2016-03-29, 03:24
Hello,
I noticed a behavior which I don't know if it works as designed or is a bug (tested on Kodi 13 - 16; same result in all versions).
My directory structure
tv shows
└───Lost
├───s01
├────── lost-s01e01-720p.mkv
├────── lost-s01e24-720p.mkv
When I add the source "tv shows" to Kodi, the scraper runs and detect everything perfect.
In my library the tv show "Lost" shows up with all seasons and their episodes.
I wanted to setup a second Kodi installation, so I decided to export the video library (separate files per entry) to save some time at the scraping process on the new installation.
On the new installation, I added the same source as I previous did. In the library "Lost" shows up with all seasons. But when I go to "Season 1" however, all episodes are listed twice. The episodes are first listed with the pattern "[1-24]. TITLE". Then they are listed again with the pattern "720. TITLE".
Screenshot:
I really appreciate any help/tip.
tv shows
└───Lost
├───s01
Screenshot:
