(2016-06-14, 14:50)Wanilton Wrote: [ -> ]For have BD-J you need libluray.dll with bd-java active (don´t have this dll with bd-java available since version 0.68 on experimental kodi by @Ace). Kodi need compiled with support BD Java, too.
Check this old thread about
http://forum.kodi.tv/showthread.php?tid=...pid1877904
Change for show menus, don´t active bd-java, only show traditional menus (without bd-java).
Version Kodi by afdechin, don´t have support bd-java, too.
I am using @
afedchin latest build w/ Estuary MOD (UPDATED 13/06/16) and @
Angelinas MQ6 Krypton Build and BD Menu works on some movies for me.
It´s not relationed with skin used, version afedchin don´t have support bd-java, but have libbluray.dll more actual 0.9.2, when default Kodi Krypton continue with version 0.8.1 for same dll. Of course when disc menu don´t use java, will work great.
(2016-06-14, 15:14)Wanilton Wrote: [ -> ]It´s not relationed skin used, version afedchin don´t have support bd-java, but have libbluray.dll more actual 0.9.2, when default Kodi Krypton continue with version 0.8.1 for same dll. Of course when disc menu don´t use java, will work great.
So how do we determine if the Disc is using BD J ?
Studios inform when have java support (Java it´s no used only for disc menu).
Use
bdinfo, look this image, item 3
wow i just found this topic now, i just want to say thanks for the hard work, every 3D work great on my I7 PC Intel 4600 graphic
thanks alot
So what version of Kodi Support BD J?
so if i'm interpreting this thread correctly BD-J development stalled (according to that other thread) and in the WIP MVC build it's not "active" despite showing as an option. one must compile both the dll and rebuild kodi to get it working.... and it only works for some not all.
(2016-06-15, 14:25)TheShoe Wrote: [ -> ]so if i'm interpreting this thread correctly BD-J development stalled (according to that other thread) and in the WIP MVC build it's not "active" despite showing as an option. one must compile both the dll and rebuild kodi to get it working.... and it only works for some not all.
Compiling and adding it to the MVC build will depend on @
afedchin
Yes, need compile both, libbluray.dll and kodi, both with java support actived.
(2016-06-15, 16:22)Wanilton Wrote: [ -> ]Yes, need compile both, libbluray.dll and kodi, both with java support actived.
Can you compile the MVC build with libbluray.dll?
KODI MVC with bd java actived is simple for me create install, but I don´t have linux here for compile DLL, sorry.
(2016-06-15, 16:38)Wanilton Wrote: [ -> ]KODI MVC with bd java active is fine for me, but I don´t have linux here for compile DLL, sorry.
For Windows ?
What do you mean
is fine for me [ What build version are you using] ?
I know how compile kodi with bd-java actived for use with windows OS. But I don´t have linux OS, for create libblurary.dll.
(2016-06-15, 16:43)Wanilton Wrote: [ -> ]I know how compile kodi with bd-java actived for use with windows OS. But I don´t have linux OS, for create libblurary.dll.
Can I get a copy of your Windows Kodi BD J Activated?
