maybe i did not delete the user data correctly but i could not get past entering the zip code. the log files were empty
also i am running the milhouse builds so maybe i just need to wait.
I tested your zap2epg update again, but same problem, keep asking me to input my zip code. Keep saying, "No Lineup configured", "Please configure your zip code and lineup under Change Current Location", when I do that, it keeps asking me for my zip code, again, and again. I get a zap2epg error, check the log.
2017-10-28 11:12:26.646 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: grab /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg
2017-10-28 11:12:26.653 spawn: Executing "/storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg"
2017-10-28 11:12:30.865 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: grab took 4 seconds
2017-10-28 11:12:30.875 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: parse took 0 seconds
2017-10-28 11:12:30.876 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: channels tot= 42 new= 0 mod= 0
2017-10-28 11:12:30.876 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: brands tot= 0 new= 0 mod= 0
2017-10-28 11:12:30.876 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: seasons tot= 0 new= 0 mod= 0
2017-10-28 11:12:30.876 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: episodes tot= 0 new= 0 mod= 0
2017-10-28 11:12:30.876 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: broadcasts tot= 0 new= 0 mod= 0
OK - let me take a look and make sure they didn't change the lineup info. One of the issue may be the popup they are deploying to announce the new site. Thanks for the feedback!
Can you take alook at the settings.xml in userdata/addon_data/script.module.zap2epg folder and see it shows for zipcode and lineupid?
I'm wondering if the settings.xml hasn't been created since I didn't instruct anyone to go into settings. So when the zip and lineup dialogs are run - it doesn't have a place to save that info to!
Information from settings.xml. Zipcode is correct for my location.
- <settings>
<setting id="days" value="1" />
<setting id="desc01" value="10" />
<setting id="desc02" value="18" />
<setting id="desc03" value="6" />
<setting id="desc04" value="13" />
<setting id="desc05" value="6" />
<setting id="desc06" value="15" />
<setting id="desc07" value="2" />
<setting id="desc08" value="9" />
<setting id="desc09" value="2" />
<setting id="desc10" value="14" />
<setting id="desc11" value="6" />
<setting id="desc12" value="11" />
<setting id="desc13" value="6" />
<setting id="desc14" value="12" />
<setting id="desc15" value="6" />
<setting id="desc16" value="20" />
<setting id="desc17" value="6" />
<setting id="desc18" value="19" />
<setting id="desc19" value="0" />
<setting id="desc20" value="0" />
<setting id="epicon" value="1" />
<setting id="lineup" value="" />
<setting id="lineupcode" value="" />
<setting id="slist" value="19600,94750,35451,98069,35449,20359,40547,35425,19601,35140,10088,73228,71559,71009,43963,95697,24050,70820,66303,43546,58754,51974,52944,51976,51970,11322,83510,82737,10119,32512,71843,103765,73826,103766,32511,25126,54803,102095,25512,45325,20376,42610" />
<setting id="xdesc" value="true" />
<setting id="xdetails" value="false" />
<setting id="zipcode" value="48346" />
</settings>
edit4ever
thank you for the good news. will give it a try as soon as i resolve my LibreElec 8.2 upgrade issues.
(2017-10-29, 16:56)clarkss12 Wrote: [ -> ]Information from settings.xml. Zipcode is correct for my location.
</settings>
Interesting that you have a channels list - did you add those manually? Which lineup are you selecting? I would like to recreate the issue on my end.
(2017-10-30, 15:18)edit4ever Wrote: [ -> ] (2017-10-29, 16:56)clarkss12 Wrote: [ -> ]Information from settings.xml. Zipcode is correct for my location.
</settings>
Yes, your app running on LibreELEC 8.2 allowed me to select my channels, it picked up all my channels from my HDHomeRun tuner.
Strange - i wouldn't think it would create a channel list without a lineup selected. I'm guessing it defaulted to the OTA lineup even though it didn't set it in the settings.xml file.
Can you try setting to a different lineup (like cable) and then setting it to the correct one and see if it sticks?
(2017-10-30, 17:18)edit4ever Wrote: [ -> ]Strange - i wouldn't think it would create a channel list without a lineup selected. I'm guessing it defaulted to the OTA lineup even though it didn't set it in the settings.xml file.
I tried adding Comcast, and Dish Network, but still shows the local OTA channels.
2017-10-30 13:36:26.257 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: grab /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg
2017-10-30 13:36:26.264 spawn: Executing "/storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg"
2017-10-30 13:36:26.587 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: grab took 0 seconds
2017-10-30 13:36:26.587 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: parse took 0 seconds
2017-10-30 13:36:26.587 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: channels tot= 0 new= 0 mod= 0
2017-10-30 13:36:26.587 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: brands tot= 0 new= 0 mod= 0
2017-10-30 13:36:26.587 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: seasons tot= 0 new= 0 mod= 0
2017-10-30 13:36:26.587 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: episodes tot= 0 new= 0 mod= 0
2017-10-30 13:36:26.587 xmltv: /storage/.kodi/addons/script.module.zap2epg/bin/tv_grab_zap2epg: broadcasts tot= 0 new= 0 mod= 0
Boy...from the time a posting appears here to when I actually get an email about it...sheesh
Just want to let you know I'm still here but unable to help out at the moment. My RPI 3 system can access my local subnet but cannot get out onto the web (which explains the catastrophic failures I've gotten since Oct. 20.....but may not explain the smaller, more inconsistent ones
Got some folks helping from a different thread so as soon as I've got my sys back to "normal", I'll rejoin the testing process of your new code.
Cheers.....
(2017-10-30, 19:36)clarkss12 Wrote: [ -> ] (2017-10-30, 17:18)edit4ever Wrote: [ -> ]Strange - i wouldn't think it would create a channel list without a lineup selected. I'm guessing it defaulted to the OTA lineup even though it didn't set it in the settings.xml file.
Did it change what shows in settings? Did it keep the Dish or Comcast lineup info or just remain blank?
(2017-10-30, 22:13)edit4ever Wrote: [ -> ] (2017-10-30, 19:36)clarkss12 Wrote: [ -> ] (2017-10-30, 17:18)edit4ever Wrote: [ -> ]Strange - i wouldn't think it would create a channel list without a lineup selected. I'm guessing it defaulted to the OTA lineup even though it didn't set it in the settings.xml file.
Yes, it showed what I changed it to, ex. Comcast, showed, but listings were still for OTA.
OK. I (and my RPI 3/OSMC/TVHeadEnd sys) am back and ready to help out
Problem was -> DHCP + Static ipaddr + power outage/reboot = network collision
Looks like some issues going on with the grabber so I'll wait for the next go around and then join in.
Cheers.....
