(2017-06-16, 16:03)edit4ever Wrote: [ -> ]If you have the OTA grabber enabled, you will only get 1-3 days depending on what the station is transmitting.
If you have that enabled and at a higher priority than the zap2xml grabber, then the channel is likely defaulting to that OTA info.
For a test - disable the OTA grabber - and also make sure the zapxml grabber is enabled. Then go into CONFIG > CHANNEL/EPG > CHANNELS and make sure that you have selected a zap2xml EPG source for each channel.
Then rerun the internal grabber. Watch the log window (open at the bottom right of the screen - double up arrows) and after a minute or two you should see an update that says how many channels, programs, etc it grabbed. Post that info here if you can. Thanks.
1) zap2xml is the only grabber on. It is set to priority 1
2) 25 channels are all set to use the zap2xml grabber
3) ran the grabber and here is the log info:
2017-06-16 10:39:22.001 epgdb: snapshot start
2017-06-16 10:39:22.036 epgdb: queued to save (size 863669)
2017-06-16 10:39:22.036 epgdb: brands 0
2017-06-16 10:39:22.036 epgdb: seasons 163
2017-06-16 10:39:22.036 epgdb: episodes 1518
2017-06-16 10:39:22.036 epgdb: broadcasts 1613
2017-06-16 10:39:22.039 epgdb: save start
2017-06-16 10:39:22.087 epgdb: stored (size 122342)
2017-06-16 10:39:36.104 xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: grab /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml
2017-06-16 10:39:36.108 spawn: Executing "/storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml"
2017-06-16 10:39:42.384 xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: grab took 6 seconds
2017-06-16 10:39:42.454 xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: parse took 0 seconds
2017-06-16 10:39:42.454 xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: channels tot= 30 new= 0 mod= 0
2017-06-16 10:39:42.454 xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: brands tot= 0 new= 0 mod= 0
2017-06-16 10:39:42.454 xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: seasons tot= 304 new= 304 mod= 304
2017-06-16 10:39:42.454 xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: episodes tot= 305 new= 215 mod= 215
2017-06-16 10:39:42.454 xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: broadcasts tot= 305 new= 0 mod= 0
4) checked the EPG and the last data is for Sunday (three days)!
