2016-03-15, 13:51
Hey guys,
i am running Raspbian Jessie on my RasPi 1. I have installed lirc and kodi and created a lircd.conf and a Lircmap.xml and placed them in the following directories:
lircd.conf: /etc/lirc
Lircmap.xml: /home/pi/.kodi/userdata
When i run irw all keys are recognized correctly. As soon as I try them in kodi some of them don't work anymore. I had a look into kodi.log but still cant fix the problem. I see, that the keys that are working (im my case left, right,up, down) seem to be converted into keyboard entries while the others (ok) dont't. Maybe you guys can help me out with that.
(Don't ask about the remote's name please )
08:39:06 T:3019935744 NOTICE: special://profile/ is mapped to: special://masterprofile/
08:39:06 T:3019935744 NOTICE: -----------------------------------------------------------------------
08:39:06 T:3019935744 NOTICE: Starting Kodi (15.2 Git:02e7013). Platform: Linux ARM 32-bit
08:39:06 T:3019935744 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
08:39:06 T:3019935744 NOTICE: Kodi compiled Dec 28 2015 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
08:39:06 T:3019935744 NOTICE: Running on Raspbian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 4.1.18+
08:39:06 T:3019935744 NOTICE: FFmpeg statically linked, version: 2.6.4-kodi-2.6.4-Isengard
08:39:06 T:3019935744 NOTICE: Host CPU: ARMv6-compatible processor rev 7 (v6l), 1 core available
08:39:06 T:3019935744 NOTICE: ARM Features: Neon disabled
08:39:06 T:3019935744 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
08:39:06 T:3019935744 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
08:39:06 T:3019935744 NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
08:39:06 T:3019935744 NOTICE: special://home/ is mapped to: /home/pi/.kodi
08:39:06 T:3019935744 NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
08:39:06 T:3019935744 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
08:39:06 T:3019935744 NOTICE: Local hostname: raspberrypi
08:39:06 T:3019935744 NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
08:39:10 T:3019935744 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property CanSuspend
08:39:10 T:3019935744 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property CanHibernate
08:39:10 T:3019935744 NOTICE: load settings...
08:39:11 T:3019928496 NOTICE: Thread FDEventMonitor start, auto delete: false
08:39:11 T:3019935744 NOTICE: Found 2 Lists of Devices
08:39:11 T:3019935744 NOTICE: Enumerated PI devices:
08:39:11 T:3019935744 NOTICE: Device 1
08:39:11 T:3019935744 NOTICE: m_deviceName : HDMI
08:39:11 T:3019935744 NOTICE: m_displayName : HDMI
08:39:11 T:3019935744 NOTICE: m_displayNameExtra:
08:39:11 T:3019935744 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
08:39:11 T:3019935744 NOTICE: m_channels : FL,FR
08:39:11 T:3019935744 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
08:39:11 T:3019935744 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
08:39:11 T:3019935744 NOTICE: Device 2
08:39:11 T:3019935744 NOTICE: m_deviceName : Analogue
08:39:11 T:3019935744 NOTICE: m_displayName : Analogue
08:39:11 T:3019935744 NOTICE: m_deviceType : AE_DEVTYPE_PCM
08:39:11 T:3019935744 NOTICE: m_sampleRates : 48000
08:39:11 T:3019935744 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
08:39:11 T:3019935744 NOTICE: Device 3
08:39:11 T:3019935744 NOTICE: m_deviceName : Both
08:39:11 T:3019935744 NOTICE: m_displayName : HDMI and Analogue
08:39:11 T:3019935744 NOTICE: Enumerated ALSA devices:
08:39:11 T:3019935744 NOTICE: m_deviceName : @
08:39:11 T:3019935744 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
08:39:11 T:3019935744 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000
08:39:11 T:3019935744 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
08:39:12 T:3019935744 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
08:39:12 T:3019935744 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<video>
<defaultplayer>dvdplayer</defaultplayer>
<defaultdvdplayer>dvdplayer</defaultdvdplayer>
</video>
<gui>
<algorithmdirtyregions>3</algorithmdirtyregions>
<nofliptimeout>0</nofliptimeout>
</gui>
<splash>false</splash>
<lookandfeel>
<enablerssfeeds>false</enablerssfeeds>
</lookandfeel>
<cputempcommand>sed -e 's/\([0-9]*\)[0-9]\{3\}.*/\1 C/' /sys/class/thermal/thermal_zone0/temp</cputempcommand>
<gputempcommand>/opt/vc/bin/vcgencmd measure_temp | sed "s,temp=\([0-9]*\)\.[0-9]'C,\1 C,"</gputempcommand>
</advancedsettings>
08:39:12 T:3019935744 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
08:39:12 T:3019935744 NOTICE: Default DVD Player: dvdplayer
08:39:12 T:3019935744 NOTICE: Default Video Player: dvdplayer
08:39:12 T:3019935744 NOTICE: Default Audio Player: paplayer
08:39:12 T:3019935744 NOTICE: Enabled debug logging due to GUI setting (2)
08:39:12 T:3019935744 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
08:39:12 T:3019935744 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
08:39:12 T:3019935744 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
08:39:12 T:3019935744 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
08:39:12 T:3019935744 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
08:39:12 T:3019935744 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
08:39:12 T:3019935744 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/mms/udp
