2016-03-18, 13:44
Hello.
I apologize in advance for everything I use Google translate.
I have the following problem.
I have a home Synology NAS 213j, and to me it is running phpMyAdmin.
I also have Xtreamer Ultra 2, SonyTV Android and kodi, AppleTV4 with MRMC and Raspberry PI 3 with OpenELEC.
I followed these instructions: http://www.htpcbeginner.com/kodi-mysql-s...e-library/
Originally I tried everything just to limber Xtreamer.
According to the instructions, I created a file advancedsettings.xml
<Advancedsettings>
<Videodatabase>
<Type> mysql </ type>
<Host> 192.168.88.22 </ host>
<Port> 3306 </ port>
<User> kodi </ user>
<Pass> kodi </ pass>
</ Videodatabase>
<Musicdatabase>
</ Musicdatabase>
<Videolibrary>
<Importwatchedstate> true </ importwatchedstate>
<Importresumepoint> true </ importresumepoint>
<Cleanonupdate> true </ cleanonupdate> <! - Also clean library During library update ->
<Hideallitems> true </ hideallitems> <! - Removes the "* All" items from the video library ->
<Hideemptyseries> true </ hideemptyseries> <! - Hide empty series in the video library ->
</ Videolibrary>
<Videoscanner>
<Ignoreerrors> true </ ignoreerrors> <! - Silently ignore errors while scanning videos. ->
</ Videoscanner>
</ Advancedsettings>
But I'm still getting the error message: The server on '192.168.88.22' (101))
11:40:48 T: 140470740187008 ERROR: Unable to create new database
11:40:48 T: 140470740187008 ERROR: Unable to open database: MyVideos93 [2003] (Can not connect to MySQL server on '192.168.88.22' (101))
11:40:48 T: 140470740187008 ERROR: Unable to open database: MyVideos92 [2003] ......
So I decided to try the procedure on another device.
I began to AppleTV4 - database was created immediately.
Advancedsettings.xml file originally created for Xtreamer I copied into SonyTV, according to the instructions, I set what exactly contains media files - Movies and scraper I set the Local info only. Just everything is working correctly.
In the same way, I proceeded to Raspberry 3 - again, everything works correctly.
But the original problem still persists XTREAMER - under no circumstances it can not connect to the database and log I still throws the same error.
If the file is not present Xtreamer advancedsettings.xml, everything works correctly. If there insert file, restart the device, then I go to Videos / files / MyMovies / are opened context menu / Set content / None --- I modified Movies / Local information only / OK / window "Change content" / YES --- ---- happening is nothing. On other devices will begin to download information about individual films.
When I go again Videos / files / MyMovies / are opened context menu / Set content / ----- I find there again set (NONE).
I tried to change several users, several password, all user I added the MySQL user, I just found the only way Xtreamer be able to connect to the database.
Advancedsettings.xml I always edited in Notepad ++
I will be grateful for any help. I really have no idea how to change this situation. I even had to file advancedsettings.xml added and lines <name> MyVideos </ name> and <name> MyMusic </ name>
Nothing helps :-(
Everywhere I am, of course, the same version of Kodi.
I thank you very much.
<Advancedsettings>
<Videodatabase>
</ Videodatabase>
<Musicdatabase>
</ Musicdatabase>
<Videolibrary>
</ Videolibrary>
<Videoscanner>
</ Videoscanner>
Nothing helps :-(
