2017-07-12, 18:14
(2017-07-12, 08:12)nicole zhong Wrote: [ -> ]Q5 Pro Latest firmware 2.0.4: http://www.mediafire.com/file/54jp83470p...update.zip
Changelog:
1.HDR ratio issue fixed
2.Fix the issueome Apps stop working caused by DATA patition read-only
3.Issue of compatibility with some routers fixed
4.Not working when press 3D button of the remote control issue fixed
5.Fix the issue:the subtitle cannot be moved by the Navigation buttons of the remote control
6.TV’s fault output issue fixed
7.Lagging issue caused by turnning on the 24hz fixed
8.System crash caused by mmc issue fixed
9.23.976 and 24hz files frame-skipping and jittering issue fixed
10.Blurred screen sometimes issue fixed
11.No sound of AAC 22.05K 5.1 channels pass-through issue fixed
12.No sound of 96K PCM 7.1 channels pass-through issue fixed
13.Frame rate auto-adaptation optimized
14.File manager optimized, language sources added, some useless files filtered
15.Video player optimized
--3D/2D indication when playback a movie added
--3D/2D default playback setting added into the playback menu
--not working when switch HDR issue fixed
--video player UI optimized
--some BDMV and BD 3D ISO not playback in KODI’s NFS issue fixed
16.Media Center UI optimized
17.Filter the useless file “RECYCLE.BIN TD Dwonload THUNDERDB Alarms Notifications Ringtones Podcasts DCIM dlna”in mediacenter
18.HD playback optimized bring many useful functions
Thank you !
