Full Version: Version 2.7.3
17.03.2016 - Version 2.7.3
+ bug reports are now solved via GitHub issues
+ added image exporting in the export templates (see http://goo.gl/kuSYlH or in the wiki)
+ added media source to the TV show section
+/x moved fanart.tv client key to the scraper settings (and released it for everyone)
x Kodi scraper: fix some invalid XML headers
x OFDB scraper: fix actor/cast parsing
x Zelluloid.de: fix actor/cast parsing, and fallback for broken web search
x Trakt.tv: fix writing correct watched state to NFO
x CMD: update TvShows only scrapes new episodes, not all
x improved data source update; parse new entries first
x improved TV show renamer for multi episode files
x finally fixed the NEW indicator behavior
it will now work as in versions before 2.7 (NEW stays for the whole tmm session)
x improved performance in the update data sources for TV shows
x fixed searching for movie set artwork in movie folders
x only write guests into episode NFO
x fixed error in movie set editor when no movie was selected
x remember last opened directory in the new chooser
x TvShows: fix studio writing
x fix loading of the movie-duplicate filter at startup
I have a bu with this version.
I post here because issue on github doesn't let me post my zip file.
Version: 2.7.3
Build: 2016-03-17 19:43
OS: Windows 10 10.0
JDK: 1.8.0_73 x86 Oracle Corporation
__What is the actual behaviour?__
Impossible to register for donator version in the last build 2.7.3
__Steps to reproduce:__
Update to version 2.7.3. TMM is no longer registered
Click on "Register for donator version" an error "java" happend.
I can post my log if it's needed but not on github at the moment.
Thanks you
this will be fixed with the next maintenance release
the fix for regstering the donator version is online
Ok it's good now thanks