08:39:12 T:3019935744 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
08:39:12 T:3019935744 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
08:39:12 T:3019935744 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
08:39:12 T:3019935744 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
08:39:12 T:3019935744 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
08:39:12 T:3019935744 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
08:39:12 T:3019935744 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
08:39:12 T:3019935744 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
08:39:12 T:3019935744 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
08:39:12 T:3019935744 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
08:39:12 T:3019935744 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
08:39:12 T:3019935744 NOTICE: Loaded playercorefactory configuration
08:39:12 T:3019935744 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
08:39:12 T:3019935744 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
08:39:12 T:3019935744 INFO: creating subdirectories
08:39:12 T:3019935744 INFO: userdata folder: special://masterprofile/
08:39:12 T:3019935744 INFO: recording folder:
08:39:12 T:3019935744 INFO: screenshots folder:
08:39:12 T:3010458544 NOTICE: Thread ActiveAE start, auto delete: false
08:39:12 T:2999972784 NOTICE: Thread AESink start, auto delete: false
08:39:12 T:2999972784 INFO: CActiveAESink::OpenSink - initialize sink
08:39:12 T:2999972784 DEBUG: CActiveAESink::OpenSink - trying to open device PI:HDMI
08:39:12 T:2999972784 DEBUG: DllBcm: Using omx system library
08:39:12 T:2999972784 DEBUG: SECTION:LoadDLL(libopenmaxil.so)
08:39:12 T:2999972784 DEBUG: Loading: libopenmaxil.so
08:39:12 T:2999972784 DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000008
08:39:12 T:2999972784 DEBUG: CAESinkPi:Initialize Format:15 Channels:2 Samplerate:44100 framesize:8 bufsize:17640 bytes/s=352800.00 dest=PI:HDMI
08:39:12 T:2941252528 NOTICE: Thread CRBPWorker start, auto delete: false
08:39:12 T:2999972784 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x32d1cd8
08:39:12 T:2999972784 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_render) - port(100), nBufferCountMin(1), nBufferCountActual(2), nBufferSize(17648), nBufferAlignmen(16)
08:39:12 T:2999972784 DEBUG: CActiveAESink::OpenSink - SinkPi Initialized:
08:39:12 T:2999972784 DEBUG: Output Device : HDMI
08:39:12 T:2999972784 DEBUG: Sample Rate : 44100
08:39:12 T:2999972784 DEBUG: Sample Format : AE_FMT_FLOAT
08:39:12 T:2999972784 DEBUG: Channel Count : 2
08:39:12 T:2999972784 DEBUG: Channel Layout: FL,FR
08:39:12 T:2999972784 DEBUG: Frames : 2205
08:39:12 T:2999972784 DEBUG: Frame Samples : 4410
08:39:12 T:2999972784 DEBUG: Frame Size : 8
08:39:13 T:2999972784 NOTICE: CAESinkPi:AddPackets Underrun (delay:0.00 frames:2205)
08:39:13 T:3019935744 NOTICE: Running database version Addons19
08:39:13 T:3019935744 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcpluff-arm.so)
08:39:13 T:3019935744 DEBUG: Loading: /usr/lib/kodi/system/libcpluff-arm.so
08:39:14 T:3019935744 INFO: ADDON: cpluff: 'Could not read plug-in directory /usr/lib/kodi/addons: No such file or directory'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in xbmc.audioencoder has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in kodi.audiodecoder has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in repository.xbmc.org has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in visualization.vortex has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in kodi.guilib has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.xbmc.builtin.wma has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in service.xbmc.versioncheck has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in skin.confluence has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in visualization.glspectrum has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in kodi.resource has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in script.module.pil has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.musicvideos.theaudiodb.com has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in xbmc.pvr has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.xbmc.builtin.aac has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_gb has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.local has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in xbmc.webinterface has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.last.fm has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.confluence has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in xbmc.python has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Plug-in xbmc.codec has been installed.'
08:39:14 T:3019935744 DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
08:39:14 T:3019935744 NOTICE: ADDONS: Using repository repository.xbmc.org
08:39:14 T:2932863920 NOTICE: Thread RemoteControl start, auto delete: false
08:39:14 T:2932863920 INFO: LIRC Process: using: /dev/lircd
08:39:14 T:2932863920 INFO: LIRC Connect: successfully started
08:39:14 T:2932863920 DEBUG: Thread RemoteControl 2932863920 terminating
08:39:14 T:3019935744 INFO: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
