2016-03-28, 07:55
Hi everyone,
I've read here and though there are explanations of how ad skipping works I can't get a predictable or reliable behavior from Kodi and was hoping someone with some inside knowledge could share their understanding of it please.
As an overview I'm using the latest Kodi for Windows (Jarvis 16.0) though as it's been the same for the previous 2 versions of Kodi I don't believe it's version specific. Here is the format of the files I get from comskip:
(txt file)
(edl file)
With these I get different behaviors for different recordings using these files. That itself varies dependent upon whether I have the txt or edl file - or both present. It can also vary between and within recordings.
The behaviors I see are:
- seeking ahead 10 or 30 minutes instead stops at the next commercial break
- for some programs (and even within the same one) commercials are sometimes automatically skipped and sometimes not
- requesting a commercial is skipped can result in a 10 second pause before it recommences playing. This can be avoided by pressing pause and play immediately after the skip button
Does anyone understand what the variables are which control this, if the behavior is intended?
Thank you!
(txt file)
FILE PROCESSING COMPLETE 94439 FRAMES AT 2500
25 88
6552 7747
13544 16800
(edl file)
262.04 309.84 3
541.72 671.96 3
Thank you!
