Full Version: [Mod] Settings menu and home screen thumbs issue
Dear TGX,
First of all I want to thank you for your hard work and amazing skins.
I use Nebula with my build and it is simply amazing.
I have some issues regarding thumbnails for the home screen and for the settings menu.
I investigated the variety of XML files in the skin and I see that the *.jpg files under Backgrounds are set for both home screen and the system settings menu (with the thumbnails) and they are actually connected.
The reason I'm asking to set each menu with different thumbs and that they won't correspond with each other is due to the fact I want to preset the path in the XML file in order to install my build on another machine without having to set the
thumbnails all over again.
So far I used special://skin/backgrounds/..... as my home tiles thumbnails and it works perfectly fine.
For the settings menu, I found the correct place in the XML file but I cannot see the changes..
Can you advise? perhaps I need to refer to another XML to apply the changes?
Thanks in advance!
Regards,
Etai.
What do you mean for thumbnails for the settings menu?
I cannot understand your request.
Tgx
Hey. Didn't see the reply :/
I managed to overcome all that mentioned above but I'm facing other issue..
I want to change the position of the OSD Menu bar from top to the bottom area. Is that possible?
There no option for this. Sorry
Tgx
OK. Thanks for the quick reply man!
