Full Version: "Add to favourites" keyboard shortcut
Hi all,
Is it possible to map the "Add to favourites" function from within the kodi context menu to an unused key on the keyboard?
Many thanks in advance
Keyboard controls (wiki) outside of these, nothing inside Kodi or the skins; but that doesn't mean it's impossible. It's all open source so if you're willing to get your hands dirty and coding hat on, anything is possible. I suspect that with a fancy remote, you could bring up the context menu, down arrow to favs and toggle and it all might be one button press with some sort of script.
Suggestion: Investigate Add-on:Super Favourites (wiki) it may give you some ideas.
Thank you for the response mate. Appreciated.
Just in case; Add-on:Super Favourites can be activated with a quick start hotkey... I use F10
