2016-03-21, 14:44
This is a continuation of http://forum.kodi.tv/showthread.php?tid=254558
For OSMC Kodi 18 builds see http://forum.kodi.tv/showthread.php?tid=298775
The previous Raspberry Pi test builds thread has been closed as we have now moved to using an APT repository. This new system allows you to update test builds more easily and ensures that dependencies of the new builds are satisfied properly.
OSMC Test Builds for Kodi 17 for Raspberry Pi 1 & 2/3
Based on the Kodi master Krypton (v17) and popcornmix's newclock
Warning
Kodi 17 is currently beta and there is likely to be a lot of activity in the coming weeks/months.
Before proceeding make sure you have a backup of your Raspberry Pi. As these are test builds there could well be some unexpected problems.
Database upgrades could also be an issue. Please make a backup of the Kodi database before installing, especially if you are running a remote MySQL database.
Current Build
16.8-199, 2 Dec 2016: Based off OSMC commit (b9120ae19e) and newclock5 (a1d171ff)
Build Highlights:
Temporarily removed peripheral.joystick due to build error
kodi-binary-addons: inputstream.adaptive replaces inputstream.mpd and inputstream.smoothstream
Previous Builds:
16.8-198, 1 Dec 2016
16.8-197, 30 Nov 2016
16.8-196, 27 Nov 2016
16.8-195, 26 Nov 2016
16.8-194,24 Nov 2016
16.8-193, 23 Nov 2016
16.8-192, 22 Nov 2016
16.8-191, 21 Nov 2016
16.8-190, 19 Nov 2016
16.8-189, 13 Nov 2016
16.8-188, 12 Nov 2016
16.8-187, 11 Nov 2016
16.8-186, 10 Nov 2016
16.8-185, 9 Nov 2016
16.8-184, 8 Nov 2016
16.8-183, 7 Nov 2016
16.8-182, 6 Nov 2016
16.8-181, 3 Nov 2016
16.8-180, 2 Nov 2016
16.8-179, 1 Nov 2016
16.8-178, 31 Oct 2016
16.8-177, 30 Oct 2016
16.8-176, 29 Oct 2016
16.8-175. 23 Oct 2016
16.8-174, 22 Oct 2016
16.8-173, 21 Oct 2016
16.8-172, 19 Oct 2016
16.8-171, 18 Oct 2016
16.8-170, 15 Oct 2016
16.8-169, 14 Oct 2016
16.8-168, 13 Oct 2016
16.8-167, 11 Oct 2016
16.8-166, 10 Oct 2016
16.8-165, 08 Oct 2016
16.8-164. 07 Oct 2016
16.8-163, 06 Oct 2016
16.8-162, 05 Oct 2016
16.8-161, 04 Oct 2016
Archive:
http://kodi.gjmccarthy.co.uk
To get these builds, you will need to add gmc to the Debian repository. This can be by editing /etc/apt/sources.list, and adding the following:
To install a test build, run the following command to update the apt cache:
And then issue the following command to install a test build for Raspberry Pi 2 or 3:
To install a Raspberry Pi 1 or Raspberry Pi Zero build, issue the following command:
You can now update to the latest build when it is published with the following commands:
To confirm which version you are running:
Warning
Current Build
Build Highlights:
Previous Builds:
Archive:
deb http://download.osmc.tv/dev/gmc ./
sudo apt-get update
sudo apt-get install rbp2-mediacenter-osmc
sudo apt-get install rbp1-mediacenter-osmc
sudo apt-get update
sudo apt-get dist-upgrade
dpkg -l | grep mediacenter-osmc | awk '{ print $3 }'
