2016-03-09, 18:14
Hello,
First thanks for this great plugin, I'm using it at home on a raspberry Pi 2 with a dreambox 500HD, it's working very well!! When we have a good connection to the box!
My problem is that I wanted to use the plugin over internet, so I use a linux server to transcode the stream of my DM500HD :
DM500HD --> Linux Server --> Raspi (Running Kodi)
Add-on ask for channels and everything to the linux server, and linux server transfer all http requests to DM500HD and when the command zap is received i start the stream using vlc :
cvlc -vvv --http-host=192.168.1.4 --http-port=8001 http://192.168.1.11/web/stream.m3u?ref=$CURRENT_SERVICE --sout "#transcode{scale=0.5}:http{mux=ps, dst=/$CURRENT_SERVICE}"
192.168.1.4 is my linux server
192.168.1.11 is the dreambox HD
$CURRENT_SERVICE is the service reference
(For now I'm only testing it on my local network)
When I change channel on Kodi the stream is started on the correct URL (I can check that it's working using vlc on another computer), but kodi does not seem to read the stream ....
Is there a problem for kodi reading this transcoded stream ?
PS : I checked that the PVR addon is configured with correct IP and correct streaming port
Thanks for any answer!
