mmmmmmmmm..... about id i have this in "old" confluence skin i installed.... :
<?xml version="1.0" encoding="UTF-8"?>
<window>
<defaultcontrol always="true">50</defaultcontrol>
<menucontrol>9000</menucontrol>
<views>50,51,500,550,551,560,501,508,504,503,515,505,511</views>
<onload condition="!Skin.HasSetting(FirstTimeRun)">ActivateWindow(1112)</onload>
<controls>
<include>CommonBackground</include>
<include>ContentPanelBackgrounds</include>
<control type="group">
<include>Window_OpenClose_Animation</include>
<!-- view id = 50 -->
<include>CommonRootView</include>
<!-- view id = 51 -->
<include>FullWidthList</include>
<!-- view id = 500 -->
<include>ThumbnailView</include>
<!-- view id = 501 -->
<include>PosterWrapView</include>
<!-- view id = 508 -->
<include>PosterWrapView2_Fanart</include>
<!-- view id = 503 -->
<include>MediaListView3</include>
<!-- view id = 504 -->
<include>MediaListView2</include>
<!-- view id = 515 -->
<include>MediaListView4</include>
<!-- view id = 505 -->
<include>WideIconView</include>
<!-- view id = 511 -->
<include>MusicVideoInfoListView</include>
<!-- view id = 550 -->
<include>AddonInfoListView1</include>
<!-- view id = 551 -->
<include>AddonInfoThumbView1</include>
<!-- view id = 560 -->
<include>LiveTVView1</include>
it's possibly estuary doesn't have id 53 54 ?? Strange.................
Meanwhile this is the first 10/20 line of my MyVideoNav.xml.... it's possibly i need to test every of this for obtain how i desire.. you thinks it's correctly ?
At this point on OSMC i need to found where it's installed the stock "Estuary" because it's not on "addons" folder.....
anxdpanic about subtitle.
I thinks i have understand how i do... i need to disable the preferred language in main kodi preferences right ? I need to set this to none/forced....... After this on addons preferences i need to set it's to "Option" and if all it's all correct i can enable of disable the subtitle for player OSD....... need to test
*EDIT*
About id of stock estuary.. on osmc it's installed here -> /usr/share/kodi/addons/skin.estuary/
There's no a 720p folder........... a file called "MyVideoNav.xml" it's here -> /usr/share/kodi/addons/skin.estuary/xml/
Have a totally different value for id........... i thinks i need to test my preferred one at one.......
*EDIT After found a working good configuration*
OOOHH Finally friends.... all it's working right now... X subtitle:
1) Go on "Language" preferences of Kodi.... i have set to "Nothigs" to default for subtitle and "Italian" on default language download
2) On Settings of Youtube Addons i have setted to "Option" on subtitle language.
In this mode when i start a video if i want to subtitle appears i need only to enable it from Player OSD Subtitle Tabs......
For ID View:
Yeah... it's working.... on actually 5.4.5 and stock estuary i can set 3 view type, "Info Wall" "Wide List" and "Large List". From MyVideoNav.xml i have look the corrisponding ID..... i have set to 55 on "Advanced" tabs to force and..... it's work... now the force it's work
Thanks for all info friends
