2016-03-12, 01:35
You'll only see this one if you are running Mimic on OpenELEC. When opening OpenELEC settings in Mimic,The heading text is a very dark blue, which tends to become virtually invisible against the background. It makes it hard to see just what your'e doing even on a big-screen.
I've tried to eliminate the effect through the skin custom color picker and have tried different system section backgrounds, but can't eliminate the effect. The dialog looks fine under Aon Nox, so I'm assuming that the heading color is coming from Mimic, although I'm not sure where/how the parameter is being passed to the addon. I see this issue on Isengard, Jarvis and Krypton.
Here's a screenshot of Mimic in case you don't use OpenELEC:
http://imgur.com/7AUHou1
And a screenshot of the same dialog under Aon NOX:
http://imgur.com/fZ2N3V5
Is there a simple fix for this?
