Full Version: Startup.xml showing not only in start of kodi
hello guy's I have small issue with my skin that i making.
the problem is that the Startup.xml showing not only in start of kodi
like he should to be he showing up after i delete an add-on for example
or doing apply background pack's from the "resources" addons
after i am doing something like the splash screen i am using is showing up
and the skin Returning back to the home menu
can someone has a guess why is can be happen?
thx Smile
please post your Startup.xml code and a Debug Log.
1) post here your startup.xml file [Edit: ronie is quicker Wink ]
2) are you sure all the startup file is being executed? try to put some dummy command like SetString or something to help you debug it.
3) did you noticed something weird in the log after it happens ?
Maybe you are using an ActivateWindow-function in the Startup.xml instead of a ReplaceWindow-function?
