Kodi and backing up skins and addons issuess i try to backup kodi with program called backup and deleted kodi then reinstalled it and the skins not there and addons or there but since skins not there it dont put them in the categorys can someone help
Thread moved to OS independent.
Is this the Jarvis version of Kodi? Since then the storage of skins etc has been moved to a different place within the file structure of the kodi (or .kodi) folder, which the back-up add-on doesn't account for as it's not written for Jarvis.
If you use the additional folders option within the add-on, you can back up the entire Kodi folder (it's one level higher than the
userdata (wiki) folder, if you need help in setting it up) and then everything will get captured.
