(2019-03-09, 20:29)fmedrano1977 Wrote: [ -> ]Is the PS175 display port to HDMI 2.0 conversion chip only found in mother boards?
That seems to be the case;
DisplayPort to HDMI / DVI Converters
- +PS161 DisplayPort to HDMI 1.3/DVI Converter
- +PS171 DisplayPort to HDMI 1.4/DVI Converter
- +PS175 DisplayPort to HDMI 2.0 Protocol Converter for Mother Board Applications
- +PS176 DisplayPort to HDMI 2.0 Protocol Converter for Adapters and Receivers
- +PS181 DisplayPort to Dual-Mode DisplayPort Converter
- +PS186 DisplayPort 1.4a to HDMI 2.0b Protocol Converter for Adapters and Receivers
Uploaded new build based on latest commits by @
afedchin (from 15th March).
This build is based on Kodi 18.
2 RC1. I haven't tested this build yet by myself.
All old shared links are obsolete, as I have made a new folder KODI-MVC in which all releases are organised as subfolders.
So in future, the links should always be the same:
KODI-MVC builds
Have fun testing!
Edit:
Tried it quickly, seems to work fine
Thank you both
Will give it a go when I'm feeling a bit better
Edit: seems to work just fine !
3D MVC is working fine on which HDMI version?
Does 4K HDR (all various versions) also work?
And lossless passthrough audio with Atmos/dts:X metadata?
I appreciate those working to update this and work out the kinks but do find it a little difficult to follow along as to just what is 'working'.
Kodi does not support HDR, yes to the rest except for MVC, which works dependent on hardware.
Why is there no HDR support?
(2019-03-16, 23:14)K0D1User1138 Wrote: [ -> ]Why is there no HDR support?
That's a question for the Kodi developers.
(2019-03-16, 23:30)fmedrano1977 Wrote: [ -> ] (2019-03-16, 23:14)K0D1User1138 Wrote: [ -> ]Why is there no HDR support?
True enough, I was just under the impression that Leia was full 4K HDR Bells and Whistles and if adding MVC 3D to that would be amazeballs.
I've got a simple question, is there a way to automate the "enable 3D display mode" setting in Windows display settings? Like perhaps some kind of script that I could set Kodi to run (similar to external players) when running files with 3D in the name.
(2019-03-21, 05:17)MustangSVT Wrote: [ -> ]I've got a simple question, is there a way to automate the "enable 3D display mode" setting in Windows display settings? Like perhaps some kind of script that I could set Kodi to run (similar to external players) when running files with 3D in the name.
what for? just enable it and leave it alone
(2019-03-21, 08:32)afedchin Wrote: [ -> ] (2019-03-21, 05:17)MustangSVT Wrote: [ -> ]I've got a simple question, is there a way to automate the "enable 3D display mode" setting in Windows display settings? Like perhaps some kind of script that I could set Kodi to run (similar to external players) when running files with 3D in the name.
If you leave it enabled, the TV/resolution sits in 3D mode all the time, which means 24p never engages properly for me in 2D movies, at least that's my impression from testing so far.
(2019-03-22, 16:48)MustangSVT Wrote: [ -> ] (2019-03-21, 08:32)afedchin Wrote: [ -> ] (2019-03-21, 05:17)MustangSVT Wrote: [ -> ]I've got a simple question, is there a way to automate the "enable 3D display mode" setting in Windows display settings? Like perhaps some kind of script that I could set Kodi to run (similar to external players) when running files with 3D in the name.
MustangSVT, you are talking about the setting to put Kodi always in 3D? Skin view also I mean?
"Stereoscopic 3D mode / current"? << This setting?
Nah I'm not talking about a Kodi setting. I'm talking like if you right-click your desktop in Windows 10, go Display Settings, and there's a slide toggle for 3D. I was looking for a way to automate that setting. You're saying that it's not necessary to ever fiddle with it? I should just leave it on?
MustangSVT, yes, in my case it leaves my 3D computer_desktop in 2D 1080p/60Hz. After starting Kodi, it changes to 3D/24p when necessary or, with 2D media, to the refresh-rate that the media has.
Didn't check that on my Home Theater setup (see below), but that will be the same I assume.
check your windows or GPU driver, it shouldn't enable stereoscopic mode. the settings just allows using stereoscopic mode by an application
