Hi marcelveldt, thanks for your work... new log on Android :
22:35:13 T:1388968240 NOTICE: GL_VENDOR = NVIDIA Corporation
22:35:13 T:1388968240 NOTICE: GL_RENDERER = NVIDIA Tegra
22:35:13 T:1388968240 NOTICE: GL_VERSION = OpenGL ES 3.2 NVIDIA 361.00
22:35:13 T:1388968240 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.20
22:35:13 T:1388968240 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_EXT_base_instance GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_buffer_storage GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_copy_image GL_EXT_debug_label GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_float_blend GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_indirect GL_EXT_multisample_compatibility GL_EXT_occlusion_query_boolean GL_EXT_post_depth_coverage GL_EXT_primitive_bounding_box GL_EXT_raster_multisample GL_EXT_render_snorm GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_sparse_texture GL_EXT_sparse_texture2 GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_format_BGRA8888 GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_view GL_EXT_unpack_subimage GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_NV_bgr GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NV_conditional_render GL_NV_conservative_raster GL_NV_copy_buffer GL_NV_copy_image GL_NV_draw_buffers GL_NV_draw_instanced GL_NV_draw_texture GL_NV_EGL_stream_consumer_external GL_NV_explicit_attrib_location GL_NV_fbo_color_attachments GL_NV_fill_rectangle GL_NV_fragment_coverage_to_color GL_NV_fragment_shader_interlock GL_NV_framebuffer_blit GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample GL_NV_generate_mipmap_sRGB GL_NV_geometry_shader_passthrough GL_NV_instanced_arrays GL_NV_internalformat_sample_query GL_NV_gpu_shader5 GL_NV_image_formats GL_NV_occlusion_query_samples GL_NV_non_square_matrices GL_NV_pack_subimage GL_NV_packed_float GL_NV_packed_float_linear GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_buffer_object GL_NV_polygon_mode GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_secure_context GL_NV_shader_atomic_fp16_vector GL_NV_shader_noperspective_interpolation GL_NV_shadow_samplers_array GL_NV_shadow_samplers_cube GL_NV_sRGB_formats GL_NV_texture_array GL_NV_texture_border_clamp GL_NV_texture_compression_latc GL_NV_texture_compression_s3tc GL_NV_texture_compression_s3tc_update GL_NV_timer_query GL_NV_viewport_array GL_NV_viewport_array2 GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_buffer GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_view GL_OES_primitive_bounding_box GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_multisample_interpolation GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_cube_map_array GL_OES_texture_npot GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_vertex_array_object GL_OES_vertex_half_float GL_ANDROID_extension_pack_es31a
22:35:27 T:1388968240 NOTICE: GL_VENDOR = NVIDIA Corporation
22:35:27 T:1388968240 NOTICE: GL_RENDERER = NVIDIA Tegra
22:35:27 T:1388968240 NOTICE: GL_VERSION = OpenGL ES 3.2 NVIDIA 361.00
22:35:27 T:1388968240 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.20
22:35:27 T:1388968240 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_EXT_base_instance GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_buffer_storage GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_copy_image GL_EXT_debug_label GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_float_blend GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_indirect GL_EXT_multisample_compatibility GL_EXT_occlusion_query_boolean GL_EXT_post_depth_coverage GL_EXT_primitive_bounding_box GL_EXT_raster_multisample GL_EXT_render_snorm GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_sparse_texture GL_EXT_sparse_texture2 GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_format_BGRA8888 GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_view GL_EXT_unpack_subimage GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_NV_bgr GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NV_conditional_render GL_NV_conservative_raster GL_NV_copy_buffer GL_NV_copy_image GL_NV_draw_buffers GL_NV_draw_instanced GL_NV_draw_texture GL_NV_EGL_stream_consumer_external GL_NV_explicit_attrib_location GL_NV_fbo_color_attachments GL_NV_fill_rectangle GL_NV_fragment_coverage_to_color GL_NV_fragment_shader_interlock GL_NV_framebuffer_blit GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample GL_NV_generate_mipmap_sRGB GL_NV_geometry_shader_passthrough GL_NV_instanced_arrays GL_NV_internalformat_sample_query GL_NV_gpu_shader5 GL_NV_image_formats GL_NV_occlusion_query_samples GL_NV_non_square_matrices GL_NV_pack_subimage GL_NV_packed_float GL_NV_packed_float_linear GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_buffer_object GL_NV_polygon_mode GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_secure_context GL_NV_shader_atomic_fp16_vector GL_NV_shader_noperspective_interpolation GL_NV_shadow_samplers_array GL_NV_shadow_samplers_cube GL_NV_sRGB_formats GL_NV_texture_array GL_NV_texture_border_clamp GL_NV_texture_compression_latc GL_NV_texture_compression_s3tc GL_NV_texture_compression_s3tc_update GL_NV_timer_query GL_NV_viewport_array GL_NV_viewport_array2 GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_buffer GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_view GL_OES_primitive_bounding_box GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_multisample_interpolation GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_cube_map_array GL_OES_texture_npot GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_vertex_array_object GL_OES_vertex_half_float GL_ANDROID_extension_pack_es31a
22:36:40 T:1570724144 ERROR: Error loading addon settings to special://profile/addon_data/plugin.audio.spotify/settings.xml
22:38:14 T:1528813872 NOTICE: Spotify --> Your platform (armv7l System.Platform.Android)
22:38:15 T:1528813872 NOTICE: Spotify --> Starting background service...
