2016-03-21, 13:05
Since Kodi 16 I have the following issue:
Tried Kodi 16, 16.1, 17 all the same result.
Kodi 15 runs fine. Any idea what could be wrong?[/code]
11:54:47 T:1248 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:54:47 T:1248 NOTICE: -----------------------------------------------------------------------
11:54:47 T:1248 NOTICE: Starting Kodi (17.0-ALPHA1 Git:20160228-4e0c0fb). Platform: Windows NT x86 32-bit
11:54:47 T:1248 NOTICE: Using Release Kodi x32 build
11:54:47 T:1248 NOTICE: Kodi compiled Feb 29 2016 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
11:54:47 T:1248 NOTICE: Running on Gigabyte Technology Co., Ltd. GA-MA785GMT-UD2H with Windows 8.1, kernel: Windows NT x86 64-bit version 6.3
11:54:47 T:1248 NOTICE: Host CPU: AMD Athlon(tm) II X2 240e Processor, 2 cores available
11:54:47 T:1248 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
11:54:47 T:1248 NOTICE: Running with administrator rights
11:54:47 T:1248 NOTICE: Aero is enabled
11:54:47 T:1248 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
11:54:47 T:1248 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
11:54:47 T:1248 NOTICE: special://masterprofile/ is mapped to: C:\Users\Ivo\AppData\Roaming\Kodi\userdata
11:54:47 T:1248 NOTICE: special://home/ is mapped to: C:\Users\Ivo\AppData\Roaming\Kodi\
11:54:47 T:1248 NOTICE: special://temp/ is mapped to: C:\Users\Ivo\AppData\Roaming\Kodi\cache
11:54:47 T:1248 NOTICE: special://logpath/ is mapped to: C:\Users\Ivo\AppData\Roaming\Kodi\
11:54:47 T:1248 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
11:54:47 T:1248 NOTICE: Local hostname: mediabak
11:54:47 T:1248 NOTICE: Log File is located: C:\Users\Ivo\AppData\Roaming\Kodi\/kodi.log
11:54:50 T:1248 NOTICE: load settings...
11:54:50 T:1248 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
11:54:50 T:1248 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
11:54:51 T:1248 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
11:54:51 T:1248 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
11:54:51 T:1248 NOTICE: Default Video Player: VideoPlayer
11:54:51 T:1248 NOTICE: Default Audio Player: paplayer
11:54:51 T:1248 NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:54:51 T:1248 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
11:54:51 T:1248 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
11:54:51 T:1248 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:54:51 T:1248 NOTICE: Loaded playercorefactory configuration
11:54:51 T:1248 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:54:51 T:1248 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:54:51 T:2596 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: stream type "STREAM_TYPE_DTSHD" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
11:54:51 T:2596 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: stream type "STREAM_TYPE_TRUEHD" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
11:54:51 T:2596 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: stream type "STREAM_TYPE_EAC3" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
11:54:51 T:2596 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: stream type "STREAM_TYPE_DTS" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
11:54:51 T:2596 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
11:54:51 T:2596 NOTICE: Found 2 Lists of Devices
11:54:51 T:2596 NOTICE: Enumerated DIRECTSOUND devices:
11:54:51 T:2596 NOTICE: Device 1
11:54:51 T:2596 NOTICE: m_deviceName : {B47F28C4-A4DC-4C5F-974C-22B1E3BCDFB2}
11:54:51 T:2596 NOTICE: m_displayName : SPDIF - Digitale audio (S/PDIF) (High Definition Audio-apparaat)
11:54:51 T:2596 NOTICE: m_displayNameExtra: DIRECTSOUND: Digitale audio (S/PDIF) (High Definition Audio-apparaat)
11:54:51 T:2596 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
11:54:51 T:2596 NOTICE: m_channels : FL,FR
11:54:51 T:2596 NOTICE: m_sampleRates : 44100
11:54:51 T:2596 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_RAW
11:54:51 T:2596 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512
11:54:51 T:2596 NOTICE: Device 2
11:54:51 T:2596 NOTICE: m_deviceName : {EA784544-1C3A-43CB-8545-7844D94682D3}
11:54:51 T:2596 NOTICE: m_displayName : HDMI - AMD HDMI Output (AMD High Definition Audio Device)
11:54:51 T:2596 NOTICE: m_displayNameExtra: DIRECTSOUND: AMD HDMI Output (AMD High Definition Audio Device)
11:54:51 T:2596 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
11:54:51 T:2596 NOTICE: m_sampleRates : 48000
11:54:51 T:2596 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512
11:54:51 T:2596 NOTICE: Device 3
11:54:51 T:2596 NOTICE: m_deviceName : default
11:54:51 T:2596 NOTICE: m_displayName : default
11:54:51 T:2596 NOTICE: Enumerated WASAPI devices:
11:54:51 T:2596 NOTICE: m_displayNameExtra: WASAPI: Digitale audio (S/PDIF) (High Definition Audio-apparaat)
11:54:51 T:2596 NOTICE: m_sampleRates : 192000,96000,88200,48000,44100
11:54:51 T:2596 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S32NE,AE_FMT_S32LE,AE_FMT_S32BE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_RAW
11:54:51 T:2596 NOTICE: m_streamTypes : STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512,STREAM_TYPE_AC3
11:54:51 T:2596 NOTICE: m_displayNameExtra: WASAPI: AMD HDMI Output (AMD High Definition Audio Device)
11:54:51 T:2596 NOTICE: m_sampleRates : 192000,96000,88200,48000,44100,32000
11:54:51 T:2596 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_RAW
11:54:51 T:2596 NOTICE: m_streamTypes : STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512,STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_TRUEHD,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512,STREAM_TYPE_AC3
11:54:55 T:1248 NOTICE: Running database version Addons22
11:54:58 T:1248 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.sports
11:54:58 T:1248 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.repositories
11:54:58 T:1248 NOTICE: ADDONS: Using repository repository.xbmchub
11:54:58 T:1248 NOTICE: ADDONS: Using repository repository.nlsports
11:54:58 T:1248 NOTICE: ADDONS: Using repository repository.xbmc.org
11:54:59 T:1248 NOTICE: Found screen: Generic PnP Monitor on AMD Radeon HD 5450, adapter 0.
