Hello,
I'm trying to use the advancedsettings.xml on my Android Shield TV.
Thing is, the 'clean library during library update' doesn't seem to be working?
<advancedsettings>
<videolibrary>
<cleanonupdate>true</cleanonupdate> <!-- Also clean library during library update -->
<importwatchedstate>true</importwatchedstate>
<hideallitems>true</hideallitems> <!-- removes the "*All" items from the video library -->
<hideemptyseries>true</hideemptyseries> <!-- hide empty series in the video library -->
</videolibrary>
<video>
<timeseekforward>15</timeseekforward> <!-- Skip back time 15 s -->
<timeseekbackward>-15</timeseekbackward> <!-- Skip forward time 15 s -->
<subsdelayrange>240</subsdelayrange> <!-- Subtitle offset adjustment range -->
</video>
<network>
<buffermode>1</buffermode> <!-- Default is 1 -->
<cachemembuffersize>52428800</cachemembuffersize> <!-- Default is 20971520 bytes or 20 MB -->
<readbufferfactor>2.0</readbufferfactor> <!-- Default is 1.0 -->
</network>
<advancedsettings>
Am I doing something wrong here?
can you upload a debug log of you updating your library?
(2016-03-28, 20:47)helta Wrote: [ -> ]can you upload a debug log of you updating your library?
Thank you for suggesting to log
Guess the advancedsettings.xml is not loading?
22:06:47 T:1387174192 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:06:47 T:1387174192 NOTICE: -----------------------------------------------------------------------
22:06:47 T:1387174192 NOTICE: Starting Kodi (16.1-RC2 Git:2016-03-28-be20e8a). Platform: Android ARM 32-bit
22:06:47 T:1387174192 NOTICE: Using Release Kodi x32 build
22:06:47 T:1387174192 NOTICE: Kodi compiled Mar 28 2016 by GCC 4.8.0 for Android ARM 32-bit API level 17 (API level 17)
22:06:47 T:1387174192 NOTICE: Running on NVIDIA SHIELD Android TV with Android 6.0.0 API level 23, kernel: Linux ARM 32-bit version 3.10.67+
22:06:47 T:1387174192 NOTICE: FFmpeg version: 2.8.6-kodi-2.8.6-Jarvis-16.0
22:06:47 T:1387174192 NOTICE: Host CPU: Cortex A57 Processor rev 1 (aarch64), 4 cores available
22:06:47 T:1387174192 NOTICE: Product: foster_e, Device: foster, Board: unknown - Manufacturer: NVIDIA, Brand: NVIDIA, Model: SHIELD Android TV, Hardware: foster_e
22:06:47 T:1387174192 NOTICE: External storage path = /storage/emulated/0; status = ok
22:06:47 T:1387174192 NOTICE: ARM Features: Neon enabled
22:06:47 T:1387174192 NOTICE: special://xbmc/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
22:06:47 T:1387174192 NOTICE: special://xbmcbin/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
22:06:47 T:1387174192 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
22:06:47 T:1387174192 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
22:06:47 T:1387174192 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
22:06:47 T:1387174192 NOTICE: The executable running is:
22:06:47 T:1387174192 NOTICE: Local hostname: localhost
22:06:47 T:1387174192 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
22:06:47 T:1387174192 NOTICE: load settings...
22:06:47 T:1387174192 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
22:06:47 T:1387174192 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
22:06:47 T:1387174192 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
22:06:47 T:1387174192 DEBUG: AESinkAUDIOTRACK - 44100 supported
22:06:47 T:1387174192 DEBUG: AESinkAUDIOTRACK - 48000 supported
22:06:47 T:1387174192 DEBUG: AESinkAUDIOTRACK - 96000 supported
22:06:47 T:1387174192 DEBUG: AESinkAUDIOTRACK - 192000 supported
22:06:47 T:1387174192 NOTICE: Found 1 Lists of Devices
22:06:47 T:1387174192 NOTICE: Enumerated AUDIOTRACK devices:
22:06:47 T:1387174192 NOTICE: Device 1
22:06:47 T:1387174192 NOTICE: m_deviceName : AudioTrack
22:06:47 T:1387174192 NOTICE: m_displayName : android
22:06:47 T:1387174192 NOTICE: m_displayNameExtra: audiotrack
22:06:47 T:1387174192 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
22:06:47 T:1387174192 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR
22:06:47 T:1387174192 NOTICE: m_sampleRates : 48000,44100,48000,96000,192000
22:06:47 T:1387174192 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
22:06:47 T:1387174192 DEBUG: CSkinSettings: no <skinsettings> tag found
22:06:47 T:1387174192 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
22:06:47 T:1387174192 ERROR: Error loading special://profile/advancedsettings.xml, Line 0
Error reading Element value.
There is no '/' in your closing tag in the advancedsettings.xml you posted.
It should be
(2016-03-28, 21:27)black_eagle Wrote: [ -> ]There is no '/' in your closing tag in the advancedsettings.xml you posted.
It should be
Bless your soul
That did the trick! Thank you. While I'm still here, Yahoo weather seems to have stopped working. Just shows as 'busy' ?
23:37:58 T:1386060080 DEBUG: ADDON: cpluff: 'Plug-in weather.yahoo has been installed.'
23:37:59 T:1410328880 DEBUG: CPythonInvoker(10, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/weather.yahoo/default.py): start processing
23:38:02 T:1410328880 DEBUG: CPythonInvoker(10, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/weather.yahoo/default.py): the source file to load is "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/weather.yahoo/default.py"
23:38:02 T:1410328880 DEBUG: CPythonInvoker(10, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/weather.yahoo/default.py): setting the Python path to /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/weather.yahoo:/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.simplejson/lib:/:/data/app/org.xbmc.kodi-2/base.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.kodi-2/base.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.kodi-2/base.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.kodi-2/base.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.kodi-2/base.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.kodi-2/base.apk/assets/python2.6/lib/python2.6/lib-dynload
23:38:02 T:1410328880 DEBUG: CPythonInvoker(10, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/weather.yahoo/default.py): entering source directory /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/weather.yahoo
23:38:02 T:1410328880 DEBUG: CPythonInvoker(10, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/weather.yahoo/default.py): instantiating addon using automatically obtained id of "weather.yahoo" dependent on version 2.19.0 of the xbmc.python api
23:38:02 T:1410328880 DEBUG: weather.yahoo: version 3.0.9 started: ['/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/weather.yahoo/default.py', '1']
23:38:02 T:1410328880 DEBUG: weather.yahoo: weather location: 1967057
23:38:14 T:1410328880 DEBUG: weather.yahoo: weather download failed
Quote:While I'm still here, Yahoo weather seems to have stopped working. Just shows as 'busy' ?
How to fix is provided in
post #165 in the weather addons support/yahoo! thread of forums.
It should be
Would there be a way I can initiate the Artwork downloader to download Artwork right after the library update?
