Hi I installed xonfulance jarvis, I am trying to set the begging of a menu item name
Example:
[COLOR BLUE]L[/COLOR]ive TV
but it cuts the "L" off can someone help?
I think the color itself needs to be in lower case.
[COLOR blue]
ok that works but why does blue turn to green lol?
(2016-03-26, 20:46)PhaseCoder Wrote: [ -> ]ok that works but why does blue turn to green lol?
You're welcome...
Probably the way your display works.
Blue seems blue to me on mine.
I sorted it if i did [COLOR blue] would turn it green just had to get the hex value
Have you tried Xconfluence?
Hundreds of color options in that skin interface.
(never mind , you posted in the wrong area but your first post mentioned Xconfluence skin)