08:39:14 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Romanian QWERTY" successfully loaded
08:39:14 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Swedish QWERTY" successfully loaded
08:39:14 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Danish QWERTY" successfully loaded
08:39:14 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian ЙЦУКЕН" successfully loaded
08:39:14 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian АБВ" successfully loaded
08:39:14 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Norwegian QWERTY" successfully loaded
08:39:14 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew QWERTY" successfully loaded
08:39:14 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew ABC" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "English QWERTY" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "English AZERTY" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "English ABC" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian ЙЦУКЕН" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian АБВ" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian AZERTY" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian QWERTY" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Arabic QWERTY" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian ЯВЕРТЪ" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian АБВ" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "German QWERTZ" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Portuguese (Portugal) QWERTY" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Greek QWERTY" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Hungarian QWERTZ" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Spanish QWERTY" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Polish QWERTY" successfully loaded
08:39:15 T:3019935744 DEBUG: CKeyboardLayoutManager: keyboard layout "Turkish QWERTY" successfully loaded
08:39:15 T:3019935744 DEBUG: UDisks: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UDisks was not provided by any .service files
08:39:15 T:3019935744 DEBUG: DeviceKit.Disks: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.DeviceKit.Disks was not provided by any .service files
08:39:15 T:3019935744 DEBUG: Selected UDev as storage provider
08:39:15 T:3019935744 NOTICE: Raspberry PI firmware version: Feb 25 2016 14:25:47
Copyright (c) 2012 Broadcom
version dea971b793dd6cf89133ede5a8362eb77e4f4ade (clean) (release)
08:39:15 T:3019935744 NOTICE: ARM mem: 448MB GPU mem: 64MB MPG2:0 WVC1:0
08:39:15 T:3019935744 NOTICE: Config:
audio_pwm_mode=1
audio_sdm_mod_order=2
config_hdmi_boost=2
disable_auto_turbo=1
disable_commandline_tags=2
emmc_pll_core=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_force_hotplug=1
ignore_lcd=1
init_uart_clock=0x2dc6c0
overscan_bottom=48
overscan_left=48
overscan_right=48
overscan_top=48
pause_burst_frames=1
program_serial_random=1
temp_limit=85
device_tree=-
08:39:15 T:3019935744 DEBUG: DllBcm: Using omx system library
08:39:15 T:3019935744 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
08:39:15 T:3019935744 DEBUG: EGL initial desktop resolution 1920x1080 (1280x720) @ 60.00 - Full Screen (1.00)
08:39:15 T:3019935744 DEBUG: EGL get supported modes (1) = 16, prefer_group=1, prefer_mode=10
08:39:15 T:3019935744 DEBUG: EGL mode 0: 640x480 (640x480) @ 60.00 - Full Screen (1.00) :1
08:39:15 T:3019935744 DEBUG: EGL mode 1: 720x480 (720x480) @ 60.00 - Full Screen (0.89) :2
08:39:15 T:3019935744 DEBUG: EGL mode 2: 720x480 (720x480) @ 60.00 - Full Screen (1.19) :3
08:39:15 T:3019935744 DEBUG: EGL mode 3: 1280x720 (1280x720) @ 60.00 - Full Screen (1.00) :4
08:39:15 T:3019935744 DEBUG: EGL mode 4: 1920x1080 (1280x720) @ 60.00i - Full Screen (1.00) I:5
08:39:15 T:3019935744 DEBUG: EGL mode 5: 720x480 (720x480) @ 60.00i - Full Screen (0.89) I:6
08:39:15 T:3019935744 DEBUG: EGL mode 6: 720x480 (720x480) @ 60.00i - Full Screen (1.19) I:7
08:39:15 T:3019935744 DEBUG: EGL mode 7: 1920x1080 (1280x720) @ 60.00 - Full Screen (1.00) N:10
08:39:15 T:3019935744 DEBUG: EGL mode 8: 720x576 (720x576) @ 50.00 - Full Screen (1.07) :11
08:39:15 T:3019935744 DEBUG: EGL mode 9: 720x576 (720x576) @ 50.00 - Full Screen (1.42) :12
08:39:15 T:3019935744 DEBUG: EGL mode 10: 1280x720 (1280x720) @ 50.00 - Full Screen (1.00) :13
08:39:15 T:3019935744 DEBUG: EGL mode 11: 1920x1080 (1280x720) @ 50.00i - Full Screen (1.00) I:14
08:39:15 T:3019935744 DEBUG: EGL mode 12: 720x576 (720x576) @ 50.00i - Full Screen (1.07) I:15
08:39:15 T:3019935744 DEBUG: EGL mode 13: 720x576 (720x576) @ 50.00i - Full Screen (1.42) I:16
08:39:15 T:3019935744 DEBUG: EGL mode 14: 1920x1080 (1280x720) @ 50.00 - Full Screen (1.00) :1f
08:39:15 T:3019935744 DEBUG: EGL mode 15: 1920x1080 (1280x720) @ 24.00 - Full Screen (1.00) :20
08:39:15 T:3019935744 DEBUG: EGL get supported modes (2) = 7, prefer_group=1, prefer_mode=10
08:39:15 T:3019935744 DEBUG: EGL mode 0: 640x480 (640x480) @ 60.00 - Full Screen (1.00) :4
08:39:15 T:3019935744 DEBUG: EGL mode 1: 640x480 (640x480) @ 75.00 - Full Screen (1.00) :6
08:39:15 T:3019935744 DEBUG: EGL mode 2: 800x600 (800x600) @ 60.00 - Full Screen (1.00) :9
08:39:15 T:3019935744 DEBUG: EGL mode 3: 800x600 (800x600) @ 75.00 - Full Screen (1.00) :b
