Full Version: Failed to load
My music add on Shoutcast and Radio both had failed to load errors when trying to play 181.fm. Here is the log:
15:27:10 T:7416 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:27:10 T:7416 NOTICE: -----------------------------------------------------------------------
15:27:10 T:7416 NOTICE: Starting Kodi (16.1-RC1 Git:20160306-46d1480). Platform: Windows NT x86 32-bit
15:27:10 T:7416 NOTICE: Using Release Kodi x32 build
15:27:10 T:7416 NOTICE: Kodi compiled Mar 6 2016 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
15:27:10 T:7416 NOTICE: Running on MSI Z1-7641 with Windows 10, kernel: Windows NT x86 64-bit version 10.0
15:27:10 T:7416 NOTICE: Host CPU: AMD FX™-8100 Eight-Core Processor, 8 cores available
15:27:10 T:7416 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
15:27:10 T:7416 NOTICE: Running with restricted rights
15:27:10 T:7416 NOTICE: Aero is enabled
15:27:10 T:7416 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
15:27:10 T:7416 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
15:27:10 T:7416 NOTICE: special://masterprofile/ is mapped to: C:\Users\Alfred\AppData\Roaming\Kodi\userdata
15:27:10 T:7416 NOTICE: special://home/ is mapped to: C:\Users\Alfred\AppData\Roaming\Kodi\
15:27:10 T:7416 NOTICE: special://temp/ is mapped to: C:\Users\Alfred\AppData\Roaming\Kodi\cache
15:27:10 T:7416 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
15:27:10 T:7416 NOTICE: Local hostname: Backroom
15:27:10 T:7416 NOTICE: Log File is located: C:\Users\Alfred\AppData\Roaming\Kodi\kodi.log
15:27:10 T:7416 NOTICE: load settings...
15:27:10 T:7416 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
15:27:10 T:7416 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
15:27:10 T:7416 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:27:10 T:7416 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:27:10 T:7416 NOTICE: Default DVD Player: dvdplayer
15:27:10 T:7416 NOTICE: Default Video Player: dvdplayer
15:27:10 T:7416 NOTICE: Default Audio Player: paplayer
15:27:10 T:7416 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:27:10 T:7416 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:27:10 T:7416 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:27:10 T:7416 NOTICE: Loaded playercorefactory configuration
15:27:10 T:7416 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:27:10 T:7416 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:27:10 T:8484 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "1 - ASUS VH238 (AMD High Definition Audio Device)" seems to be not supported.
15:27:10 T:8484 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "1 - ASUS VH238 (AMD High Definition Audio Device)" seems to be not supported.
15:27:10 T:8484 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_EAC3" on device "1 - ASUS VH238 (AMD High Definition Audio Device)" seems to be not supported.
15:27:10 T:8484 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTS" on device "1 - ASUS VH238 (AMD High Definition Audio Device)" seems to be not supported.
15:27:10 T:8484 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AC3" on device "1 - ASUS VH238 (AMD High Definition Audio Device)" seems to be not supported.
15:27:10 T:8484 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_LPCM" on device "1 - ASUS VH238 (AMD High Definition Audio Device)" seems to be not supported.
15:27:10 T:8484 NOTICE: Found 2 Lists of Devices
15:27:10 T:8484 NOTICE: Enumerated DIRECTSOUND devices:
15:27:10 T:8484 NOTICE: Device 1
15:27:10 T:8484 NOTICE: m_deviceName : {0C8AE73C-CA23-4CB7-B7E0-F93921AB31D3}
15:27:10 T:8484 NOTICE: m_displayName : Speakers - Speakers (High Definition Audio Device)
15:27:10 T:8484 NOTICE: m_displayNameExtra: DIRECTSOUND: Speakers (High Definition Audio Device)
15:27:10 T:8484 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:27:10 T:8484 NOTICE: m_channels : FL,FR
15:27:10 T:8484 NOTICE: m_sampleRates : 44100
15:27:10 T:8484 NOTICE: m_dataFormats : AE_FMT_FLOAT
15:27:10 T:8484 NOTICE: Device 2
15:27:10 T:8484 NOTICE: m_deviceName : {19B774DD-E246-4856-9DE8-19A9108A1990}
15:27:10 T:8484 NOTICE: m_displayName : HDMI - 1 - ASUS VH238 (AMD High Definition Audio Device)
15:27:10 T:8484 NOTICE: m_displayNameExtra: DIRECTSOUND: 1 - ASUS VH238 (AMD High Definition Audio Device)
15:27:10 T:8484 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:27:10 T:8484 NOTICE: m_sampleRates : 48000
15:27:10 T:8484 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
15:27:10 T:8484 NOTICE: Device 3
15:27:10 T:8484 NOTICE: m_deviceName : default
15:27:10 T:8484 NOTICE: m_displayName : default
15:27:10 T:8484 NOTICE: Enumerated WASAPI devices:
15:27:10 T:8484 NOTICE: m_displayNameExtra: WASAPI: Speakers (High Definition Audio Device)
15:27:10 T:8484 NOTICE: m_sampleRates : 192000,96000,48000,44100
15:27:10 T:8484 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
15:27:10 T:8484 NOTICE: m_displayNameExtra: WASAPI: 1 - ASUS VH238 (AMD High Definition Audio Device)
15:27:10 T:8484 NOTICE: m_sampleRates : 192000,176400,96000,88200,48000,44100,32000
15:27:10 T:8484 NOTICE: m_dataFormats : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
15:27:10 T:7416 NOTICE: Running database version Addons20
15:27:10 T:7416 NOTICE: ADDONS: Using repository repository.xbmc.org
15:27:10 T:7416 NOTICE: Found screen: Generic PnP Monitor on AMD Radeon R7 200 Series, adapter 0.