22:38:15 T:1528813872 NOTICE: Spotify --> ERROR in backgroundservice! Unable to find 'libspotify'
22:38:15 T:1528813872 ERROR: Exception
22:38:15 T:1528813872 ERROR: OSError
22:38:15 T:1528813872 ERROR: :
22:38:15 T:1528813872 ERROR: OSError("Unable to find 'libspotify'",)
22:38:15 T:1528813872 ERROR: in
22:38:15 T:1528813872 ERROR: <bound method ?.? of <spotify.session.Session instance at 0x5e037808>>
22:38:15 T:1528813872 ERROR: ignored
22:38:15 T:1528813872 NOTICE: Spotify --> Background service stopped
22:39:04 T:1570724144 NOTICE: Spotify --> WebService - start helper webservice on port 52308
22:39:05 T:1570724144 NOTICE: Spotify --> Waiting for authentication token...
22:39:06 T:1414523184 NOTICE: Previous line repeats 1 times.
22:39:06 T:1414523184 ERROR: localhost - - [29/Mar/2016 22:39:06] "GET /callback?code=AQDD6dPmHkwaAIwp2S9TIS5QuYEPhtQQBuFY5PVNxqWBiujhdLSSrJhYeVP-UJ7PLMlug8_g2NVGV0n2pKH-09J1rjV2py32BNWLHo47LfwgHcwtgTpPHYujw6Q_xkg9EfZng21rw53U3hpSuHFsLQCNYerXX4PnQeA6pQqrK2otLQ0vfypnIFkTGeJs60aKOSQEH9W2WJaH3Crt1vwleTcrgydfoUAQ8BYR8Lzsd_YSJ_8_2cZ-dBl07_BXQumkPCjy3Aw9hPNhcqpNCDzVP7fIUWXrVi-rqrlI0eHSbpPbao27oYDoSLvTDJ6_r8bDZFwbR5zVcLn9GTNmtYowq6JqQH_WwOOMLYJWjtIxkb1GOCv5mEH0iKXJN8ugAfqWwoTenlqtxH7msjHIISGp_dpw2_3supiSAr56ROfRpu42Yr-4ZCF-MwsioPc5VPqX_kHXYe6LlX9Bb0sCS78sXZtf2E3PBezCZZh2LAot5CtaSUGwVnPFmerUiHCvMjTgRA HTTP/1.1" 200 -
22:39:07 T:1570724144 NOTICE: Spotify --> WebService - stop called
22:39:07 T:1414523184 ERROR: localhost - - [29/Mar/2016 22:39:07] "GET /favicon.ico HTTP/1.1" 200 -
22:39:07 T:1414523184 ERROR: localhost - - [29/Mar/2016 22:39:07] "QUIT / HTTP/1.1" 200 -
22:39:10 T:1388968240 NOTICE: GL_VENDOR = NVIDIA Corporation
22:39:10 T:1388968240 NOTICE: GL_RENDERER = NVIDIA Tegra
22:39:10 T:1388968240 NOTICE: GL_VERSION = OpenGL ES 3.2 NVIDIA 361.00
22:39:10 T:1388968240 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.20
22:39:10 T:1388968240 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_EXT_base_instance GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_buffer_storage GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_copy_image GL_EXT_debug_label GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_float_blend GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_indirect GL_EXT_multisample_compatibility GL_EXT_occlusion_query_boolean GL_EXT_post_depth_coverage GL_EXT_primitive_bounding_box GL_EXT_raster_multisample GL_EXT_render_snorm GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_sparse_texture GL_EXT_sparse_texture2 GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_format_BGRA8888 GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_view GL_EXT_unpack_subimage GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_NV_bgr GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NV_conditional_render GL_NV_conservative_raster GL_NV_copy_buffer GL_NV_copy_image GL_NV_draw_buffers GL_NV_draw_instanced GL_NV_draw_texture GL_NV_EGL_stream_consumer_external GL_NV_explicit_attrib_location GL_NV_fbo_color_attachments GL_NV_fill_rectangle GL_NV_fragment_coverage_to_color GL_NV_fragment_shader_interlock GL_NV_framebuffer_blit GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample GL_NV_generate_mipmap_sRGB GL_NV_geometry_shader_passthrough GL_NV_instanced_arrays GL_NV_internalformat_sample_query GL_NV_gpu_shader5 GL_NV_image_formats GL_NV_occlusion_query_samples GL_NV_non_square_matrices GL_NV_pack_subimage GL_NV_packed_float GL_NV_packed_float_linear GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_buffer_object GL_NV_polygon_mode GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_secure_context GL_NV_shader_atomic_fp16_vector GL_NV_shader_noperspective_interpolation GL_NV_shadow_samplers_array GL_NV_shadow_samplers_cube GL_NV_sRGB_formats GL_NV_texture_array GL_NV_texture_border_clamp GL_NV_texture_compression_latc GL_NV_texture_compression_s3tc GL_NV_texture_compression_s3tc_update GL_NV_timer_query GL_NV_viewport_array GL_NV_viewport_array2 GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_buffer GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_view GL_OES_primitive_bounding_box GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_multisample_interpolation GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_cube_map_array GL_OES_texture_npot GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_vertex_array_object GL_OES_vertex_half_float GL_ANDROID_extension_pack_es31a
22:40:08 T:1388968240 ERROR: CXBMCApp::StartActivity - ExceptionOccurred launching
22:40:49 T:1388968240 ERROR: Previous line repeats 7 times.