08:39:15 T:3019935744 DEBUG: EGL mode 4: 1024x768 (960x720) @ 60.00 - Full Screen (1.00) :10
08:39:15 T:3019935744 DEBUG: EGL mode 5: 1024x768 (960x720) @ 70.00 - Full Screen (1.00) :11
08:39:15 T:3019935744 DEBUG: EGL mode 6: 1024x768 (960x720) @ 75.00 - Full Screen (1.00) :12
08:39:15 T:3019935744 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 60.000000 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 59.940063 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 50.000000 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 24.000000 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 23.976025 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 75.000000 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 75.000000 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 960 x 720 for display 0 with 1024 x 768 @ 60.000000 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 960 x 720 for display 0 with 1024 x 768 @ 59.940063 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 960 x 720 for display 0 with 1024 x 768 @ 70.000000 Hz
08:39:15 T:3019935744 NOTICE: Found resolution 960 x 720 for display 0 with 1024 x 768 @ 75.000000 Hz
08:39:15 T:3019935744 NOTICE: Found ([email protected]) at 22, setting to RES_DESKTOP at 16
08:39:15 T:3019935744 NOTICE: Checking resolution 16
08:39:15 T:3019935744 DEBUG: EGL set HDMI mode (1,16)=0
08:39:15 T:2974806960 DEBUG: EGL tv_service_callback (8,1,16)
08:39:15 T:3019935744 DEBUG: EGL set resolution 1280x720 -> 1920x1080 @ 60.00 fps (1,16) flags:10010004 aspect:1.00
08:39:15 T:3019935744 DEBUG: CreateWindow: Created surface of size 1280x720
08:39:15 T:3019935744 NOTICE: GL_VENDOR = Broadcom
08:39:15 T:3019935744 NOTICE: GL_RENDERER = VideoCore IV HW
08:39:15 T:3019935744 NOTICE: GL_VERSION = OpenGL ES 2.0
08:39:15 T:3019935744 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
08:39:15 T:3019935744 DEBUG: GLES: Extension Support Test - GL_NVX_gpu_memory_info NO
08:39:15 T:3019935744 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
08:39:15 T:3019935744 DEBUG: GLES: Extension Support Test - GL_EXT_texture_format_BGRA8888 YES
08:39:15 T:3019935744 DEBUG: GLES: Extension Support Test - GL_IMG_texture_format_BGRA8888 NO
08:39:15 T:3019935744 DEBUG: GLES: Extension Support Test - GL_APPLE_texture_format_BGRA8888 NO
08:39:15 T:3019935744 DEBUG: GL: Vertex Shader compilation log:
08:39:15 T:3019935744 DEBUG: Compiled
08:39:15 T:3019935744 DEBUG: GL: Vertex Shader compiled successfully
08:39:15 T:3019935744 DEBUG: GL: Pixel Shader compilation log:
08:39:15 T:3019935744 DEBUG: GL: Fragment Shader compiled successfully
08:39:15 T:3019935744 DEBUG: GUI Shader [guishader_frag_default.glsl]- Initialise successful : 0x33b8e68
08:39:15 T:3019935744 DEBUG: GUI Shader [guishader_frag_texture.glsl]- Initialise successful : 0x33b8ee0
08:39:15 T:3019935744 DEBUG: GUI Shader [guishader_frag_multi.glsl]- Initialise successful : 0x33b9268
08:39:15 T:3019935744 DEBUG: GUI Shader [guishader_frag_fonts.glsl]- Initialise successful : 0x33b92e0
08:39:15 T:3019935744 DEBUG: GUI Shader [guishader_frag_texture_noblend.glsl]- Initialise successful : 0x33b8470
08:39:16 T:3019935744 DEBUG: GL: Pixel Shader compilation log:
08:39:16 T:3019935744 DEBUG: Compiled
08:39:16 T:3019935744 DEBUG: GL: Fragment Shader compiled successfully
08:39:16 T:3019935744 DEBUG: GUI Shader [guishader_frag_multi_blendcolor.glsl]- Initialise successful : 0x33b84e8
08:39:16 T:3019935744 DEBUG: GL: Vertex Shader compilation log:
08:39:16 T:3019935744 DEBUG: GL: Vertex Shader compiled successfully
08:39:16 T:3019935744 DEBUG: GUI Shader [guishader_frag_rgba.glsl]- Initialise successful : 0x34145f0
08:39:16 T:3019935744 DEBUG: GLES: Extension Support Test - GL_OES_EGL_image_external YES
08:39:16 T:3019935744 DEBUG: GUI Shader [guishader_frag_rgba_oes.glsl]- Initialise successful : 0x3414a38
08:39:16 T:3019935744 DEBUG: GUI Shader [guishader_frag_rgba_blendcolor.glsl]- Initialise successful : 0x3414ab0
08:39:16 T:3019935744 DEBUG: GUI Shader [guishader_frag_rgba_bob.glsl]- Initialise successful : 0x33b8278
08:39:16 T:3019935744 DEBUG: GUI Shader [guishader_frag_rgba_bob_oes.glsl]- Initialise successful : 0x33b8318
08:39:16 T:3019935744 DEBUG: CWinSystemEGL::CreateNewWindow: No need to create a new window
08:39:16 T:3019935744 INFO: GLES: Maximum texture width: 2048
08:39:16 T:3019935744 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
08:39:16 T:3019935744 INFO: load keymapping
08:39:17 T:3019935744 INFO: Loading special://xbmc/system/keymaps/appcommand.xml
08:39:17 T:3019935744 INFO: Loading special://xbmc/system/keymaps/gamepad.xml
08:39:17 T:3019935744 INFO: Loading special://xbmc/system/keymaps/joystick.Alienware.Dual.Compatible.Controller.xml
08:39:17 T:3019935744 INFO: Loading special://xbmc/system/keymaps/joystick.AppleRemote.xml
08:39:17 T:3019935744 INFO: Loading special://xbmc/system/keymaps/joystick.Harmony.xml
08:39:17 T:3019935744 INFO: Loading special://xbmc/system/keymaps/joystick.Interact.AxisPad.xml
08:39:17 T:3019935744 INFO: Loading special://xbmc/system/keymaps/joystick.Logitech.RumblePad.2.xml
08:39:17 T:3019935744 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.360.Controller.xml
08:39:17 T:3019935744 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.Controller.S.xml
