2016-03-13, 19:21
I have always used Kodi on a headless linux machine, which always worked like charm, when setting the video playback with turned on deinterlacing and proper video scaling methods, artefacts and tearing effects were never an issue.
For other reasons, however, I had to change from a server version ob ubuntu 15.10 to its desktop variant, using the unity 7 desktop environment, which relies on Composite. Starting Kodi in that environment produced a lot of tearing effects with the same settings as before.
After reading many entries across the forum, I tried to enable / disable the "Unredirect Fullscreen Windows" option using Compiz Config Settings Manager. Turning it off reduced the Tearing artefacts, but it produced a different effect, which was an occasionally blinking screen in Kodi when moving through the menu.
So I thought if it's possible to completely disable the Desktop environments Display postprocessing like Compiz and OpenGL for a fullscreen application like Kodi, and have the nice and flawless plain xserver running for that application, but the full Unity experience for the rest.
The best solution would be, if, on boot, tty1 would launch a standard xserver with Kodi running, while, lets say tty7, launches Ubuntus lightdm and logs me into a Unity session. How could I achieve that?
Thanks for the help.