22:40:49 T:1388968240 ERROR: Playlist Player: skipping unplayable item: 2, path [plugin://plugin.audio.spotify/?action=play_android&ownerid=spotify_germany&playlistid=6tjOqHYydB6l0u5G77Nqe9]
Hi Now I get error Spotify login error plataform not supported for playback continuing without playback support running on Android thanks
I have not been able to get this working.
Initially the issue was that the only available browser officially available from the Play Store for the Nvidia Shield does not work, but after I sideloaded Firefox I was prompted to login from a webpage. I logged in, and some time afterwards, probably when trying to start the addon, I was asked to allow plugin access in another website, I assume this is for the API. No when I try to use the addon after some minutes there is an error 'Login error:', nothing after the :. Sometimes before the error Firefox tries to load something on localhost, but the page is always blank. I tried uninstalling and what I think were the config files before reinstalling, but this did not help. I have checked, double-checked, and triple-checked my password, also tried using email instead of username to login, but nothing has changed. Please find the log below:
11:20:38 T:1387059504 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:20:38 T:1387059504 NOTICE: -----------------------------------------------------------------------
11:20:38 T:1387059504 NOTICE: Starting Kodi (16.0 Git:2016-02-20-e240bb2). Platform: Android ARM 32-bit
11:20:38 T:1387059504 NOTICE: Using Release Kodi x32 build
11:20:38 T:1387059504 NOTICE: Kodi compiled Feb 20 2016 by GCC 4.8.0 for Android ARM 32-bit API level 17 (API level 17)
11:20:38 T:1387059504 NOTICE: Running on NVIDIA SHIELD Android TV with Android 6.0.0 API level 23, kernel: Linux ARM 32-bit version 3.10.67+
11:20:38 T:1387059504 NOTICE: FFmpeg version: 2.8.6-kodi-2.8.6-Jarvis-16.0
11:20:38 T:1387059504 NOTICE: Host CPU: Cortex A57 Processor rev 1 (aarch64), 4 cores available
11:20:38 T:1387059504 NOTICE: Product: foster_e_hdd, Device: foster, Board: unknown - Manufacturer: NVIDIA, Brand: NVIDIA, Model: SHIELD Android TV, Hardware: foster_e_hdd
11:20:38 T:1387059504 NOTICE: External storage path = /storage/emulated/0; status = ok
11:20:38 T:1387059504 NOTICE: ARM Features: Neon enabled
11:20:38 T:1387059504 NOTICE: special://xbmc/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
11:20:38 T:1387059504 NOTICE: special://xbmcbin/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
11:20:38 T:1387059504 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
11:20:38 T:1387059504 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
11:20:38 T:1387059504 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
11:20:38 T:1387059504 NOTICE: The executable running is:
11:20:38 T:1387059504 NOTICE: Local hostname: localhost
11:20:38 T:1387059504 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
11:20:39 T:1387059504 NOTICE: load settings...
11:20:39 T:1387059504 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
11:20:39 T:1387059504 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
11:20:39 T:1387059504 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
11:20:39 T:1387059504 DEBUG: AESinkAUDIOTRACK - 44100 supported
11:20:39 T:1387059504 DEBUG: AESinkAUDIOTRACK - 48000 supported
11:20:39 T:1387059504 DEBUG: AESinkAUDIOTRACK - 96000 supported
11:20:39 T:1387059504 DEBUG: AESinkAUDIOTRACK - 192000 supported
11:20:39 T:1387059504 NOTICE: Found 1 Lists of Devices
11:20:39 T:1387059504 NOTICE: Enumerated AUDIOTRACK devices:
11:20:39 T:1387059504 NOTICE: Device 1
11:20:39 T:1387059504 NOTICE: m_deviceName : AudioTrack
11:20:39 T:1387059504 NOTICE: m_displayName : android
11:20:39 T:1387059504 NOTICE: m_displayNameExtra: audiotrack
11:20:39 T:1387059504 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
11:20:39 T:1387059504 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR
11:20:39 T:1387059504 NOTICE: m_sampleRates : 48000,44100,48000,96000,192000
11:20:39 T:1387059504 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
11:20:39 T:1387059504 DEBUG: CSkinSettings: no <skinsettings> tag found
11:20:39 T:1387059504 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
11:20:39 T:1387059504 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
11:20:39 T:1387059504 NOTICE: Default DVD Player: dvdplayer
11:20:39 T:1387059504 NOTICE: Default Video Player: dvdplayer
11:20:39 T:1387059504 NOTICE: Default Audio Player: paplayer
11:20:39 T:1387059504 NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:20:39 T:1387059504 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
11:20:39 T:1387059504 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
11:20:39 T:1387059504 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:20:39 T:1387059504 NOTICE: Loaded playercorefactory configuration
11:20:39 T:1387059504 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:20:39 T:1387059504 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:20:39 T:1387059504 NOTICE: Running database version Addons20
11:20:39 T:1387059504 NOTICE: ADDONS: Using repository repository.beta.emby.kodi
11:20:39 T:1387059504 NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
11:20:39 T:1387059504 NOTICE: CEGLNativeTypeAndroid: Switching to resolution:
11:20:39 T:1387059504 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
11:20:39 T:1387059504 NOTICE: Previous line repeats 1 times.
