2016-03-09, 04:06
Pages: 1 2
2016-03-09, 09:31
Do you have your local movies library set up? They should populate from there.
2016-03-09, 12:11
Is there a way to increase the number of moves in the 'recently added movies' list?
2016-03-09, 13:08
How to set up local MOVIES library Thank you
2016-03-09, 13:19
2016-03-09, 17:51
It will not let me add movies it will let me add video Is it because they are on a hard drive or because they are rips Thank you
2016-03-09, 18:25
Read the link.
If you have a folder containing films add it as a source in videos.
Set the content to Movies.
Scan.
And you have Movies.
Rips are fine - as long as they're named properly. Again, have a read of the wiki, have a read around here.
Scan.
2016-03-11, 18:20
Hello to whom it may concern I think what the problem is I have a share error Anyone have any ideas or fix if possible Thank you in advance
2016-03-11, 18:25
Why do you think you have a 'share issue'? Can you not see the video files in kodi?
If not ... start a new thread - nobody will look in here for share issues.
Describe the problem in detail. Where's the share? What happens when you try to connect?
Post a debug log (see wiki).
2016-03-12, 00:15
Hello there the reason I think it's a share problem is because when trying to get to library my Hard Disk does'nt show although I can play my rips outside of library I thought I was doing the right thing by keeping it in the thread I would like to have a nice library metadata but it does'nt seem to be working out thanking you
2016-03-12, 00:17
If you can play the files then you can access the share.
Are your films all in 1 folder?
Is that folder one of your sources in 'Videos'?
What happens when you try to set content on that (or any) folder?
2016-03-12, 01:27
It keeps telling me it timed out
2016-03-12, 01:34
You can play the files in a folder.
But it times out if you try to set content on the same folder.
Is that right? Or have I misunderstoood?
I've never come across that - a debug log (see the wiki) might shed some light.
2016-03-12, 05:03
(2016-03-09, 12:11)deaded Wrote: [ -> ]Is there a way to increase the number of moves in the 'recently added movies' list?
Yes, that's pretty easy.
You need to edit / create the AdvancedSettings.xml (wiki) file, take a look at the recentlyaddeditems tag.
If you don't already have an advancedsettings.xml you could just cut & paste this:
<advancedsettings>
<videolibrary>
<recentlyaddeditems>35</recentlyaddeditems> <!-- number of recently added items. Defaults to 25 -->
</videolibrary>
</advancedsettings>
.. change the number (35) to anything you want like 9999.
2016-03-12, 06:14
(2016-03-12, 05:03)Gothicawakening Wrote: [ -> ](2016-03-09, 12:11)deaded Wrote: [ -> ]Is there a way to increase the number of moves in the 'recently added movies' list?
Code:<advancedsettings>
<videolibrary>
</videolibrary>
</advancedsettings>
Thanks Goth!! That's exactly what I was looking for! I'll try it out this weekend
Pages: 1 2
