Attention!! Mallwarebytes antiransomeware just find kodi.exe unnistall.exe and the files i just downloaded from your server with criptolocker virus..
Please check you files on the server..
(2016-03-12, 17:41)iepuryla Wrote: [ -> ]Attention!! Mallwarebytes antiransomeware just find kodi.exe unnistall.exe and the files i just downloaded from your server with criptolocker virus..
You didn't mention which version or O/S file you downloaded, but this has been reported a few times, Avast doesn't have issue so I would suggest this is another false positive. But it's always healthy to scan downloads for viri, but a lof of the virus checkers will come back with errors on an executable. Always download DIRECTLY from trusted sites (This if the official Kodi site and can be trusted).
Suggestion: report this to Mallwarebytes, sounds like their routines might be in question.
