Thank You will give it a go.!
can't watch movies ,quota has been reached error.
I downloaded the newest Youtube plugin and the No streams error disappeared, so thanks for that.
But now "Hide Watched" doesn't work anymore. Anyone else have this glitch?
hi guys ,
I ve jus installed the addon on my kodi 17.
All seems to work fine , but all videos are in 720p.
even if I select : "ask for videos quality" in options , max res is 720p
no possiblity to have 4k youtube videos with this addon ?
(2017-02-12, 17:35)marcaurellexxx Wrote: [ -> ]hi guys ,
read the first post
Quote:Kodi 17 and inputstream.adaptive Add-on are required for 1080p and above to work
inputstream.adaptive may be included with your installation of Kodi 17, and some installations will be require it to be enabled and/or installed.
4K at 30fps works, not sure about 60fps, even though 60fps works at lower resolutions
hi siggijarl ,
inputstream.adaptive Add-on was already installed but input stream adaptative wasn't enabled in addons
I enabled it , but still the same , all videos in youtube addon : max 720p res
perhaps , I forgot to enable something
edit : seems to be ok with input stream adaptative with a minimal bandwith (I put 10.000.000)
I have many problems reading Youtube videos (Video stream not found, max search request and many more).
I want to update Youtube addons.
I searched the librelec Wiki, and nothing about updating addons.
How do you manually update addons ?
Even Addons forum has no sticky note "how-to update addons manually".
Also, Input Stream Adaptive is not listed in the "addons repository"... Where do you find it ?
I'm lost... How to manually update Youtube Addon and check "input stream adaptive"..
Please help.
Thank you.
(2017-02-12, 19:32)iosys Wrote: [ -> ]Also, Input Stream Adaptive is not listed in the "addons repository"... Where do you find it ?
Check
My Addons. If it's listed, enable it. If it's not listed, it's probably not available for your platform yet.
(2017-02-12, 17:34)Thinaran Wrote: [ -> ]I downloaded the newest Youtube plugin and the No streams error disappeared, so thanks for that. But now "Hide Watched" doesn't work anymore. Anyone else have this glitch?
Please see the FAQ in Post 3 on Page 1
here.
95% of the videos i want to watch wont load.Works ok on normal "chrome/fifrefox" but on on kodi i get error message or no message at all, just a loading screec and nothing after that.... Was no problem on kodi 16.1 but on 17 some videos wont play..
Youtube 5.3.9 with my own keys on LibreELEC (Krypton) v7.95.3 BETA has been flawless (Thanks Guys) until now. 503 service unavailable.
http://sprunge.us/Hffg
Edit: After a few hours it seems to be working ok now
Kodi v17 the date of the video (publishedAt?) is no longer displayed on any skin?
Just curious, why doesnt the plugin auto update to 5.3.9 rather than having to manually do it? And when installing 5.3.9 do I download the .master version of the addon or the one which says 5.3.9 from the list?
(2017-02-13, 11:31)Gregoire Wrote: [ -> ] (2017-02-10, 16:39)jdf76 Wrote: [ -> ] (2017-02-10, 14:30)Gregoire Wrote: [ -> ]My youtube plugin updated to 5.4.1 Did I miss something?
There is no 5.4.1.
Last version is 5.3.9.
You can check github.com/jdf76/plugin.video.youtube/blob/master/addon.xml
Jeff
That's odd. hmm.
Not odd because you are using a pirated addon which has this version number
