2016-04-19, 20:06
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
2016-04-19, 23:30
Sure, via Kodi and HDHomeRun add-on, I'm playing ATSC mpeg2 fine. Also tried the HDHomeRun app off Google play. I didn't pay particular attention to deinterlacing and others aspects of live TV rendering closely however. With locally saved mpeg2 and H.264, Q10 does mostly well. Just can't play C-band 4:2:2 type stuff, but that's satellite.
2016-04-20, 04:29
hdmkv, Attach a Keyboard and hit the "O" codec Key and tell us pls what decoder is being used when watching Interlaced content ?
I would like to know if its inferior Bob Software (ff-mpeg) or Hardware deinterlacing ?
The Video OSD settings will also give it away. If the Video deinterlacing options Pop up that indicates Software deinterlacing.
2016-04-20, 11:19
The Q10 is starting to look quite attractive indeed.. Some quick questions–
1. How user-configurable is the Android OS on it? I.e, can you add custom commands to its bootup sequence (/etc/rc.local equivalent?) Prob. a silly question, but I am mostly used to standalone boxes.
2. Are there any options for caching of video streams, e.g via .kodi/userdata/advancedsettings.xml – in order to avoid i/o starvation?
(That is; if + are set will the himedia wrapper honor those? Obviously those settings are for a system w/ much more onboard RAM than the Q10.)
3. And lastly, are people happy with the stock remote? Too bad it isn't backlit though, and having the option to use a bluetooth remote would increase reception
significantly. (a matter of preference I know, but I have the media box in an adjacent room)
(That is; if
<buffermode>1</buffermode>
<readbufferfactor>20.0</readbufferfactor>
<cachemembuffersize>638860800</cachemembuffersize>
2016-04-20, 11:49
(2016-04-20, 11:19)Drag0nFly Wrote: [ -> ]The Q10 is starting to look quite attractive indeed.. Some quick questions–
(That is; if+Code:<buffermode>1</buffermode>
are set will the himedia wrapper honor those? Obviously those settings are for a system w/ much more onboard RAM than the Q10.)Code:<readbufferfactor>20.0</readbufferfactor>
1) You can use this hack http://www.android-mediaplayer.de/index....a-Q5-3D4k/ EDIT: NO first firmware not have adb over tcp enable
2) No, why do you need more "caching of video streams"?
3) you can use hicontrol wherever there is wifi , https://www.youtube.com/watch?v=DdyMFE4VV3A
2016-04-20, 12:08
1. Thanks for the input (& the script)–so I guess there is no direct ssh access to the box? Bummer.
2. I don't need 'more' caching of video, I just need 'some' caching. The reason I am asking this is that even with locally-attached storage you will occasionally risk stutter at some point when viewing full-bitrate streams, unless your NFS server is 100% idle doing nothing else or you have a dedicated (overpriced/low capacity) NAS box. This was the case for my internal SATA disks as well as a RAID5 enclosure.
3. No wifi-so not an option. Anyone tried connecting a PS3 remote to it? I know Kodi supports it, but it needed some tweaking with LIRC/bdremote-ng.
2016-04-20, 12:22
Hy guys,
Futeko just updated their Q5 Pro page with images of the new unit.
That's the one I follow considering that I want to stream media from server via wired lan.
Looks good.
Looks good.
2016-04-20, 12:27
(2016-04-20, 12:08)Drag0nFly Wrote: [ -> ]1. Thanks for the input (& the script)–so I guess there is no direct ssh access to the box? Bummer.
1) why do you need ssh access? it's not a smartphone or NAS
2) i not understand, i am not ever issues about caching also when i playback a full 3d ISO with old NAS with fast ethernet( 10mb/s ).
3) hicontrol APP is more better remote control ever try and it's free , you can control q10 without turn on TV. Why you need PS3 remote?
2016-04-20, 13:05
(2016-04-20, 12:27)looun Wrote: [ -> ](2016-04-20, 12:08)Drag0nFly Wrote: [ -> ]1. Thanks for the input (& the script)–so I guess there is no direct ssh access to the box? Bummer.
SSH makes a lot of stuff easier. You need to make a quick .xml file change - then you can just SSH in and run nano. If you have SSH you usually also have SCP so it's easier to transfer files across, edit larger things on a PC and send them back again, all without having to touch a USB stick.
2016-04-20, 14:30
Hello HDMKV,
do you find another bugs since your review April 16 2016 ?
i am so disappointed about the new Q5 pro's design, I going to order the Q10 pro the next week.
2016-04-20, 14:54
(2016-04-20, 13:05)noggin Wrote: [ -> ]SSH makes a lot of stuff easier. You need to make a quick .xml file change - then you can just SSH in and run nano. If you have SSH you usually also have SCP so it's easier to transfer files across, edit larger things on a PC and send them back again, all without having to touch a USB stick.For editing files on my Android box, I have simply add a FTP server apps and I can edit XML or whatever with WinSCP on my Windows laptop
2016-04-20, 20:53
(2016-04-20, 14:30)OlivierQC Wrote: [ -> ]Hello HDMKV,As part of beta-test group, we have brought 20+ issues/bugs to HiMedia's attention. Around 5 were closed, fixed. Those 20+ that remain aren't all serious... I'd say maybe around 5-7 are 'medium' to 'high' priority. It will take some time.
2016-04-20, 21:00
(2016-04-20, 04:29)wrxtasy Wrote: [ -> ]hdmkv, Attach a Keyboard and hit the "O" codec Key and tell us pls what decoder is being used when watching Interlaced content ?
Kodi report :
h.264 = dc: amc-h264(S)
mpeg2 = dc:ff-mepg2video
SMPC report:
dc: amc-h264
i not understand the "S", which is the difference amc-h264 vs amc-h264(S)?
2016-04-21, 00:16
HiMedia has posted the latest firmware for Q10 Pro here, but don't get excited yet, as it's the shipping firmware. But, the flip-eyes 3D fix at least should be in the next firmware.
2016-04-21, 03:08
(2016-04-20, 21:00)looun Wrote: [ -> ]As expected for Android, not as good as RPi (hybrid), AMLogic or Intel quality Hardware deinterlacing...(2016-04-20, 04:29)wrxtasy Wrote: [ -> ]hdmkv, Attach a Keyboard and hit the "O" codec Key and tell us pls what decoder is being used when watching Interlaced content ?
Kodi report :
SMPC report:
dc: amc-h264
S stands for surface I believe, beyond that I've never seen an explanation of the differences between the two.
