hmm. I'm getting the impression HDR is a very vague term, with very varying compliance. But an essential marketing checkbox feature atm
(2016-09-20, 17:02)hdmkv Wrote: [ -> ]On Q10 Pro, believe @OlivierQC tested w/his Sony HDR TV, and it indicated HDR mode engaged. One of @mirror88's screenshots shows similar for Zidoo X9S. Wish I had a HDR-capable display to verify.
Doing some testing with HDR files that i downloaded from UHD-demo and i don't see any HDR signal engage on my TV, HDR signal does engage when i use my Xbox One S to play UHD Blu-ray Disc, so i know HDR is working on my TV.
(2016-09-20, 15:55)looun Wrote: [ -> ]Simple explanation is :
Quote:one key.xml for all Android HiMedia/OEM device sale in last 3 years. Like you already know are many Chinese version of box with different IR remote that international version. Some HiMedia customer have special request, for launcher / TV streaming / DVB tuner and other witch I not observed.
If I've understood your argument, this file is intended for many devices of this brand (sorry, but your english is not easy to understand). And if so, is there any Android device (customized for another company or not) using a remote with a stop button? I've read previously that there is no Android box in the market with a remote with that button, all of them just have a 'Return/Back' button. IMHO, I think HiMedia's purpose is kind of different and maybe, as I said before, they tried to include standard commands for other controllers which should use these standard (IR or key?) codes too (logically). The proof for my assertion would be to test a controller (IR remote or special keyboard) with the stop button, for example.
Just my 2 cents, of course.
(2016-09-20, 17:10)hdmkv Wrote: [ -> ]Right, and quality and type of implementation seems to vary. Have a look at this AVSForum user's screenshots with Epson 5040UB and JVC RS400 PJ's. The SDR screenshot looks better than any of the HDR modes (granted, judging PQ solely by screenshots isn't accurate, but at least you can appreciate the differences in rendering).
There is a right faff going on with the new Epsons (9300 / 7300 - UK names) and HDR, people using HDFury's to strip HDR and just get WCG in rec.2020, but then HDR working properly in 8 or 12bit but not 10bit...
Hopefully next year things might smooth out in this area, too many inconsistencies atm.
ps. I see Android 7.0 has had support for all HDR's added.
(2016-09-20, 17:22)movie78 Wrote: [ -> ] (2016-09-20, 17:02)hdmkv Wrote: [ -> ]On Q10 Pro, believe @OlivierQC tested w/his Sony HDR TV, and it indicated HDR mode engaged. One of @mirror88's screenshots shows similar for Zidoo X9S. Wish I had a HDR-capable display to verify.
yes HDR mode is engaged when i watch HDR demo ( all demo 4k HDR works perfectly) on my Sony x93c with my xbox One S or my Q10 pro.
(2016-09-20, 22:42)OlivierQC Wrote: [ -> ] (2016-09-20, 17:22)movie78 Wrote: [ -> ] (2016-09-20, 17:02)hdmkv Wrote: [ -> ]On Q10 Pro, believe @OlivierQC tested w/his Sony HDR TV, and it indicated HDR mode engaged. One of @mirror88's screenshots shows similar for Zidoo X9S. Wish I had a HDR-capable display to verify.
What HDR Files are you testing with?
If you test HDR10 or DV on any of the well authored movies (UHD discs for HDR10 vs. Vudu for DV), you definitely see a big difference between HDR vs SDR. I have a LG 65 E6P, which is DV capable and the built-in apps (Netflix, Vudu - DV vs Amazon - HDR10). When I watch HDR content, the difference in the image is night & day.
new version
KEY_MAP 0.2 patch
thanks to pcristi now also button 2 open PQTool ,PQSetting pop-up, with all application
like youtube:
good afternoon movie78,
i made a mistake about One S, demo 4k hdr do not work at all (no picture no sound) as you only UHD Blu-ray Disc works.
with Q10 pro my tv switch HDR mode with all demo HDR (for information the box is connected directly to the TV)
i will uploaded my demo, tomorrow i will give the url if you are interested
https://1fichier.com/?pbndzaq9jr
see you
(2016-09-21, 01:35)OlivierQC Wrote: [ -> ]good afternoon movie78,
see you
Thanks! waiting for you demos to do some testing...
This file is suppose to be HDR, Can you please test it?
Good morning movie78,
i will test LG Chess - HDR this evening
Here you are ( file size 12go - Demo 4k SDR and HDR) :
IMPORTANT :
The following demo are only for LG and Vizio TV Dolby Vision ( i do not know if they works with Q10 pro, may be ''the_jaguar'' with his LG oled could test them) with my TV they works as demo SDR :
LG_2_DEMO_4K_O_H_1_Dolby Comparison_OLED
LG_2_DEMO_4K_O_H_2_Dolby Trailer.
Have nice day
OlivierQC
(2016-09-21, 13:30)OlivierQC Wrote: [ -> ]Good morning movie78,
Here you are ( file size 12go - Demo 4k SDR and HDR) : https://1fichier.com/?pbndzaq9jr
The following demo are only for LG and Vizio TV (Dolby Vision), i do not know if they works with Q10 pro : LG_2_DEMO_4K_O_H_1_Dolby Comparison_OLED, LG_2_DEMO_4K_O_H_2_Dolby Trailer.
Have nice day
OlivierQC
Thanks @
OlivierQC i tested the video from the link i posted above and Yes HDR does activate with Himedia Q10Pro on my TV.
Last night I was testing 10bit HDR demos again and comparing the Q10 pro against my Samsung js8500 native player.
For me this was the best demo to test against.
Samsung UHD : Ride on Board
I must say that visually I couldn't tell the difference between the 2 renders.
