Full Version: skin.estuary.midraal
Pages: 1 2
this is just a quick edit to get the skin to use script.skinshortcuts for the menus and widgets. it looks the same but you can change the menus and widgets
download
edit: changed screenshot
Took you long enough...
More seriously - it's amazing how quick that was. I'll have to have a play now.
Excellent, thanks for the support.
I think unfortunately this is going to be out of date very soon, but nice to see its possible for us who like to customize our menus
Yes, thank you! Will be using this when Krypton reaches beta for sure.
Hi just trying this out might be a bit of a silly question but how do you get to add addon's menu? cheers
you'll need to add a link to it in your menu or submenu
ok thanks just thought I was going blind or mad or both lol, I know it's early days but do you intend to further develop this skin? cheers
it was more of a quick fix to show adding custom menus isn't that hard, but i'll probably do the fix again once the skin has reached a stable point
How do you add this MOD ?
Just download from the link in the first post and install from zip in kodi - addons
I have do this, entire integration in skin settings.
(2016-03-15, 13:14)Guilouz Wrote: [ -> ]I have do this, entire integration in skin settings.
yes please Wink
I need to fix some stuff and I will share it.
(2016-03-15, 21:24)Guilouz Wrote: [ -> ]I need to fix some stuff and I will share it.
Big Grin thanks
(2016-03-15, 21:35)rsoares Wrote: [ -> ]
Big Grin thanks
If you can please put type of widget square,and the addons video fix de missing poster Wink
thanks
Pages: 1 2