11:20:39 T:1387059504 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
11:20:39 T:1387059504 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
11:20:39 T:1387059504 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 25.000000 Hz
11:20:39 T:1387059504 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970030 Hz
11:20:39 T:1387059504 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
11:20:39 T:1387059504 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
11:20:39 T:1387059504 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940060 Hz
11:20:39 T:1387059504 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
11:20:39 T:1387059504 NOTICE: Found ([email protected]) at 23, setting to RES_DESKTOP at 16
11:20:39 T:1387059504 NOTICE: Checking resolution 16
11:20:39 T:1387059504 NOTICE: CEGLNativeTypeAndroid: Switching to resolution: 1920x1080 @ 60.00 - Full Screen
11:20:39 T:1387059504 NOTICE: GL_VENDOR = NVIDIA Corporation
11:20:39 T:1387059504 NOTICE: GL_RENDERER = NVIDIA Tegra
11:20:39 T:1387059504 NOTICE: GL_VERSION = OpenGL ES 3.2 NVIDIA 361.00
11:20:39 T:1387059504 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.20
11:20:39 T:1387059504 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_EXT_base_instance GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_buffer_storage GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_copy_image GL_EXT_debug_label GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_float_blend GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_indirect GL_EXT_multisample_compatibility GL_EXT_occlusion_query_boolean GL_EXT_post_depth_coverage GL_EXT_primitive_bounding_box GL_EXT_raster_multisample GL_EXT_render_snorm GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_sparse_texture GL_EXT_sparse_texture2 GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_format_BGRA8888 GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_view GL_EXT_unpack_subimage GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_NV_bgr GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NV_conditional_render GL_NV_conservative_raster GL_NV_copy_buffer GL_NV_copy_image GL_NV_draw_buffers GL_NV_draw_instanced GL_NV_draw_texture GL_NV_EGL_stream_consumer_external GL_NV_explicit_attrib_location GL_NV_fbo_color_attachments GL_NV_fill_rectangle GL_NV_fragment_coverage_to_color GL_NV_fragment_shader_interlock GL_NV_framebuffer_blit GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample GL_NV_generate_mipmap_sRGB GL_NV_geometry_shader_passthrough GL_NV_instanced_arrays GL_NV_internalformat_sample_query GL_NV_gpu_shader5 GL_NV_image_formats GL_NV_occlusion_query_samples GL_NV_non_square_matrices GL_NV_pack_subimage GL_NV_packed_float GL_NV_packed_float_linear GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_buffer_object GL_NV_polygon_mode GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_secure_context GL_NV_shader_atomic_fp16_vector GL_NV_shader_noperspective_interpolation GL_NV_shadow_samplers_array GL_NV_shadow_samplers_cube GL_NV_sRGB_formats GL_NV_texture_array GL_NV_texture_border_clamp GL_NV_texture_compression_latc GL_NV_texture_compression_s3tc GL_NV_texture_compression_s3tc_update GL_NV_timer_query GL_NV_viewport_array GL_NV_viewport_array2 GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_buffer GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_view GL_OES_primitive_bounding_box GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_multisample_interpolation GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_cube_map_array GL_OES_texture_npot GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_vertex_array_object GL_OES_vertex_half_float GL_ANDROID_extension_pack_es31a
11:20:39 T:1387059504 ERROR: Unable to load libcec.so, reason: undefined symbol: NvGlEs2Init
11:20:39 T:1387059504 ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
11:20:39 T:1387059504 NOTICE: Running database version ViewModes6
11:20:39 T:1387059504 NOTICE: Running database version Textures13
11:20:39 T:1387059504 NOTICE: Running database version MyMusic56
11:20:39 T:1387059504 NOTICE: Running database version MyVideos99
11:20:39 T:1387059504 NOTICE: Running database version TV29
11:20:39 T:1387059504 NOTICE: Running database version Epg11
11:20:40 T:1387059504 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
11:20:40 T:1387059504 NOTICE: ActiveAE DSP - starting
11:20:40 T:1387059504 NOTICE: initialize done
11:20:40 T:1387059504 NOTICE: Running the application...
11:20:40 T:1387059504 NOTICE: starting zeroconf publishing
11:20:40 T:1387059504 NOTICE: starting upnp client
11:20:40 T:1505671472 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
11:20:40 T:1505671472 NOTICE: UDP: Listening on port 9777
11:20:40 T:1387059504 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
11:20:40 T:1387059504 NOTICE: GL_VENDOR = NVIDIA Corporation
11:20:40 T:1387059504 NOTICE: GL_RENDERER = NVIDIA Tegra
11:20:40 T:1387059504 NOTICE: GL_VERSION = OpenGL ES 3.2 NVIDIA 361.00
11:20:40 T:1387059504 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.20
11:20:40 T:1387059504 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_EXT_base_instance GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_buffer_storage GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_copy_image GL_EXT_debug_label GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_float_blend GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_indirect GL_EXT_multisample_compatibility GL_EXT_occlusion_query_boolean GL_EXT_post_depth_coverage GL_EXT_primitive_bounding_box GL_EXT_raster_multisample GL_EXT_render_snorm GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_sparse_texture GL_EXT_sparse_texture2 GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_format_BGRA8888 GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_view GL_EXT_unpack_subimage GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_NV_bgr GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NV_conditional_render GL_NV_conservative_raster GL_NV_copy_buffer GL_NV_copy_image GL_NV_draw_buffers GL_NV_draw_instanced GL_NV_draw_texture GL_NV_EGL_stream_consumer_external GL_NV_explicit_attrib_location GL_NV_fbo_color_attachments GL_NV_fill_rectangle GL_NV_fragment_coverage_to_color GL_NV_fragment_shader_interlock GL_NV_framebuffer_blit GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample GL_NV_generate_mipmap_sRGB GL_NV_geometry_shader_passthrough GL_NV_instanced_arrays GL_NV_internalformat_sample_query GL_NV_gpu_shader5 GL_NV_image_formats GL_NV_occlusion_query_samples GL_NV_non_square_matrices GL_NV_pack_subimage GL_NV_packed_float GL_NV_packed_float_linear GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_buffer_object GL_NV_polygon_mode GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_secure_context GL_NV_shader_atomic_fp16_vector GL_NV_shader_noperspective_interpolation GL_NV_shadow_samplers_array GL_NV_shadow_samplers_cube GL_NV_sRGB_formats GL_NV_texture_array GL_NV_texture_border_clamp GL_NV_texture_compression_latc GL_NV_texture_compression_s3tc GL_NV_texture_compression_s3tc_update GL_NV_timer_query GL_NV_viewport_array GL_NV_viewport_array2 GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_buffer GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_view GL_OES_primitive_bounding_box GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_multisample_interpolation GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_cube_map_array GL_OES_texture_npot GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_vertex_array_object GL_OES_vertex_half_float GL_ANDROID_extension_pack_es31a
11:20:43 T:1465899312 NOTICE: script.grab.fanart: Grab Fanart Service Started
11:20:43 T:1466943792 NOTICE: Skin Helper Service --> skin helper service version 1.0.68 started
11:20:43 T:1472166192 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> Starting NextUp Service
