someone as pressed something on my fire stick because when i try to use it a message says disconnect the mouse i havent connected one how can i fix
I don't think you could have posted your problem in the worst place.
You attached it to an old existing thread that was not only unrelated but in the completely wrong sub-forum.
I have renamed your thread and moved it to the appropriate place.
Given the VERY limited information you supply, the missing letters and no punctuation whatsoever makes it somewhat hard to help you out. I will try though:
Is ADB turned on (probably, since to install Kodi in the first place you need it)? You can fully control the stick with a pc then (
http://lmgtfy.com/?q=control+fire+tv+stick+with+adb ). You cold also try to control the stick with the FireTV app on a Smartphone. If that doesn't work i fear a factory reset would be the easiest thing to do -if you have no way to control the stick. I am not sure i interpreted your post correctly though.
