Full Version: PVR/Radio: Informations missing if radio channel is a webstream
Pages: 1 2
hi,
i use mediaportal pvr backend for live-tv. with that backend its possible to add radio channels as web-streams. its simple: within mediaportal backend you add a new radio channel, give the channel a name and put in the stream-url. this works good within kodi. but the problem is the informations (artist + name of the song) is not displayed within kodi (not in fullscreen and also not on homescreen). but i know this informations are included within the stream (if i play the same streams with another music-addon (where its possible to add own radio stations/urls) the informations are there)).
can anyone help? is it a problem of the skin (confluence) or what can i do?
Yes confirm. It appears for a few seconds at startup. Then disappears
http://forum.kodi.tv/showthread.php?tid=291572
Have you enabled the "parse RDS data" in the settings? It's somewhere in there, can't remember where exactly.
Yes
Yes, alas, confirm this problem... It appears for a few seconds at startup. (in v16-Jarvis and v17-Krypton too).
How to fix the problem? other skins all works fine !
http://xbmc.ru/forum/attachment.php?atta...1474610361
The link requires a login so it's useless.
(2016-09-24, 10:48)negge Wrote: [ -> ]The link requires a login so it's useless.
Also works for other skins such as - Amber, AeonNox, Rapier, and other.
Chroma:
(2016-09-23, 08:07)negge Wrote: [ -> ]Have you enabled the "parse RDS data" in the settings? It's somewhere in there, can't remember where exactly.
i think that has nothing to do with "rds". "real" antenna radio has rds, but i talk about a webstream.
@onfreedom: it seems this is a bug or a missing feature. in every case this problem is skin related. please ask developer here: http://forum.kodi.tv/forumdisplay.php?fid=260
Maybe you need this. (Shameless plug for my add-on Rofl)
KODI v16, v17. Tested on various skins.
Metadata don't displayed.
Sometimes displayed text like "pvr.iptvsimple_7658736987.pvr"
In your stream media simply do not have the data. Try - http://live.radiorostov.ru:8000/rostovradio or http://5.39.71.159:8110/stream
i tested this on hundreds radio streams, that i know have data, for example SomaFM streams
Up
Screenshots above all radios.
all icecast not PVR !
(2016-09-26, 07:55)sudden Wrote: [ -> ]i tested this on hundreds radio streams, that i know have data, for example SomaFM streams
SomaFM not RDS this icecast -
Pages: 1 2
