Maybe another CloudFlare issue, but I can no longer ssh into SRV1 to do wiki backups, updating extensions, and accessing the configuration files for the wiki.
Still unable to ssh in. Even if it is an issue that can't be handled at the moment, some kind of acknowledgment would be appreciated. The wiki is over due for a backup and spam IP lookups are broken until I can log in. I'm quite worried about it, but I don't want to be a bother.
What are you ssh-ing to ?
Originally it was xbmc.org, then kodi.tv, on a non-default port. Now it just times out trying to connect, so I'm guessing I need to use a different address and/or port?
you'll have to use the original IP, not what points to cloudflare
Ah, that makes sense. Now I just need to know what that IP is :)
I'd say srv1.kodi.tv as it's not a CF ip block