08:39:18 T:3019935744 INFO: Loading special://xbmc/system/keymaps/joystick.Nintendo.Wii.U.Pro.Controller.xml
08:39:18 T:3019935744 INFO: Loading special://xbmc/system/keymaps/joystick.Ouya.Controller.xml
08:39:18 T:3019935744 INFO: Loading special://xbmc/system/keymaps/joystick.PS3.Remote.Keyboard.xml
08:39:18 T:3019935744 INFO: Loading special://xbmc/system/keymaps/joystick.PS4.Controller.xml
08:39:18 T:3019935744 INFO: Loading special://xbmc/system/keymaps/joystick.Sony.PLAYSTATION(R)3.Controller.xml
08:39:18 T:3019935744 INFO: Loading special://xbmc/system/keymaps/joystick.WiiRemote.xml
08:39:18 T:3019935744 INFO: Loading special://xbmc/system/keymaps/keyboard.xml
08:39:18 T:3019935744 INFO: Loading special://xbmc/system/keymaps/mouse.xml
08:39:18 T:3019935744 INFO: Loading special://xbmc/system/keymaps/remote.xml
08:39:18 T:3019935744 INFO: Loading special://xbmc/system/keymaps/touchscreen.xml
08:39:19 T:3019935744 INFO: Loading special://xbmc/system/Lircmap.xml
08:39:19 T:3019935744 INFO: * Adding remote mapping for device 'mceusb'
08:39:19 T:3019935744 INFO: * Adding remote mapping for device 'XboxDVDDongle'
08:39:19 T:3019935744 INFO: * Adding remote mapping for device 'Microsoft_Xbox'
08:39:19 T:3019935744 INFO: * Adding remote mapping for device 'PinnacleSysPCTVRemote'
08:39:19 T:3019935744 INFO: * Adding remote mapping for device 'anysee'
08:39:19 T:3019935744 INFO: * Adding remote mapping for device 'iMON-PAD'
08:39:19 T:3019935744 INFO: * Adding remote mapping for device 'Antec_Veris_RM200'
08:39:19 T:3019935744 INFO: * Adding remote mapping for device 'MCE_via_iMON'
08:39:19 T:3019935744 INFO: * Adding remote mapping for device 'TwinHanRemote'
08:39:19 T:3019935744 INFO: * Adding remote mapping for device 'linux-input-layer'
08:39:19 T:3019935744 INFO: * Linking remote mapping for 'linux-input-layer' to 'cx23885_remote'
08:39:19 T:3019935744 INFO: * Adding remote mapping for device 'mediacenter'
08:39:19 T:3019935744 INFO: * Adding remote mapping for device 'devinput'
08:39:19 T:3019935744 INFO: Loading special://profile/Lircmap.xml
08:39:19 T:3019935744 INFO: * Adding remote mapping for device '/storage/.config/lircd.conf.conf'
08:39:19 T:3019935744 INFO: GUI format 1280x720, Display 1920x1080 (1280x720) @ 60.00 - Full Screen
08:39:19 T:3019935744 DEBUG: guilib: Fill viewport on change for solving rendering passes
08:39:19 T:3019935744 INFO: CLangInfo: loading resource.language.en_gb language information...
08:39:19 T:3019935744 DEBUG: trying to set locale to en_US.UTF-8
08:39:19 T:3019935744 INFO: global locale set to C
08:39:19 T:3019935744 INFO: CLangInfo: loading resource.language.en_gb language strings...
08:39:19 T:3019935744 DEBUG: POParser: loaded 3312 strings from file resource://resource.language.en_gb/strings.po
08:39:19 T:3019935744 DEBUG: LoadMappings - loaded node "Motorola Nyxboard Hybrid"
08:39:19 T:3019935744 DEBUG: LoadMappings - loaded node "CEC Adapter"
08:39:19 T:3019935744 DEBUG: LoadMappings - loaded node "Pulse-Eight CEC Adapter"
08:39:19 T:3019935744 DEBUG: LoadMappings - loaded node "iMON HID device"
08:39:19 T:3019935744 DEBUG: CPeripheralBusUSB - initialised udev monitor
08:39:19 T:3019935744 DEBUG: SECTION:LoadDLL(libcec.so.3.0)
08:39:19 T:3019935744 DEBUG: Loading: libcec.so.3.0
08:39:20 T:3019935744 DEBUG: GetMappingForDevice - device (2708:1001) mapped to CEC Adapter (type = cec)
08:39:20 T:3019935744 DEBUG: InitialiseFeature - using libCEC v3.0.1
08:39:20 T:3019935744 DEBUG: Initialise - initialised peripheral on 'RPI' with 2 features and 0 sub devices
08:39:20 T:3019935744 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
08:39:20 T:2913338288 NOTICE: Thread CECAdapter start, auto delete: false
08:39:20 T:2913338288 DEBUG: OpenConnection - opening a connection to the CEC adapter: RPI
08:39:21 T:2888172464 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
08:39:21 T:3019935744 DEBUG: SECTION:LoadDLL(libcurl.so.4)
08:39:21 T:3019935744 DEBUG: Loading: libcurl.so.4
08:39:22 T:3019935744 NOTICE: Running database version Addons19
08:39:22 T:3019935744 DEBUG: Initialize, updating databases...
08:39:22 T:3019935744 NOTICE: Running database version ViewModes6
08:39:22 T:3019935744 NOTICE: Running database version Textures13
08:39:22 T:3019935744 NOTICE: Running database version MyMusic52
08:39:22 T:2913338288 DEBUG: OpenConnection - connection to the CEC adapter opened
08:39:22 T:2913338288 DEBUG: SetConfigurationFromLibCEC - settings updated by libCEC
08:39:22 T:2879017904 NOTICE: Thread CECAdapterUpdate start, auto delete: false
08:39:22 T:3019935744 NOTICE: Running database version MyVideos93
08:39:22 T:3019935744 NOTICE: Running database version TV29
08:39:22 T:3019935744 NOTICE: Running database version Epg10
08:39:22 T:3019935744 DEBUG: Initialize, updating databases... DONE
08:39:22 T:3019935744 NOTICE: start dvd mediatype detection
08:39:22 T:3019935744 INFO: DPMS: not supported on this platform
08:39:22 T:3001099184 NOTICE: Thread DetectDVDMedia start, auto delete: false
08:39:22 T:3001099184 DEBUG: Compiled with libcdio Version 0.83
08:39:22 T:3001099184 DEBUG: Thread DetectDVDMedia 3001099184 terminating
08:39:23 T:3019935744 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
08:39:23 T:3019935744 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
08:39:23 T:3019935744 INFO: Unloading old skin ...