11:54:59 T:1248 NOTICE: Primary mode: 1920x1080@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 720x480@ 29.97i - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 720x480@ 30.00i - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 720x576@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 720x576@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 720x576@ 25.00i - Full Screen
11:54:59 T:1248 NOTICE: Previous line repeats 2 times.
11:54:59 T:1248 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1152x648@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1152x648@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1152x648@ 50.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x768@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x768@ 50.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x768@ 29.97 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x768@ 30.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x768@ 25.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x768@ 24.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x1024@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x1024@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x1024@ 50.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x1024@ 29.97 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x1024@ 30.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x1024@ 25.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x1024@ 23.98 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1360x1024@ 24.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1366x768@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1366x768@ 50.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1366x768@ 29.97 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1366x768@ 30.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1366x768@ 25.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1366x768@ 24.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1400x1050@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1400x1050@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1400x1050@ 50.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1400x1050@ 29.97 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1400x1050@ 30.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1400x1050@ 25.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1400x1050@ 23.98 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1400x1050@ 24.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1440x900@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1440x900@ 50.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1440x900@ 29.97 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1440x900@ 30.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1440x900@ 25.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1440x900@ 24.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1600x900@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1600x900@ 50.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1600x900@ 29.97 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1600x900@ 30.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1600x900@ 25.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1600x900@ 24.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1680x1050@ 50.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1680x1050@ 29.97 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1680x1050@ 30.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1680x1050@ 25.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1680x1050@ 23.98 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1680x1050@ 24.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1776x1000@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1776x1000@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1776x1000@ 50.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1776x1000@ 29.97 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1776x1000@ 30.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1776x1000@ 29.97i - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1776x1000@ 30.00i - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1776x1000@ 25.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1776x1000@ 25.00i - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1776x1000@ 24.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1920x1080@ 29.97 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1920x1080@ 30.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1920x1080@ 25.00 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1920x1080@ 25.00i - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1920x1080@ 23.98 - Full Screen
11:54:59 T:1248 NOTICE: Additional mode: 1920x1080@ 24.00 - Full Screen
11:54:59 T:1248 NOTICE: Checking resolution 15
11:55:07 T:1248 NOTICE: Running database version Addons22
11:55:07 T:1248 NOTICE: Running database version ViewModes6
11:55:07 T:1248 NOTICE: Running database version Textures13
11:55:07 T:1248 NOTICE: Running database version MyMusic59
11:55:07 T:1248 NOTICE: Running database version MyVideos103
11:55:07 T:1248 NOTICE: Running database version TV29
11:55:07 T:1248 NOTICE: Running database version Epg11
11:55:11 T:1248 ERROR: unable to load:C:\Users\Ivo\AppData\Roaming\Kodi\addons\skin.aeon.nox.5\1080i\DialogNotification.xml, Line 0
Failed to open file
11:55:12 T:1248 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
11:55:12 T:1248 NOTICE: ActiveAE DSP - starting
11:55:12 T:1248 NOTICE: CApplication::UpdateLibraries: Starting video library startup scan
11:55:12 T:1248 NOTICE: CApplication::UpdateLibraries: Starting music library startup scan
11:55:12 T:1248 ERROR: CScriptInvocationManager::ExecuteAsync - Not executing non-existing script C:\Users\Ivo\AppData\Roaming\Kodi\addons\script.navi-x\service.py
11:55:12 T:1248 NOTICE: initialize done
11:55:12 T:1248 NOTICE: Running the application...
11:55:12 T:1248 NOTICE: WebServer: Started the webserver
11:55:12 T:1248 NOTICE: starting upnp client
11:55:12 T:2264 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
11:55:12 T:2264 NOTICE: UDP: Listening on port 9777
11:55:13 T:2208 NOTICE: VideoInfoScanner: Starting scan ..
