Huhu!
So the Q10 doesnt switch to 23,976hz under 1920*1080 which is a shame and a no go. Will they fix it yes or no? When?
And then it still stutters when switched to 23,976hz? Is that the case? Always? That would be another no go
And real HDR 10 bit doesnt work or does it now?
(2016-06-14, 08:22)yusufomur Wrote: [ -> ]Hi Guys,
I have bought a Q5 Pro from China and want to upgrade it to the Eng version and use Kodi, wrapper etc. How can i manage it? Is there anyone can help me?
You can NOT, Eng and China version are different.
I know ENG and China version are different but i am looking for a way. Is there any possibility to change it from China to ENG?
(2016-06-14, 12:16)D3rdevil Wrote: [ -> ]So the Q10 doesnt switch to 23,976hz under 1920*1080 which is a shame and a no go. Will they fix it yes or no? When?
Don't know when 23.976 will overall be fixed. We beta-testers are trying to figure out how best to show the issue to HiMedia team. Taking picture or even videos won't work. The microstutters, at least in my case,
sometimes happen 2-3 times in a 2-hour movie (even 1920x1080p and above), and seem random, and can't be replicated in those same spots.
Re: HDR10, yes, works, but isn't fully there yet, as some banding is noticeable, especially in scenes with sky or other large solid parts. There's a new beta-tester f/w today w/a note "Improve the compatibility of HDMI for HDR", so HiMedia is obviously still working on this.
God bless you both keep us informed
Good evening,
I checked HDR10 + YCbRc 4.2.0 10Bit and 8Bit with the last beta FW 1.0.4 and the problem persists with all demo 4K HDR.
with the internal player Sony, they're work perfectly.
@ hdmkv/@
looun or any one else with a Q10/Q5 Pro: Does this actually support FLAC bitstream (non-decoded FLAC) over HDMI as mentioned by Simon and another user on Futeko forums?
(2016-06-15, 04:41)wesk05 Wrote: [ -> ]@ hdmkv/@looun or any one else with a Q10/Q5 Pro: Does this actually support FLAC bitstream (non-decoded FLAC) over HDMI as mentioned by Simon and another user on Futeko forums?
The answer is Yes. It bitstream untouched Flac file to my AVR with native Music Player. You can not manipulate volume with Q10 remote, and the AVR show 92kHz or higher
(2016-06-15, 05:43)Transit266 Wrote: [ -> ] (2016-06-15, 04:41)wesk05 Wrote: [ -> ]@ hdmkv/@looun or any one else with a Q10/Q5 Pro: Does this actually support FLAC bitstream (non-decoded FLAC) over HDMI as mentioned by Simon and another user on Futeko forums?
What is your AVR brand model? Just because your AVR shows 96 or 192 kHz doesn't mean that it is FLAC bitstream.
[/quote]
[/quote]
My AVR is Onkyo Base V20HD. I cannot manipulate the volume by Q10 pro remote
Strange, flac bitstream is not oficially supported for HDMI.
(2016-06-15, 09:28)hansolo Wrote: [ -> ] (2016-06-15, 04:41)wesk05 Wrote: [ -> ]@ hdmkv/@looun or any one else with a Q10/Q5 Pro: Does this actually support FLAC bitstream (non-decoded FLAC) over HDMI as mentioned by Simon and another user on Futeko forums?
I think there are some misunderstandings here. Q10 pro can decode FLAC to lossless PCM (which is bit to bit) and send untouched signal to AVR. Since for Android system, if it "touches" this PCM signal, only 44.1kHz come out as many android developer forum mention this
