2007-05-21, 21:47
I have a problem with the stream from VLC (or directly from AVB). I can View some channel but other channel Like Discovery or FOX (and other) I can view the stream for 2 or 3 second. The channel is discrembled and i can view it in Mytheatre but XBMC won't read the stream of some channel.
Oh and other can be viewed for 1 hour and get disconnected.
Hardware and Software used :
Twinhan SatPro 1027
BEV
Mytheatre 3.38
Emunation 1.4.3.4
AVB 0.13
XBMC (Current version 2.0.1 (i think))
mytheatre.py (last version)
VLC (last stable)
part of DEBUG
Cache fill: 0.00% (0 bytes)
14:43:45 M: 27906048 DEBUG: msg: stream_enable_cache() eof detected
14:43:45 M: 27906048 DEBUG: msg: demux_open(011D9010,0,-1,-1,-1)
14:43:46 M: 27906048 ERROR: CMPlayer::OpenFile : Access violation at 0x02652e34: Reading location 0x00000020
14:43:46 M: 27906048 DEBUG: msg: mplayer_close_file()
14:43:46 M: 27906048 DEBUG: msg: uninit_player
14:43:46 M: 30035968 DEBUG: msg: uninit_player - done
14:43:46 M: 30068736 DEBUG: Freeing FS segment @ 0xa936e0
14:43:46 M: 36438016 ERROR: Playlist Player: skipping unplayable item: 0, path [http://192.168.1.103:8000/dvbcore.mpg]
14:43:46 M: 36438016 DEBUG: Playlist Player: no more playable items... aborting playback
14:43:49 M: 37433344 INFO: XCURL:llLibCurlGlobal::CheckIdle - Closing session to http://192.168.1.103
14:43:50 M: 37470208 DEBUG: CApplication::OnKey: 256 pressed, action is 7
14:43:50 M: 37470208 INFO: Loading skin file: DialogProgress.xml
14:43:59 M: 37470208 INFO: Loading web playlist http://192.168.1.103:8000/dvbcore.mpg
14:43:59 M: 37470208 INFO: Get Header URL: http://192.168.1.103:8000/dvbcore.mpg
14:43:59 M: 37433344 ERROR: Server returned: 405 Method Not Allowed
14:43:59 M: 37470208 NOTICE: URL http://192.168.1.103:8000/dvbcore.mpg not found
14:43:59 M: 37470208 DEBUG: CApplication:rocessAndStartPlaylist(temp.strm, 3)
14:43:59 M: 37470208 DEBUG: CPlayerCoreFactor::GetPlayers(http://192.168.1.103:8000/dvbcore.mpg)
14:43:59 M: 37433344 INFO: XCURL:llLibCurlGlobal::easy_aquire - Created session to http:[....]
Twinhan SatPro 1027
BEV
Mytheatre 3.38
Emunation 1.4.3.4
AVB 0.13
VLC (last stable)
part of DEBUG
