(2016-06-12, 19:14)rickyman Wrote: [ -> ]is Ant-man and Guardian of the Galaxy work on newest kodi mvc or not? does it work with the menu also?
Ant-man and Guardian of the Galaxy 3D BD J Menu doesn't work, the movie start playback directly in 3D.
hdmkv, you can add these to the Right eye first list:
-Peanuts Movie
-The Darkest Hour
Thanks...
I listed them here. A decent # of titles are right-eye first;
probably still missing a few from list:
- The Chronicles of Narnia: The Voyage of the Dawn Trader
- The Darkest Hour
- Dolphin Tale
- Drive Angry
- Edge of Tomorrow
- Gulliver's Travels
- The Hobbit: An Unexpected Journey
- The Hobbit: The Desolation of Smaug
- The Hobbit: The Battle of the Five Armies
- Ice Age 3: Dawn of the Dinosaurs
- The Peanuts Movie
- Rio
- A Turtle's Tale: Sammy's Adventures
i am wondering if i can install this version of kodi 17 with windows 7. why do i have to install windows 8 or 10 on it?
how do you enable the BD-J menus?
I have java installed though not certain if needed.
i have a folder (not ISO) and it's scanned into the library correctly.
when i try playback i'm prompted to select the menu style so I choose Blu Ry. after a short pause it just starts playing back a title with no menu displayed at all.
does this only work with ISOs?
hdmkv
Just bought a new slimline AVR, Marantz NR-1606, it appears that my CD Audio lossless issue reported previously was caused by an incompatibility with the Intel Display Audio in the Brix J1900 and the Pioneer VSX-S510K receiver, others are having the same issue with intel drivers and other receivers though.
There are now no lipsync issues with the Brix J1900 with the new receiver.
The only issue I have now is when I disable 'Windowed Full Screen' as it uses less CPU and Avatar drop loads of frames with this enabled, all 3D MVC films show at 30Hz, I have found a workaround to this is to set the display resolution to 24Hz in the Intel Display Control Panel, it still auto selects the correct framerate for all other files, like 50Hz for PAL, it just seems to make the default 24Hz for anything that is not auto switching correctly. So it solves the issue for now.
With your Dell 3050 with the J1800 did you notice the same issue, or any tips to force a refresh rate change to 24Hz by codec type.
(2016-06-14, 04:41)movie78 Wrote: [ -> ] (2016-06-14, 03:06)TheShoe Wrote: [ -> ]how do you enable the BD-J menus?
Try this.
SETTINGS/ PLAYER SETTINGS / DISC / BLU-RAY PLAYBACK MODE /SHOW BLU-RAY MENU
did. still doesnt work. will try another bluray and see if it works.
this was the Pixar Short Films collection Volume 2 that failed. backup using MakeMKV to a folder.
(2016-06-14, 13:06)TheShoe Wrote: [ -> ] (2016-06-14, 04:41)movie78 Wrote: [ -> ] (2016-06-14, 03:06)TheShoe Wrote: [ -> ]how do you enable the BD-J menus?
Try this.
Try to convert BD folder into an ISO.
(2016-06-14, 13:15)movie78 Wrote: [ -> ] (2016-06-14, 13:06)TheShoe Wrote: [ -> ] (2016-06-14, 04:41)movie78 Wrote: [ -> ]Try this.
Which movies did it work for you ?
I have try " rush hour 1/2/3 " and " cloverfield 10 " and more ISO and didn't work menu.
For have BD-J you need libluray.dll with bd-java active (don´t have this dll with bd-java available since version 0.68 on experimental kodi by @Ace). Kodi need compiled with support BD Java, too.
Check this old thread about
http://forum.kodi.tv/showthread.php?tid=...pid1877904
Change for show menus, don´t active bd-java, only show traditional menus (without bd-java).
Version Kodi by afdechin, don´t have support bd-java, too.
(2016-06-14, 14:37)movie78 Wrote: [ -> ] (2016-06-14, 14:07)Neighbour Wrote: [ -> ] (2016-06-14, 13:15)movie78 Wrote: [ -> ]Try to convert BD folder into an ISO.
I have try " rush hour 1/2/3 " and " Cloverfield 10 " and more ISO and didn't work menu.
Quote:V for vendetta (BD-J)
the dark knight (BD-J)
batman begins (BD-J)
the dark knight rises (BD-J)
young Frankenstein (BD-J)
Argo (BD-J)
Spider-man (BD-J)
Man in black 2 (BD-J)
And More!!
hey - did you need to compile the dll and kodi yourself refrenced in this thread and others?
or did you do a straight up install of the WIP mvc enabled kodi and it worked?
also - i mount my media over smb but for this experiment over nfs. does it have to be local?
thanks
