Full Version: Brief display of video feed, then VNSI-Error: cxSocket::read: read() error at 0/
I'm running everything out of Debian testing, which means:
VDR 2.2.0
Kodi 16.0
VNSI Plugin 1.11.15
All running on localhost.
vdr works fine when I test it with vdr-sxfe.
when I attempt to play anything via Kodi, this shows in the logs:
Mar 12 20:22:44 maple vdr: [2966] VNSI: Successfully found following device: 0xc528f0 (1) for receiving
Mar 12 20:22:44 maple vdr: [2966] VNSI: Successfully switched to channel 4 - OPB-HD Channel
Mar 12 20:22:44 maple vdr: [2966] VNSI: Started streaming of channel OPB-HD Channel (timeout 16960 seconds)
Mar 12 20:22:44 maple vdr: [2968] cLiveStreamer stream processor thread started (pid=2840, tid=2968, prio=high)
Mar 12 20:22:44 maple vdr: [2967] VNSI: VideoInput: no pat/pmt within timeout, falling back to channel pids
Mar 12 20:22:44 maple vdr: [2967] VNSI: Video Input - new pmt, attaching receiver
Mar 12 20:22:44 maple vdr: [2968] VNSI: Created stream for pid=49 and type=7
Mar 12 20:22:45 maple vdr: [2966] VNSI-Error: cxSocket::read: read() error at 0/4
Mar 12 20:22:45 maple vdr: [2968] VNSI: exit streamer thread
Mar 12 20:22:45 maple vdr: [2968] cLiveStreamer stream processor thread ended (pid=2840, tid=2968)
Mar 12 20:22:45 maple vdr: [2966] VNSI: LiveStreamer::Close - close
Mar 12 20:22:45 maple vdr: [2966] VNSI: close video input ...
Mar 12 20:22:45 maple vdr: [2966] VNSI: call retune ...
Mar 12 20:22:45 maple vdr: [2924] VNSI: Client with ID 1 seems to be disconnected, removing from client list
I don't know what packages are provided by Debian and you didn't even mention what version of vnsiserver you are running. Not much I can do with this info.
(2016-03-14, 08:20)FernetMenta Wrote: [ -> ]you didn't even mention what version of vnsiserver you are running. Not much I can do with this info.
Oops, I'm sorry. Debian testing includes vdr-plugin-vnsiserver 1.3.1, along with the versions above listed of the other packages.
Please pastebin full kodi debug log and sysleg with vdr logging level 3