11:20:43 T:1472166192 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> ======== START NEXTUP SERVICE NOTIFICATION ========
11:20:43 T:1469032752 NOTICE: service.url.downloader: SERVICE: STARTED
11:20:43 T:1472166192 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> KODI Version: 16.0 Git:2016-02-20-e240bb2
11:20:43 T:1472166192 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> NEXTUP SERVICE NOTIFICATION Version: 1.0.17
11:20:43 T:1472166192 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> Platform: Linux/RPi
11:20:43 T:1466943792 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
11:20:47 T:1467988272 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.15)
11:20:50 T:1507760432 NOTICE: script.module.youtube.dl: youtube_dl core version: 2016.03.18
11:20:50 T:1507760432 NOTICE: version 4.5.3 started
11:20:52 T:1507760432 WARNING: Attempt to use invalid handle 3
11:20:52 T:1507760432 WARNING: Previous line repeats 29 times.
11:20:52 T:1507760432 NOTICE: finished
11:20:57 T:1464854832 NOTICE: version 1.0.1 started
11:20:57 T:1464854832 NOTICE: finished
11:20:58 T:1507760432 NOTICE: version 1.0.1 started
11:20:58 T:1507760432 NOTICE: finished
11:20:59 T:1477388592 NOTICE: version 1.0.1 started
11:20:59 T:1477388592 NOTICE: finished
11:21:00 T:1464854832 NOTICE: version 1.0.1 started
11:21:00 T:1464854832 NOTICE: finished
11:21:01 T:1486870832 NOTICE: version 1.0.1 started
11:21:01 T:1486870832 NOTICE: finished
11:21:02 T:1464854832 NOTICE: version 1.0.1 started
11:21:02 T:1464854832 NOTICE: finished
11:21:03 T:1464854832 NOTICE: version 1.0.1 started
11:21:03 T:1464854832 NOTICE: finished
11:21:04 T:1477388592 NOTICE: version 1.0.1 started
11:21:04 T:1477388592 NOTICE: finished
11:21:05 T:1464854832 NOTICE: version 1.0.1 started
11:21:05 T:1464854832 NOTICE: finished
11:21:06 T:1464854832 NOTICE: version 1.0.1 started
11:21:06 T:1464854832 NOTICE: finished
11:21:08 T:1464854832 NOTICE: version 1.0.1 started
11:21:08 T:1464854832 NOTICE: finished
11:21:09 T:1464854832 NOTICE: version 1.0.1 started
11:21:09 T:1464854832 NOTICE: finished
11:22:08 T:1390258480 NOTICE: VideoInfoScanner: Starting scan ..
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/8 out of 10 Cats/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Agatha Christie's Poirot/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Alan Carr Chatty Man/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Americans/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Armada 12 Days to Save England/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Attenborough 60 Years in the Wild/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Banished/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Beowulf return to the shieldlands/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Better Call Saul/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Black Books/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Blacklist/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Blue Bloods/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Boardwalk Empire/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Broadchurch/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/CSI Cyber/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Cheers/' does not exist - skipping scan.
11:22:21 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Chicago Fire/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Chicago PD/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Comic's Choice/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Dickensian/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Downton Abbey/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Endeavour/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Extant/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Fall/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Fargo/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/From There to Here/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Game of Thrones/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Genius of Charles Darwin/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Gotham/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Graham Norton Show/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Great British Bake Off/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Great Fire/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/HARDtalk/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Happy Valley/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Hatfields & McCoys/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Have I Got News For You/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Homeland/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Honourable Woman/' does not exist - skipping scan.
11:22:22 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Houdini/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/House of Cards (US)/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Hunt/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/I'm a Celebrity...Get Me Out of Here!/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Indian Summers/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/It's Always Sunny in Philadelphia/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Jericho/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Jimmy Kimmel Live/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Jonathan Ross Show/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Justified/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Killing/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Last Kingdom/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Leftovers/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Legends/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Lewis/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Live at the Apollo/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Mayday/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Mock the Week/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Newsroom/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Our Girl/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Our World (2007)/' does not exist - skipping scan.
11:22:23 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Panorama/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Partners in Crime/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Peaky Blinders/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Penny Dreadful/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Pretty Little Liars/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Public Morals/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Ray Donovan/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Returned/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Saturday Night Live/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Seinfeld/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Shadow Line/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Silent Witness/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Silicon Valley/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Sons of Anarchy/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Southcliffe/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Suits/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/The Affair/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Titanic/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Top Gear/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/True Detective/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/UFC/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Village/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Walking Dead/' does not exist - skipping scan.