08:39:23 T:3019935744 INFO: load skin from: /usr/share/kodi/addons/skin.confluence (version: 2.7.4)
08:39:23 T:3019935744 INFO: load fonts for skin...
08:39:23 T:3019935744 INFO: Loading fonts from /usr/share/kodi/addons/skin.confluence/720p/Font.xml
08:39:23 T:3019935744 DEBUG: POParser: loaded 147 strings from file /usr/share/kodi/addons/skin.confluence/language/resource.language.en_gb/strings.po
08:39:23 T:3019935744 INFO: Loading skin includes from /usr/share/kodi/addons/skin.confluence/720p/includes.xml
08:39:28 T:3019935744 INFO: load new skin...
08:39:28 T:3019935744 INFO: Loading user windows, path /usr/share/kodi/addons/skin.confluence/720p
08:39:28 T:3019935744 DEBUG: Load Skin XML: 148.71ms
08:39:28 T:3019935744 INFO: initialize new skin...
08:39:28 T:3019935744 DEBUG: guilib: Fill viewport on change for solving rendering passes
08:39:28 T:3019935744 INFO: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
08:39:28 T:3019935744 DEBUG: OpenBundle - Opened bundle /usr/share/kodi/addons/skin.confluence/media/Textures.xbt
08:39:28 T:3019935744 INFO: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
08:39:28 T:3019935744 INFO: Loading skin file: DialogKaiToast.xml, load type: LOAD_ON_GUI_INIT
08:39:28 T:3019935744 INFO: Loading skin file: DialogMuteBug.xml, load type: LOAD_ON_GUI_INIT
08:39:28 T:3019935744 INFO: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
08:39:29 T:3019935744 INFO: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
08:39:29 T:3019935744 INFO: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
08:39:29 T:3019935744 INFO: Loading resource://resource.uisounds.confluence/sounds.xml
08:39:30 T:3019935744 INFO: skin loaded...
08:39:31 T:3019935744 DEBUG: JSONRPC: JSON schema type broadcastnext references an unknown type PVR.Details.Broadcast
08:39:31 T:3019935744 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
08:39:31 T:3019935744 INFO: JSONRPC: Adding type "PVR.Details.Channel" to list of incomplete definitions (waiting for "PVR.Details.Broadcast")
08:39:31 T:3019935744 DEBUG: JSONRPC: JSON schema type references an unknown type PVR.Details.Channel
08:39:31 T:3019935744 DEBUG: Invalid item definition in "items" for type channels
08:39:31 T:3019935744 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
08:39:31 T:3019935744 INFO: JSONRPC: Adding type "PVR.Details.ChannelGroup.Extended" to list of incomplete definitions (waiting for "PVR.Details.Channel")
08:39:31 T:3019935744 INFO: JSONRPC: Resolving incomplete types/methods referencing PVR.Details.Broadcast
08:39:31 T:3019935744 INFO: JSONRPC: Resolving incomplete types/methods referencing PVR.Details.Channel
08:39:31 T:3019935744 DEBUG: JSONRPC: JSON schema type stereoscopicmode references an unknown type GUI.Stereoscopy.Mode
08:39:31 T:3019935744 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
08:39:31 T:3019935744 INFO: JSONRPC: Adding type "GUI.Property.Value" to list of incomplete definitions (waiting for "GUI.Stereoscopy.Mode")
08:39:31 T:3019935744 INFO: JSONRPC: Resolving incomplete types/methods referencing GUI.Stereoscopy.Mode
08:39:32 T:3019935744 DEBUG: JSONRPC: JSON schema type definition references an unknown type Setting.Details.Setting
08:39:32 T:3019935744 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
08:39:32 T:3019935744 INFO: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
08:39:32 T:3019935744 INFO: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
08:39:33 T:3019935744 INFO: JSONRPC v6.25.2: Successfully initialized
08:39:33 T:3019935744 DEBUG: ADDON: Starting service addons.
08:39:33 T:3019935744 DEBUG: Activating window ID: 12999
08:39:33 T:3019935744 DEBUG: ------ Window Init (Startup.xml) ------
08:39:33 T:3019935744 INFO: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
08:39:33 T:2866803632 NOTICE: Thread LanguageInvoker start, auto delete: false
08:39:33 T:2866803632 INFO: initializing python engine.
08:39:33 T:3019935744 INFO: removing tempfiles
08:39:33 T:3019935744 NOTICE: initialize done
08:39:33 T:3019935744 NOTICE: Running the application...
