I have a device with kodi 15.2 and metropolis 3.1.0,
everything is working I think.. what shouldn't work?
is it less stable or something?
3.2.x includes the required changes to make it Isengard-compliant. Is there some particular reason you're not updating?
Thank you for you're quick answer!
my 3.1.0 is hebrew and 3.2.x don't have..
I know I can modify but still, what's not supposed to work?
can you make metropolis 3.2.2 with hebrew support in it?
You're going to continuously have that problem I'm afraid. And Jarvis (and beyond) definitely won't work with 3.1.0.
To answer your question though, the differences are listed in the changelog. The first change, "Kodi 15 support," includes support for the required changes
listed here.
(2016-03-15, 21:32)adito Wrote: [ -> ]can you make metropolis 3.2.2 with hebrew support in it?
If someone is able to modify the existing font to cover the missing characters, I would certainly include it. However, simply using Arial or whatever for everything isn't something I will do -- the font is a pretty integral part of the design.
That said.. I assume your modifications are just to the Font.xml file, which hasn't really been touched since Dec 2014, with the exception of one small addition on Oct 7 2015. So you probably can just drop in your modified Font.xml and things will work.
