2016-03-17, 15:51
Hello,
I have an issue for 2 weeks. When i want to get all data for my films this message appear at the end of the configuration :Can not connect to the server - you want to continue scanning ?
This works fine for my TV Shows with TVDB scraper.
I tried to reinstall OSMC with KODI but i have the same problem. I tried to update the scrapper by download on website and install from zip, but doesn't resolve the problem.
Below the log to understand the problem:
10:02:13 2893.681641 T:2579493872 DEBUG: VideoInfoScanner: No NFO file found. Using title search for '/media/Stock_Mara/Films/Kad.Et.Olivier.Antotologie.Part1.CD1/Kad Et Olivier Antotologie.avi'
10:02:13 2893.685303 T:2579493872 DEBUG: FindMovie: Searching for 'Kad Et Olivier Antotologie' using The Movie Database scraper (path: '/usr/share/kodi/addons/metadata.themoviedb.org', content: 'movies', version: '3.9.0')
10:02:13 2893.895508 T:2579493872 DEBUG: scraper: CreateSearchUrl returned <url>http://api.tmdb.org/3/search/movie?api_key=f7f51775877e0bb6703520952b3c7840&query=Kad%20Et%20Olivier%20Antotologie&year=&language=en</url>
10:02:13 2893.903076 T:2579493872 DEBUG: CurlFile::Open(0xa888b7e0) http://api.tmdb.org/3/search/movie?api_k...anguage=en
10:02:13 2893.907715 T:2579493872 INFO: easy_aquire - Created session to http://api.tmdb.org
10:02:23 2903.986816 T:2579493872 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
10:02:23 2903.988281 T:2579493872 ERROR: CCurlFile::Open failed with code 0 for http://api.tmdb.org/3/search/movie?api_k...anguage=en
10:02:23 2903.989746 T:2579493872 ERROR: Run: Unable to parse web site
10:02:23 2903.995361 T:3024245296 DEBUG: ------ Window Init (DialogYesNo.xml) ------
10:02:27 2908.172852 T:2854220784 DEBUG: script.module.osmcsetting.updates : - blurp 778 - DialogYesNo.xml
Could you help me please, i have search a lot and write a lot of article on this problem without result.
Thanks in advance
Thanks in advance
