2016-03-23, 10:58
Hi there,
Iv'e just started playing around with accessing my library remotely for when i'm on the go.
I'm using MYSQL for the library and FTPS to access the files, which is now working well remotely. However I can only wake my PC up by using a Wake on Lan Command. The Wake on Access feature appears not to work outside of the local network despite trying to tinker with the hostname and port etc.
Just wondering if anyone has successfully managed to get this to work? It seems the only workaround i have at this stage is to send a Wake on Lan command with the device and setup continuous wake on lan packets from within kodi once its loaded, to keep the pc from going to sleep which im accessing it remotely and not streaming any files/browsing.
Thanks in advance,
Thanks in advance,