15:27:10 T:7416 NOTICE: Primary mode: [email protected] 60.00 - Full Screen
15:27:10 T:7416 NOTICE: Additional mode: [email protected] 75.00 - Full Screen
15:27:10 T:7416 NOTICE: Additional mode: [email protected] 72.00 - Full Screen
15:27:10 T:7416 NOTICE: Additional mode: [email protected] 67.00 - Full Screen
15:27:10 T:7416 NOTICE: Additional mode: [email protected] 60.00 - Full Screen
15:27:10 T:7416 NOTICE: Additional mode: [email protected] 59.94 - Full Screen
15:27:10 T:7416 NOTICE: Additional mode: [email protected] 29.97i - Full Screen
15:27:10 T:7416 NOTICE: Additional mode: [email protected] 30.00i - Full Screen
15:27:10 T:7416 NOTICE: Additional mode: [email protected] 50.00 - Full Screen
15:27:10 T:7416 NOTICE: Additional mode: [email protected] 25.00i - Full Screen
15:27:10 T:7416 NOTICE: Previous line repeats 2 times.
15:27:10 T:7416 NOTICE: Additional mode: [email protected] 56.00 - Full Screen
15:27:10 T:7416 NOTICE: Additional mode: [email protected] 70.00 - Full Screen
15:27:10 T:7416 NOTICE: Checking resolution 15
15:27:10 T:7416 NOTICE: Running database version ViewModes6
15:27:10 T:7416 NOTICE: Running database version Textures13
15:27:10 T:7416 NOTICE: Running database version MyMusic56
15:27:10 T:7416 NOTICE: Running database version MyVideos99
15:27:10 T:7416 NOTICE: Running database version TV29
15:27:10 T:7416 NOTICE: Running database version Epg11
15:27:10 T:7416 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
15:27:10 T:7416 NOTICE: ActiveAE DSP - starting
15:27:10 T:7416 NOTICE: initialize done
15:27:11 T:7416 NOTICE: Running the application...
15:27:11 T:7416 NOTICE: starting upnp client
15:27:11 T:7416 NOTICE: starting upnp renderer
15:27:11 T:6620 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
15:27:11 T:6620 NOTICE: UDP: Listening on port 9777
15:27:15 T:4744 NOTICE: [xbmcswift2] Request for "/" matches rule for function "show_root_menu"
15:27:16 T:1476 NOTICE: [xbmcswift2] Request for "/stations/my/" matches rule for function "show_my_stations"
15:27:16 T:1476 NOTICE: [plugin.audio.radio_de] __add_stations started with 1 items
15:27:17 T:6444 NOTICE: [xbmcswift2] Request for "/station/2977" matches rule for function "get_stream_url"
15:27:17 T:6444 NOTICE: [plugin.audio.radio_de] get_station_by_station_id started with station_id=2977
15:27:17 T:6444 NOTICE: [plugin.audio.radio_de] __api_call started with path=broadcast/getbroadcastembedded, param={'broadcast': '2977'}
15:27:17 T:6444 NOTICE: [plugin.audio.radio_de] __urlopen opening url=http://rad.io/info/broadcast/getbroadcastembedded?broadcast=2977
15:27:17 T:6444 NOTICE: [plugin.audio.radio_de] get_stream_url result: http://relay.181.fm:8032/
15:27:27 T:7416 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for http://relay.181.fm:8032/
15:27:47 T:7416 ERROR: Previous line repeats 1 times.
15:27:47 T:7416 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
15:27:47 T:7416 ERROR: CCurlFile::Open failed with code 0 for http://relay.181.fm:8032/
15:27:47 T:7416 ERROR: XFILE::CFileCache::Open - failed to open source <http://relay.181.fm:8032/>
15:27:47 T:7416 ERROR: DVDPlayerCodec::Init: Error opening file http://relay.181.fm:8032/
15:27:47 T:7416 ERROR: CAudioDecoder: Unable to Init Codec while loading file http://relay.181.fm:8032/
15:27:47 T:7416 WARNING: PAPlayer::QueueNextFileEx - Failed to create the decoder
15:27:47 T:7416 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.audio.radio_de/station/2977]
15:28:15 T:7416 NOTICE: Storing total System Uptime
15:28:15 T:7416 NOTICE: Saving settings
15:28:15 T:7416 NOTICE: stop all
15:28:15 T:7416 NOTICE: stop player
15:28:15 T:7416 NOTICE: ES: Stopping event server
15:28:15 T:7416 NOTICE: stopping upnp
15:28:16 T:6620 NOTICE: ES: UDP Event server stopped
15:28:16 T:7416 NOTICE: stop sap announcement listener
15:28:16 T:7416 NOTICE: clean cached files!
15:28:16 T:7416 NOTICE: unload skin
15:28:16 T:7416 NOTICE: stopped
15:28:16 T:7416 NOTICE: destroy
15:28:16 T:7416 NOTICE: closing down remote control service
15:28:16 T:7416 NOTICE: unload sections
15:28:16 T:7416 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:28:16 T:7416 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
15:28:16 T:7416 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
15:28:16 T:7416 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
15:28:16 T:7416 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
15:28:16 T:7416 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
15:28:16 T:7416 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
15:28:16 T:7416 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
15:28:16 T:7416 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
15:28:16 T:7416 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
15:28:16 T:7416 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
15:28:16 T:7416 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
15:28:16 T:7416 NOTICE: application stopped...
15:28:16 T:7416 ERROR: dllFreeLibrary - Invalid hModule specified
Please do not post logs directly into the thread as text, use an uploader service such as xbmclogs or pastebin.