11:22:24 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Widower/' does not exist - skipping scan.
11:22:25 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Wolf Hall/' does not exist - skipping scan.
11:22:25 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/World Wars/' does not exist - skipping scan.
11:22:25 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Would I Lie to You/' does not exist - skipping scan.
11:22:25 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/Young Ones/' does not exist - skipping scan.
11:22:25 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/hand of god/' does not exist - skipping scan.
11:22:25 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/missing/' does not exist - skipping scan.
11:22:25 T:1390258480 WARNING: virtual void VIDEO::CVideoInfoScanner::Process() directory 'smb://DD-WRT/Media/Video/TV Shows/red road/' does not exist - skipping scan.
11:22:44 T:1390258480 WARNING: No information found for item 'smb://DD-WRT/NAS/Media/Video/TV Shows/Luther - Season 03/', it won't be added to the library.
11:22:44 T:1390258480 WARNING: No information found for item 'smb://DD-WRT/NAS/Media/Video/TV Shows/Mickey Flanagan's Detour De France/', it won't be added to the library.
11:22:44 T:1390258480 WARNING: No information found for item 'smb://DD-WRT/NAS/Media/Video/TV Shows/Mothers Murders and Mistresses Empresses of Ancient Rome/', it won't be added to the library.
11:22:51 T:1390258480 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:42
11:22:51 T:1466943792 NOTICE: Skin Helper Service --> Kodi_Monitor: onDatabaseUpdated: video
11:23:35 T:1391315248 NOTICE: version 1.0.1 started
11:23:36 T:1391315248 NOTICE: finished
11:23:44 T:1393436976 NOTICE: Spotify --> Your platform (armv6 System.Platform.Android)
11:23:45 T:1393436976 NOTICE: Spotify --> Starting background service...
11:23:45 T:1393436976 NOTICE: Spotify --> ERROR in backgroundservice! Unable to find 'libspotify'
11:23:45 T:1393436976 ERROR: Exception
11:23:45 T:1393436976 ERROR: OSError
11:23:45 T:1393436976 ERROR: :
11:23:45 T:1393436976 ERROR: OSError("Unable to find 'libspotify'",)
11:23:45 T:1393436976 ERROR: in
11:23:45 T:1393436976 ERROR: <bound method ?.? of <spotify.session.Session instance at 0x85c52950>>
11:23:45 T:1393436976 ERROR: ignored
11:23:45 T:1393436976 NOTICE: Spotify --> Background service stopped
11:24:14 T:1391315248 NOTICE: Spotify --> WebService - start helper webservice on port 52308
11:24:15 T:1391315248 NOTICE: Spotify --> Waiting for authentication token...
11:24:16 T:1393436976 ERROR: localhost - - [30/Mar/2016 11:24:16] "GET /callback?code=AQA7fRFOyTtRWMzimVZziLpZiZ2ukHQW1OPl4-CJyv-4W69vNpiTlnmv7EEAK_lZlEtZqYFwCnOR8G21Olz-_krFMsmFo4Tk72rtGGw1yb5NCwk0syws5xMC1fcZtCX7scvPBXq0Kl3CodS5XDZY4QOtrO50ALAVhhdkLDfNzdyASFzxBXVZNvEEXMgTMCid0UB6Gpcun01guHZlRgqGjtYz6NUugfypLoypuSAHTGwIDQ8y8fgN9mGAoovl6-I8j0YoDFaj6S15a3HnP7Y7JnbPjqe2XflMgT14o3_3M_DaGtbhpjpowAC7l7o7wXCj-TYPy-5JzngIKAF73_zq7fa-oVANHoCq73IpwWXIKIq1JsuhAAHHp0osVbZLgHb3Gx-LNBOvM_XNGfbBmSkTTnjeP9NiC8QEwAX4Qrh1aazlr3PN0om8ouNDaSzOOI2XBBObiLdxuPONyFRZGesCbipPEslImKAuE9HfZhRfxsPq0I7u3wY-xXZbkIvyTflbBg HTTP/1.1" 200 -
11:24:16 T:1393436976 ERROR: localhost - - [30/Mar/2016 11:24:16] "GET /favicon.ico HTTP/1.1" 200 -
11:24:16 T:1391315248 ERROR: Previous line repeats 1 times.
