2017-10-31, 15:37
@clarkss12 - it would make sense that it is showing the ota channels as you created a channel list. In the zap2epg addon, change to Comcast, then go to the channel list option and see if the Comcast channels come up for selecting. You should get a prompt first that says "existing channel list detected - do you want to download a new list" say yes to this and see if the channels available change. If so, then go ahead and put your lineup back to over the air, and run the channel list option again and select the OTA channels you want to keep.
Then, go ahead and run zap2epg from within the addon and see if you get a prompt when finished saying if it created the xmltv.xml file with XX channels and XX episodes. If you do - then you're all set and you just need to setup the grabber in tvheadend.
Thanks for testing!
@stephr1 - this version should be working and is worth testing. I am running it a a number of systems and all seems fine. The testing process for new installs is what I need feedback on to see if I need to make any changes to instructions or settings to easily get people up and running. If you could test I would appreciate it. You don't have to set it up in tvheadend if you don't want to - just install the zap2rpg addon, setup your zipcode and lineup and then run it from the addon to see if it generates an xmltv.xml file. The channel list is optional. Thanks!
Thanks for testing!