08:39:33 T:3019935744 DEBUG: Activating window ID: 10000
08:39:34 T:3019935744 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0x3414308
08:39:34 T:3019935744 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(125120), nBufferAlignmen(16)
08:39:34 T:3019935744 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61 m_handle 0x33b9048
08:39:34 T:3019935744 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0x33b8c48
08:39:34 T:3019935744 DEBUG: COMXCoreComponent::UseEGLImage component(OMX.broadcom.egl_render) - port(221), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(15360) nBufferAlignmen(16)
08:39:34 T:3019935744 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.image_decode handle 0x3414308
08:39:34 T:3019935744 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.resize handle 0x33b9048
08:39:34 T:3019935744 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.egl_render handle 0x33b8c48
08:39:34 T:3019935744 DEBUG: ------ Window Init () ------
08:39:34 T:3019935744 DEBUG: ------ Window Init (Pointer.xml) ------
08:39:34 T:3019935744 INFO: GLES: Enabling VSYNC
08:39:34 T:3019935744 INFO: GLES: Selected vsync mode 10
08:39:34 T:3019935744 DEBUG: ------ Window Deinit (Startup.xml) ------
08:39:34 T:3019935744 DEBUG: ------ Window Init (Home.xml) ------
08:39:34 T:3019935744 INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
08:39:38 T:2856678320 NOTICE: Thread JobWorker start, auto delete: true
08:39:38 T:2856678320 DEBUG: CRecentlyAddedJob::UpdateMusic() - Running RecentlyAdded home screen update
08:39:39 T:2856678320 DEBUG: GetRecentlyAddedAlbumSongs() query: SELECT songview.* FROM (SELECT idAlbum FROM albumview ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN songview ON songview.idAlbum=recentalbums.idAlbum
08:39:39 T:2856678320 DEBUG: GetRecentlyAddedAlbums query: select * from albumview where strAlbum != '' order by idAlbum desc limit 10
08:39:39 T:2856678320 DEBUG: CRecentlyAddedJob::UpdateVideos() - Running RecentlyAdded home screen update
08:39:39 T:3019935744 DEBUG: no profile autoexec.py (/home/pi/.kodi/userdata/autoexec.py) found, skipping
08:39:39 T:3019935744 DEBUG: NetworkMessage - Starting network services
08:39:39 T:3019935744 DEBUG: CZeroconfAvahi::clientCallback: client is up and running
08:39:39 T:3019935744 NOTICE: starting zeroconf publishing
08:39:39 T:3019935744 NOTICE: starting upnp client
08:39:39 T:2839901104 NOTICE: Thread JobWorker start, auto delete: true
08:39:39 T:3019935744 NOTICE: ES: Starting event server
08:39:39 T:3019935744 INFO: JSONRPC Server: Successfully initialized
08:39:39 T:2797958064 NOTICE: Thread EventServer start, auto delete: false
08:39:39 T:2797958064 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
08:39:39 T:2797958064 NOTICE: UDP: Listening on port 9777
08:39:39 T:2789569456 NOTICE: Thread TCPServer start, auto delete: false
08:39:39 T:2839901104 DEBUG: CZeroconfAvahi::doPublishService identifier: servers.eventserver type: _xbmc-events._udp name:Kodi (raspberrypi) port:9777
08:39:39 T:2839901104 DEBUG: CZeroconfAvahi::addService() named: Kodi (raspberrypi) type: _xbmc-events._udp port:9777
08:39:39 T:3019935744 DEBUG: LogindUPowerSyscall - Received unknown signal NameAcquired
08:39:39 T:2839901104 DEBUG: CZeroconfAvahi::doPublishService identifier: servers.jsonrpc-tpc type: _xbmc-jsonrpc._tcp name:Kodi (raspberrypi) port:9090
08:39:39 T:2839901104 DEBUG: CZeroconfAvahi::addService() named: Kodi (raspberrypi) type: _xbmc-jsonrpc._tcp port:9090
08:39:39 T:3019935744 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
08:39:39 T:3019935744 INFO: Found input device /dev/input/event0
08:39:39 T:3019935744 INFO: opened device 'lircd' (file name /dev/input/event0), m_bSkipNonKeyEvents 0
08:39:39 T:3019935744 WARNING: no keymap support (requires /dev/tty0 - CONFIG_VT)
08:39:39 T:3019935744 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0x3bede98
08:39:39 T:3019935744 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(125120), nBufferAlignmen(16)
08:39:39 T:3019935744 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61 m_handle 0x3c02150
08:39:40 T:3019935744 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0x358dc28
08:39:40 T:3019935744 DEBUG: COMXCoreComponent::UseEGLImage component(OMX.broadcom.egl_render) - port(221), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(15360) nBufferAlignmen(16)
08:39:40 T:3019935744 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.image_decode handle 0x3bede98
08:39:40 T:3019935744 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.resize handle 0x3c02150
08:39:40 T:3019935744 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.egl_render handle 0x358dc28
08:39:40 T:2856678320 DEBUG: RunQuery took 93 ms for 0 items query: select * from movie_view ORDER BY dateAdded desc, idMovie desc LIMIT 10
08:39:40 T:2856678320 DEBUG: RunQuery took 107 ms for 0 items query: select * from episode_view ORDER BY dateAdded desc, idEpisode desc LIMIT 10
08:39:40 T:3019935744 DEBUG: ------ Window Deinit (Pointer.xml) ------
08:39:40 T:2856678320 DEBUG: RunQuery took 91 ms for 0 items query: select * from musicvideo_view ORDER BY dateAdded desc, idMVideo desc LIMIT 10
08:39:40 T:2856678320 DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
08:39:40 T:2848289712 DEBUG: CZeroconfAvahi::groupCallback: Service successfully established
08:39:40 T:2866803632 DEBUG: Previous line repeats 1 times.