11:24:16 T:1391315248 NOTICE: Spotify --> WebService - stop called
11:24:16 T:1393436976 ERROR: localhost - - [30/Mar/2016 11:24:16] "QUIT / HTTP/1.1" 200 -
11:24:16 T:1391315248 ERROR: Traceback (most recent call last):
11:24:16 T:1391315248 ERROR: File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.audio.spotify/resources/plugincontent.py", line 653, in checkLoginDetails
11:24:16 T:1391315248 ERROR: error = SpotifyError[int(error)]
11:24:16 T:1391315248 ERROR: ValueError: invalid literal for int() with base 10: ''
11:24:23 T:1387059504 NOTICE: Samba is idle. Closing the remaining connections
11:24:27 T:1387059504 NOTICE: CEGLNativeTypeAndroid: Switching to resolution: 1920x1080 @ 60.00 - Full Screen
11:24:27 T:1387059504 NOTICE: GL_VENDOR = NVIDIA Corporation
11:24:27 T:1387059504 NOTICE: GL_RENDERER = NVIDIA Tegra
11:24:27 T:1387059504 NOTICE: GL_VERSION = OpenGL ES 3.2 NVIDIA 361.00
11:24:27 T:1387059504 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.20
11:24:27 T:1387059504 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_EXT_base_instance GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_buffer_storage GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_copy_image GL_EXT_debug_label GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_float_blend GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_indirect GL_EXT_multisample_compatibility GL_EXT_occlusion_query_boolean GL_EXT_post_depth_coverage GL_EXT_primitive_bounding_box GL_EXT_raster_multisample GL_EXT_render_snorm GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_sparse_texture GL_EXT_sparse_texture2 GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_format_BGRA8888 GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_view GL_EXT_unpack_subimage GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_NV_bgr GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NV_conditional_render GL_NV_conservative_raster GL_NV_copy_buffer GL_NV_copy_image GL_NV_draw_buffers GL_NV_draw_instanced GL_NV_draw_texture GL_NV_EGL_stream_consumer_external GL_NV_explicit_attrib_location GL_NV_fbo_color_attachments GL_NV_fill_rectangle GL_NV_fragment_coverage_to_color GL_NV_fragment_shader_interlock GL_NV_framebuffer_blit GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample GL_NV_generate_mipmap_sRGB GL_NV_geometry_shader_passthrough GL_NV_instanced_arrays GL_NV_internalformat_sample_query GL_NV_gpu_shader5 GL_NV_image_formats GL_NV_occlusion_query_samples GL_NV_non_square_matrices GL_NV_pack_subimage GL_NV_packed_float GL_NV_packed_float_linear GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_buffer_object GL_NV_polygon_mode GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_secure_context GL_NV_shader_atomic_fp16_vector GL_NV_shader_noperspective_interpolation GL_NV_shadow_samplers_array GL_NV_shadow_samplers_cube GL_NV_sRGB_formats GL_NV_texture_array GL_NV_texture_border_clamp GL_NV_texture_compression_latc GL_NV_texture_compression_s3tc GL_NV_texture_compression_s3tc_update GL_NV_timer_query GL_NV_viewport_array GL_NV_viewport_array2 GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_buffer GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_view GL_OES_primitive_bounding_box GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_multisample_interpolation GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_cube_map_array GL_OES_texture_npot GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_vertex_array_object GL_OES_vertex_half_float GL_ANDROID_extension_pack_es31a
11:27:00 T:1387059504 NOTICE: CEGLNativeTypeAndroid: Switching to resolution: 1920x1080 @ 60.00 - Full Screen
11:27:00 T:1387059504 NOTICE: GL_VENDOR = NVIDIA Corporation
11:27:00 T:1387059504 NOTICE: GL_RENDERER = NVIDIA Tegra
11:27:00 T:1387059504 NOTICE: GL_VERSION = OpenGL ES 3.2 NVIDIA 361.00
11:27:00 T:1387059504 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.20
11:27:00 T:1387059504 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_EXT_base_instance GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_buffer_storage GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_copy_image GL_EXT_debug_label GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_float_blend GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_indirect GL_EXT_multisample_compatibility GL_EXT_occlusion_query_boolean GL_EXT_post_depth_coverage GL_EXT_primitive_bounding_box GL_EXT_raster_multisample GL_EXT_render_snorm GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_sparse_texture GL_EXT_sparse_texture2 GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_format_BGRA8888 GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_view GL_EXT_unpack_subimage GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_NV_bgr GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NV_conditional_render GL_NV_conservative_raster GL_NV_copy_buffer GL_NV_copy_image GL_NV_draw_buffers GL_NV_draw_instanced GL_NV_draw_texture GL_NV_EGL_stream_consumer_external GL_NV_explicit_attrib_location GL_NV_fbo_color_attachments GL_NV_fill_rectangle GL_NV_fragment_coverage_to_color GL_NV_fragment_shader_interlock GL_NV_framebuffer_blit GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample GL_NV_generate_mipmap_sRGB GL_NV_geometry_shader_passthrough GL_NV_instanced_arrays GL_NV_internalformat_sample_query GL_NV_gpu_shader5 GL_NV_image_formats GL_NV_occlusion_query_samples GL_NV_non_square_matrices GL_NV_pack_subimage GL_NV_packed_float GL_NV_packed_float_linear GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_buffer_object GL_NV_polygon_mode GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_secure_context GL_NV_shader_atomic_fp16_vector GL_NV_shader_noperspective_interpolation GL_NV_shadow_samplers_array GL_NV_shadow_samplers_cube GL_NV_sRGB_formats GL_NV_texture_array GL_NV_texture_border_clamp GL_NV_texture_compression_latc GL_NV_texture_compression_s3tc GL_NV_texture_compression_s3tc_update GL_NV_timer_query GL_NV_viewport_array GL_NV_viewport_array2 GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_buffer GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_view GL_OES_primitive_bounding_box GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_multisample_interpolation GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_cube_map_array GL_OES_texture_npot GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_vertex_array_object GL_OES_vertex_half_float GL_ANDROID_extension_pack_es31a
11:27:02 T:1464854832 NOTICE: Spotify --> Your platform (armv6 System.Platform.Android)
11:27:02 T:1464854832 NOTICE: Spotify --> Starting background service...
