting completely the DVB Player, I will post some screenshot but consider that for the final build we will also try different icons and different accent colors.
http://imgur.com/a/RNE4K
As you can see, in the settings you will get a remote friendly interface whenever possible.
I don't have picons but if you do (and you will have the option to download it from our web backend, or install yours from a zip pack), you will get them in both main OSD and channel list.
The PVR now will not require that the Theater is running, it will be handled by a background service and while recording you will see a "REC" notification in WeTek Launcher's notification area.
The ROM will have support for mounting multiple CIFS/NFS shares (you can see in one of my screenshots I have a network share mounted).
If the device is taking longer to reach the shelves is because we are trying to improve it every day.
Very good job @
WeTek devs . It looks amazing :-) if it is possible add also some info from oscam if it is installed (ca, prov, source ...) would be nice
For obvious reason oscam is not pre-installed but you can use OStool (or if you wanna get your hands dirty modify a start script and auto run an oscam binary), I use oscam since I share my TivuSat card to all my devices at home, it is working
Good to know :-) keep good working
What is about new amlogic s905x cpu?Wetek will have it,4K VP9 or HDR?
905x dont have ts imput, neither HDR.
S905D should be the Verimatrix certified if I remember correctly
What about the price of new device? Can you trade us in this regard also so that it is a deciding factor for some whether to choose stone other device or is it worth the wait will be better to know in advance...
Thanks for some easy of hope atleast....
I will ask because it's a kind of information that is out of my league