08:39:40 T:2866803632 DEBUG: CPythonInvoker(0, /home/pi/.kodi/addons/service.xbmc.versioncheck/service.py): start processing
08:39:46 T:3019935744 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
08:39:46 T:2866803632 NOTICE: -->Python Interpreter Initialized<--
08:39:46 T:2866803632 DEBUG: CPythonInvoker(0, /home/pi/.kodi/addons/service.xbmc.versioncheck/service.py): the source file to load is "/home/pi/.kodi/addons/service.xbmc.versioncheck/service.py"
08:39:46 T:2866803632 DEBUG: CPythonInvoker(0, /home/pi/.kodi/addons/service.xbmc.versioncheck/service.py): setting the Python path to /home/pi/.kodi/addons/service.xbmc.versioncheck:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/pymodules/python2.7
08:39:46 T:2866803632 DEBUG: CPythonInvoker(0, /home/pi/.kodi/addons/service.xbmc.versioncheck/service.py): entering source directory /home/pi/.kodi/addons/service.xbmc.versioncheck
08:39:46 T:2866803632 DEBUG: CPythonInvoker(0, /home/pi/.kodi/addons/service.xbmc.versioncheck/service.py): instantiating addon using automatically obtained id of "service.xbmc.versioncheck" dependent on version 2.1.0 of the xbmc.python api
08:39:49 T:2866803632 DEBUG: Version Check: Version 0.3.16 started
08:39:55 T:2866803632 DEBUG: Version Check: Version installed {u'major': 15, u'tag': u'stable', u'minor': 2, u'revision': u'02e7013'}
08:39:55 T:2866803632 DEBUG: Version Check: Version available {u'major': u'15', u'extrainfo': u'final', u'tagversion': u'', u'tag': u'stable', u'addon_support': u'yes', u'minor': u'2', u'revision': u'20151019-02e7013'}
08:39:55 T:2866803632 DEBUG: Version Check: There is no newer stable available
08:39:55 T:2866803632 INFO: CPythonInvoker(0, /home/pi/.kodi/addons/service.xbmc.versioncheck/service.py): script successfully run
08:39:56 T:2866803632 INFO: Python script stopped
08:39:56 T:2866803632 DEBUG: Thread LanguageInvoker 2866803632 terminating
08:40:20 T:3019935744 INFO: Python, unloading python shared library because no scripts are running anymore
08:40:20 T:3019935744 DEBUG: UnloadExtensionLibs, clearing python extension libraries
08:40:23 T:2839901104 DEBUG: Thread JobWorker 2839901104 terminating (autodelete)
08:40:25 T:2856678320 DEBUG: Thread JobWorker 2856678320 terminating (autodelete)
08:40:46 T:3019935744 DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
08:40:46 T:3019935744 DEBUG: OnKey: up (0xf080) pressed, action is Up
08:40:46 T:3019935744 DEBUG: LIRC: Update - NEW at 85751:00000000000013e0 00 key_up /storage/.config/lircd.conf.conf (key_up)
08:40:46 T:3019935744 DEBUG: LIRC: Update - NEW at 86110:00000000000013e0 00 key_up /storage/.config/lircd.conf.conf (key_up)
08:40:46 T:3019935744 DEBUG: LIRC: Update - NEW at 86457:00000000000003d7 00 key_ok /storage/.config/lircd.conf.conf (key_ok)
08:40:47 T:3019935744 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
08:40:47 T:3019935744 DEBUG: OnKey: down (0xf081) pressed, action is Down
08:40:47 T:3019935744 DEBUG: LIRC: Update - NEW at 86755:00000000000013e1 00 Key_down /storage/.config/lircd.conf.conf (Key_down)
08:40:47 T:3019935744 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
08:40:47 T:3019935744 DEBUG: OnKey: right (0xf083) pressed, action is Right
08:40:47 T:3019935744 DEBUG: LIRC: Update - NEW at 87086:00000000000013d0 00 key_right /storage/.config/lircd.conf.conf (key_right)
08:40:47 T:3019935744 DEBUG: LIRC: Update - NEW at 87414:00000000000003d7 00 key_ok /storage/.config/lircd.conf.conf (key_ok)
08:40:47 T:3019935744 DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
08:40:47 T:3019935744 DEBUG: OnKey: left (0xf082) pressed, action is Left
08:40:47 T:3019935744 DEBUG: LIRC: Update - NEW at 87697:00000000000013d1 00 key_left /storage/.config/lircd.conf.conf (key_left)
08:40:48 T:3019935744 DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
08:40:48 T:3019935744 DEBUG: OnKey: left (0xf082) pressed, action is Left
08:40:48 T:3019935744 DEBUG: LIRC: Update - NEW at 87978:00000000000003d7 00 key_ok /storage/.config/lircd.conf.conf (key_ok)
08:40:48 T:3019935744 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
08:40:48 T:3019935744 DEBUG: OnKey: down (0xf081) pressed, action is Down
08:40:48 T:3019935744 DEBUG: LIRC: Update - NEW at 88221:00000000000013e1 00 Key_down /storage/.config/lircd.conf.conf (Key_down)
08:40:48 T:3019935744 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
08:40:48 T:3019935744 DEBUG: OnKey: right (0xf083) pressed, action is Right
08:40:48 T:3019935744 DEBUG: LIRC: Update - NEW at 88515:00000000000013d0 00 key_right /storage/.config/lircd.conf.conf (key_right)
08:40:49 T:3019935744 DEBUG: LIRC: Update - NEW at 88797:00000000000003d7 00 key_ok /storage/.config/lircd.conf.conf (key_ok)
08:40:49 T:3019935744 DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
08:40:49 T:3019935744 DEBUG: OnKey: up (0xf080) pressed, action is Up
08:40:49 T:3019935744 DEBUG: LIRC: Update - NEW at 89045:00000000000013e0 00 key_up /storage/.config/lircd.conf.conf (key_up)
08:40:49 T:3019935744 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
08:40:49 T:3019935744 DEBUG: OnKey: right (0xf083) pressed, action is Right
08:40:49 T:3019935744 DEBUG: LIRC: Update - NEW at 89277:00000000000013d0 00 key_right /storage/.config/lircd.conf.conf (key_right)