11:27:02 T:1464854832 NOTICE: Spotify --> ERROR in backgroundservice! Unable to find 'libspotify'
11:27:02 T:1464854832 ERROR: Exception
11:27:02 T:1464854832 ERROR: OSError
11:27:02 T:1464854832 ERROR: :
11:27:02 T:1464854832 ERROR: OSError("Unable to find 'libspotify'",)
11:27:02 T:1464854832 ERROR: in
11:27:02 T:1464854832 ERROR: <bound method ?.? of <spotify.session.Session instance at 0x844882f0>>
11:27:02 T:1464854832 ERROR: ignored
11:27:02 T:1464854832 NOTICE: Spotify --> Background service stopped
11:27:32 T:1393486128 ERROR: Traceback (most recent call last):
11:27:32 T:1393486128 ERROR: File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.audio.spotify/resources/plugincontent.py", line 653, in checkLoginDetails
11:27:32 T:1393486128 ERROR: error = SpotifyError[int(error)]
11:27:32 T:1393486128 ERROR: ValueError: invalid literal for int() with base 10: ''
11:28:10 T:1390258480 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting
11:28:22 T:1753798960 NOTICE: Kodi Log Uploader: started
11:28:22 T:1753798960 NOTICE: Kodi Log Uploader: settings: len(email)=20
11:28:22 T:1753798960 NOTICE: Kodi Log Uploader: settings: skip_oldlog=True
11:28:24 T:1753798960 NOTICE: Kodi Log Uploader: reading log...
Cannot login in Kodibuntu. Usename is kätyri so there is this ä character which may cause problems.
Here is some Python error log:
File "/home/kodi/.kodi/addons/plugin.audio.spotify/resources/plugincontent.py", line 670, in checkLoginDetails
20:11:18 T:140603060905728 ERROR: error = int(error)
20:11:18 T:140603060905728 ERROR: ValueError: invalid literal for int() with base 10: "argument 2: <type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode character u'\\xe4' in position 1: ordinal not in range(128)"
20:11:18 T:140603060905728 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnboundLocalError'>
Error Contents: local variable 'errorStr' referenced before assignment
File "/home/kodi/.kodi/addons/plugin.audio.spotify/plugin.py", line 3, in <module>
Main().main()
File "/home/kodi/.kodi/addons/plugin.audio.spotify/resources/plugincontent.py", line 730, in main
if self.checkLoginDetails():
File "/home/kodi/.kodi/addons/plugin.audio.spotify/resources/plugincontent.py", line 680, in checkLoginDetails
dlg.ok(ADDON_NAME, ADDON.getLocalizedString(11019) + ': ' + errorStr)
UnboundLocalError: local variable 'errorStr' referenced before assignment
(2016-03-30, 12:57)dusf Wrote: [ -> ]I have not been able to get this working.
Please try again with latest version. This log is from previous version.
I'm not sure if this is ever going to work because I think the nvidia shield has an armv8 architecture and libspotify is only available form armv6 and armv7.
In the most recent version it will at least fallback to the android spotify app for playback.
(2016-03-29, 23:15)mystic84 Wrote: [ -> ]Hi Now I get error Spotify login error plataform not supported for playback continuing without playback support running on Android thanks
For playback only the addon still relies on the old libspotify SDK which hasn't been updated for 2 years.
That means that a few newer ARM platforms (especially on Android) will not be supported, the same applies to x86 based Android devices, it simply won't work.
Spotify promises that there will soon be a solution for that, untill that we''ll have to wait.
For now I have coded it as such that if your platform isn't supported you can still browse the addon and it will fallback to the native spotify app for playback.
Hello Marcel,
thank you for your work.
I have the same error as other people with newer Android boxes. Playback is not supported.
I hope there will be a solution somedaybecause I don't like the native Android app in Kodi :-(
(2016-03-30, 20:08)PimPandoer72 Wrote: [ -> ]Hello Marcel,
Well, I have coded the entire addon to use the new Spotify Web Api (that's why you have to authenticate through a browser) but full length playback is not yet supported so for playback I still had to use the old libspotify SDK (also used in spotimc and spotlight kodi addons) which is really outdated.
Once the playback support is added to the new API I will offcourse change the playback code to that.
(2016-03-22, 21:31)marcelveldt Wrote: [ -> ] (2016-03-22, 21:27)Jönke Wrote: [ -> ]How to use on Raspberry pi with Openelec ? ( has no webbrowser)
I will add support for the web Viewer addon today:
http://kodi.wiki/view/Add-on:Web_Viewer
EDIT: hmm, tried that and isn't working so no luck for pi users.
There is a small workaround to try if you have another client which actually does have a browser:
1. install the spotify client on a pc with a browser
2. open the spotify client and accept the authentication request in the browser.
3. now, on the filesystem navigate to kodi userdata\addon_data\plugin.audio.spotify and copy the cache file to the same location on your pi
I didn't test this but it's worth a shot If it works it might be an idea if I create an option to specify a custom path to the cache file because the token gets refreshed from time to time.
No luck on my Rpi yet , has anybody got it running on Rpi ?
Thanks! works great.(latest Openelec) I was hoping spotify connect would be available, is this possible?
I tried a couple spotify addons but it seems like every time the developer gives up on the project and it ends up broken. How do I go about donating?
Did 1.0.8 break playlist ? Everything but my playlist works in spotify now
This is what i get in log when try to open playlist
http://pastebin.com/DWBR6LuY
Still some problems with ÅÄÖ letters ? When acess playlist i get a new folder named "j%c3%b6nke-user" and not jönke-user
I'll take a look tomorrow at the reports/requests, busy with some other stuff today
(2016-04-02, 13:53)Jönke Wrote: [ -> ]This is what i get in log when try to open playlist
Version 1.0.9 is now uploading to the repo. That should fix the unicode issue
